I am looking for the default profile that was supposed to be included in 1.7.7 to make these conversions (FLAC,TRUEHD,AC3,E-AC3,DTS)->LPCM
from... viewtopic.php?f=10&t=4776
As of version 1.7.7 following conversions are supported:
(LPCM,TRUEHD,AC3,E-AC3,DTS)->FLAC
It doesn't appear to be in 1.15.2
Any help would be greatly appreciated.
Re: (FLAC,TRUEHD,AC3,E-AC3,DTS)->LPCM
Where are you seeing that MakeMKV converts to LPCM?
Reviewing the history back as far as 1.0.1, there is no mention of LPCM encoding, just improvements in how it is handled when read.
MakeMKV v1.7.7 ( 16.8.2012 )
Improved handling for DVD/Blu-ray discs with mastering errors
MakeMKV now prevents computer going to sleep mode during copy
Miscellaneous stability improvements
Max OS X changes:
BDMV folder bundles can be selected on Mountain Lion
Switched from GROWL to Mountain Lion notifications
Expert mode:
MakeMKV now includes ffmpeg executable with 24-bit FLAC encoder
New FLAC profile
Bug fixes:
On some DVDs MakeMKV could go into endless loop when opening disc in CellWalk mode
MakeMKV could hang (endless ASSERT) on titles with seamless branching and LPCM tracks
Forced subtitles were extracted incompletely on certain blu-ray discs
Aspect ratio was sometimes incorrect for H.264 SD content
Occasionally makemkvcon executable could stay running in background even after application window was closedMakeMKV Frequently Asked Questions
litlgi74
Hello...
@mike admin specifically mentions it in this thread...
https://www.makemkv.com/forum/viewtopic.php?f=10&t=4776
Then we'll have to wait for Mike to respond, because I find no record of an "LPCM profile", but the FLAC profile has been part of MakeMKV since 1.7.7.
There is an AAC profile that was added at 1.8.8.
With the FLAC or AAC profile selected, tracks that CAN be converted show an arrow between the original track and what it will be converted to. If you can find a copy of the LPCM profile, dropping it in your MakeMKV data directory should make it available in Expert mode. Maybe someone has it somewhere?
Question: Why would you want to use LPCM instead of FLAC? I can see a desire to avoid lossy conversions, but LPCM is uncompressed, making it rather large for what you're getting.
You can create a conversion profile to specify LPCM output.
https://www.makemkv.com/forum/viewtopic.php?f=10&t=4385
After reading this guy's post https://www.makemkv.com/forum/viewtopic ... 10&t=21630 I was able to hack my own conversion profile to turn DTS-HD MA tracks into LCPM-raw. I tried it on a Blu-ray backup I had lying around and it dutifully produced a giant audio track in the resulting MKV file.
In the unconverted MKV, the DTS-HD MA track is only 4.2 GB. The DTS-HD MA track as FLAC is 3.6 GB as reported by MediaInfo.
If you really need LCPM, then so be it, but I think FLAC is probably a better option for most people.
Audio #4
ID in the original source medium : 4352 (0x1100)
Format : PCM
Format settings : Little / Signed
Codec ID : A_PCM/INT/LIT
Duration : 1 h 59 min
Bit rate mode : Constant
Bit rate : 9 216 kb/s
Channel(s) : 8 channels
Sampling rate : 48.0 kHz
Frame rate : 30.000 FPS (1600 SPF)
Bit depth : 24 bits
Stream size : 7.71 GiB (25%)
Title : Surround 7.1
Language : English
Default : No
Forced : No
Original source medium : Blu-rayIf you really need LCPM, then so be it, but I think FLAC is probably a better option for most people.
litlgi74
I have a device that can only accept LPCM over HDMI... It is unable to decode any audio format.dcoke22 wrote: Sun Sep 20, 2020 5:24 am You can create a conversion profile to specify LPCM output.
In the unconverted MKV, the DTS-HD MA track is only 4.2 GB. The DTS-HD MA track as FLAC is 3.6 GB as reported by MediaInfo.Code: Select all
Audio #4 ID : 5 ID in the original source medium : 4352 (0x1100) Format : PCM Format settings : Little / Signed Codec ID : A_PCM/INT/LIT Duration : 1 h 59 min Bit rate mode : Constant Bit rate : 9 216 kb/s Channel(s) : 8 channels Sampling rate : 48.0 kHz Frame rate : 30.000 FPS (1600 SPF) Bit depth : 24 bits Stream size : 7.71 GiB (25%) Title : Surround 7.1 Language : English Default : No Forced : No Original source medium : Blu-ray
litlgi74
I have a device, Smyth Realiser A8, that can only accept LPCM over HDMI... It is unable to decode any audio format.Woodstock wrote: Sun Sep 20, 2020 4:40 am Question: Why would you want to use LPCM instead of FLAC? I can see a desire to avoid lossy conversions, but LPCM is uncompressed, making it rather large for what you're getting.
