Try what?hepe9 wrote: Sat Sep 19, 2020 12:22 pmPlease can you try it with the firestick?ragico wrote: Sat Sep 19, 2020 11:20 amIn the mp4 files I did not add subtitles so don't know if they are displayed in firestick.
In the DV Mkv played in shield/ugoos am6plus via kodi/exoplayer, the pgs subs work and are displayed correctly.
@yusesope I don't know, is only a idea, I say that becouse it work on Android devides but no in X700
You're are the master here![]()
If .pgs subtitles works with the firestick and exoplayerragico wrote: Sat Sep 19, 2020 12:33 pmTry what?hepe9 wrote: Sat Sep 19, 2020 12:22 pmPlease can you try it with the firestick?ragico wrote: Sat Sep 19, 2020 11:20 amIn the mp4 files I did not add subtitles so don't know if they are displayed in firestick.
If I use FEL -> MEL then the resulting file size is the same as without that conversion. Is that right?
Normally MEL EL-file sizes are much lower.
Parameter -mode 2 doesn't delete EL data. Getting not a file BL+RPU.hevc, only BL+EL+RPU.hevc with similar size.
I'm using profile 5 on Windows 10 using mp4muxer. Only this works.
Dell XPS 15 9500, cpu i7-10570H, Win10 Pro v2004,
Full HD 1920x1080 non-glare, HDR streaming enabled, Dolby Vision active
Didn't knew, ffmpeg could also extract the core ac3 from truehd.yusesope wrote: Sat Sep 19, 2020 8:39 amBut you didn't let us know if it works on LG or not.
A little tip: if you don't need to make cuts, you can extract video and audio with a single commandClearly replace "XXX" with the correct TrueHD (with ac3 core) audio stream idCode: Select all
ffmpeg.exe -i \path\to\file -map 0:0 -c copy \path\to\BL.hevc -map 0:1 -c copy \path\to\EL.hevc -map 0:XXX -bsf:a truehd_core -c:a copy \path\to\AUDIO.ac3
Thanks for that mate
Unfortunately the Gemini Man movie still lags very hard, like the TV has trouble decoding it somehow.
So it doesn't have anything to do with MEL or FEL.
I guess it simply cannot handle 60fps DV.
yes, MEL Single Track Double Layer made with your tool plays on the x700... but not the FEL ones and not the converted MEL ones.yusesope wrote: Sat Sep 19, 2020 11:37 am But normally, does the x700 play mp4 obtained with my tool (Single Track Double Layer)?
Fully agree with @RESET_999RESET_9999 wrote: Sat Sep 19, 2020 3:08 pmyes, MEL Single Track Double Layer made with your tool plays on the x700... but not the FEL ones and not the converted MEL ones.yusesope wrote: Sat Sep 19, 2020 11:37 am But normally, does the x700 play mp4 obtained with my tool (Single Track Double Layer)?
latest Tsmuxer nightly produces DV profile 7 from hevc files made with Yusesope tool.
Tested, didn’t have any problems with the .bat files with the added libraries. I used the MI6 bathroom scene that’s been floating around here (recut from my own disc). Seems to have worked fine.
I only have an LG cx and shield to test with at the moment. LG TV didn’t seem to like the file, not sure if that’s expected, I’ve never really tried that hard to get it to play files due to the audio limitations.
The shield played the file. I can’t tell if the colour issue is still there though, I was struggling to see the red push on both the MEL mp4 and the FEL mkv. I don’t think the intention of this experiment was to ‘fix’ any of that? This was more for other devices, e.g. firestick?
As I said mp4 files do not support pgs subtitles so there is no way, at moment, to know if they are supported in exoplayer/firestick. I think we must wait for Tsmuxer m2ts format played via exoplayer to test this functionality.
Well fukk me..
I've created four different versions of Gemini Man.
All with the same source files:
BL_EL_RPU.hevc (created with -mux -fel_to_mel as I described a few posts back)
Gemini.ac3 (the core ac3 5.1 audio taken from the Blu-ray disc)
Now I've muxed four versions with mp4muxer with only difference in --dv-profile being 4, 6, 7 (as recommended by yusesope) and 8.
Producing:
Profile 04:
Profile 06:
Profile 07:
Profile 08:
Now watch this:
https://streamable.com/4v5u4k
As you can see they all trigger DV.
But only the one being profile 08 (the last one) plays OK.
Why is that?
Perhaps profile 8 should be used for all Blu-ray DV rips then?
I'm going to try on Shield TV and also test all 4 of them with Emby client to see how well they play.
Producing:
Profile 04:
General
Complete name : test_dv4.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/dby1/isom)
File size : 68.9 GiB
Duration : 1 h 57 min
Overall bit rate : 84.3 Mb/s
Encoded date : UTC 2020-09-19 14:32:24
Tagged date : UTC 2020-09-19 14:32:24
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.04.09, BL+EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 83.7 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 (60000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.168
Stream size : 68.4 GiB (99%)
Default : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 5180 cd/m2
Maximum Frame-Average Light Level : 1577 cd/m2
Codec configuration box : hvcC+dvcC+hvcE
Audio
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : ac-3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 536 MiB (1%)
Language : English
Service kind : Complete Main
Default : No
Tagged date : UTC 2020-09-19 14:32:24Profile 06:
General
Complete name : test_dv6.mp4
Format : MPEG-4
Encoded date : UTC 2020-09-19 15:38:54
Tagged date : UTC 2020-09-19 15:38:54
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.06.09, BL+EL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Color space : YUV
Bit depth : 10 bits
Default : No
Audio
Format : AC-3
Codec ID : ac-3
Bit rate : 640 kb/s
Language : English
Default : No
Tagged date : UTC 2020-09-19 15:38:54Profile 07:
General
Complete name : test_dv7.mp4
Format : MPEG-4
Encoded date : UTC 2020-09-18 14:35:45
Tagged date : UTC 2020-09-18 14:35:45
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.09, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Color space : YUV
Bit depth : 10 bits
Default : No
Audio
Format : AC-3
Codec ID : ac-3
Bit rate : 640 kb/s
Language : emg
Default : No
Tagged date : UTC 2020-09-18 14:35:45Profile 08:
General
Complete name : test_dv8.mp4
Format : MPEG-4
Encoded date : UTC 2020-09-19 16:47:48
Tagged date : UTC 2020-09-19 16:47:48
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.09, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Color space : YUV
Bit depth : 10 bits
Default : No
Audio
Format : AC-3
Codec ID : ac-3
Bit rate : 640 kb/s
Language : English
Default : No
Tagged date : UTC 2020-09-19 16:47:48https://streamable.com/4v5u4k
Why is that?
Profile 8 is not supposed to have an EL according to Dolby specs. If whatever you're using for playback is following dolby standards, then it may just be ignoring the EL when it encounters a profile 8 video.MastaG wrote: Sat Sep 19, 2020 6:49 pm Well fukk me..
Producing:
Profile 04:Code: Select all
General Complete name : test_dv4.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (mp42/dby1/isom) File size : 68.9 GiB Duration : 1 h 57 min Overall bit rate : 84.3 Mb/s Encoded date : UTC 2020-09-19 14:32:24 Tagged date : UTC 2020-09-19 14:32:24 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.04.09, BL+EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible Codec ID : hev1 Codec ID/Info : High Efficiency Video Coding Duration : 1 h 57 min Bit rate : 83.7 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.168 Stream size : 68.4 GiB (99%) Default : No Encoded date : UTC 2020-09-19 14:32:24 Tagged date : UTC 2020-09-19 14:32:24 Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 5180 cd/m2 Maximum Frame-Average Light Level : 1577 cd/m2 Codec configuration box : hvcC+dvcC+hvcE Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : ac-3 Duration : 1 h 57 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 536 MiB (1%) Language : English Service kind : Complete Main Default : No Encoded date : UTC 2020-09-19 14:32:24 Tagged date : UTC 2020-09-19 14:32:24
Profile 06:Code: Select all
General Complete name : test_dv6.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (mp42/dby1/isom) File size : 68.9 GiB Duration : 1 h 57 min Overall bit rate : 84.3 Mb/s Encoded date : UTC 2020-09-19 15:38:54 Tagged date : UTC 2020-09-19 15:38:54 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.06.09, BL+EL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible Codec ID : hev1 Codec ID/Info : High Efficiency Video Coding Duration : 1 h 57 min Bit rate : 83.7 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.168 Stream size : 68.4 GiB (99%) Default : No Encoded date : UTC 2020-09-19 15:38:54 Tagged date : UTC 2020-09-19 15:38:54 Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 5180 cd/m2 Maximum Frame-Average Light Level : 1577 cd/m2 Codec configuration box : hvcC+dvcC+hvcE Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : ac-3 Duration : 1 h 57 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 536 MiB (1%) Language : English Service kind : Complete Main Default : No Encoded date : UTC 2020-09-19 15:38:54 Tagged date : UTC 2020-09-19 15:38:54
Profile 07:Code: Select all
General Complete name : test_dv7.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (mp42/dby1/isom) File size : 68.9 GiB Duration : 1 h 57 min Overall bit rate : 84.3 Mb/s Encoded date : UTC 2020-09-18 14:35:45 Tagged date : UTC 2020-09-18 14:35:45 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.09, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible Codec ID : hev1 Codec ID/Info : High Efficiency Video Coding Duration : 1 h 57 min Bit rate : 83.7 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.168 Stream size : 68.4 GiB (99%) Default : No Encoded date : UTC 2020-09-18 14:35:45 Tagged date : UTC 2020-09-18 14:35:45 Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 5180 cd/m2 Maximum Frame-Average Light Level : 1577 cd/m2 Codec configuration box : hvcC+dvcC+hvcE Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : ac-3 Duration : 1 h 57 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 536 MiB (1%) Language : emg Service kind : Complete Main Default : No Encoded date : UTC 2020-09-18 14:35:45 Tagged date : UTC 2020-09-18 14:35:45
Profile 08:Now watch this:Code: Select all
General Complete name : test_dv8.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (mp42/dby1/isom) File size : 68.9 GiB Duration : 1 h 57 min Overall bit rate : 84.3 Mb/s Encoded date : UTC 2020-09-19 16:47:48 Tagged date : UTC 2020-09-19 16:47:48 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.08.09, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible Codec ID : hev1 Codec ID/Info : High Efficiency Video Coding Duration : 1 h 57 min Bit rate : 83.7 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.168 Stream size : 68.4 GiB (99%) Default : No Encoded date : UTC 2020-09-19 16:47:48 Tagged date : UTC 2020-09-19 16:47:48 Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 5180 cd/m2 Maximum Frame-Average Light Level : 1577 cd/m2 Codec configuration box : hvcC+dvcC+hvcE Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : ac-3 Duration : 1 h 57 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 536 MiB (1%) Language : English Service kind : Complete Main Default : No Encoded date : UTC 2020-09-19 16:47:48 Tagged date : UTC 2020-09-19 16:47:48
Why is that?
That makes sense.. but they're virtually the same.shawnc22 wrote: Sat Sep 19, 2020 7:06 pm Profile 8 is not supposed to have an EL according to Dolby specs. If whatever you're using for playback is following dolby standards, then it may just be ignoring the EL when it encounters a profile 8 video.
I cannot spot any differences.
Also for a MEL movie what does the enhancement layer contain?
But firestick can play m2ts?ragico wrote: Sat Sep 19, 2020 4:49 pmAs I said mp4 files do not support pgs subtitles so there is no way, at moment, to know if they are supported in exoplayer/firestick. I think we must wait for Tsmuxer m2ts format played via exoplayer to test this functionality.
Edit: I read It can
If Tsmuxer add this, pls try .pgs subtitles
Thank you
That's not really true
Oppo can't playback single track dual layer files, but it can profile 5 single track single layer MEL files (BL+RPU, without EL).
So as someone just asked above: why don't you try to create BL+RPU instead of BL+EL+RPU?
RESET_9999 wrote: Sat Sep 19, 2020 3:08 pm yes, MEL Single Track Double Layer made with your tool plays on the x700... but not the FEL ones and not the converted MEL ones.
Third attempt guys!ragico wrote: Sat Sep 19, 2020 12:32 pm Thr m2ts file plays in sony x700 via usb.
Dolby vision is triggered a couple of seconds after the play starts.
There is some heavy flickering here and there.
Find the new file HERE.
Does it play on the FireStick and x700?
Thanks for your patience!
pitrako wrote: Sat Sep 19, 2020 10:00 am Profile 4 = It starts but lags until the image freezes.
Profile 5 = It plays correctly.
Profile 7 = Black screen, time does not advance.
Profile 8 id 1 = It plays correctly.
Profile 8 id 2 = It plays correctly.
fel_to_mel_test_2.mp4 (your test file)= Black screen, time does not advance.
No luck for me with profile 7.
Profile 5 and 8 are not good in this case! These are files with Enhancement Layer and profile 5/8 does not have this layer. In addition, the HW DV decoder uses different decoding modes depending on the profile!MastaG wrote: Sat Sep 19, 2020 6:49 pm
Why is that?
I have already answered HERE
My idea does not include any video encoding but only a modification of the RPU units. It is therefore normal that the size is the same.spezi wrote: Sat Sep 19, 2020 1:40 pm If I use FEL -> MEL then the resulting file size is the same as without that conversion. Is that right?
Don't worry, "-mode 2" works as it should. "BL+EL+RPU.hevc" is just a name like any other: if you use the command line you can assign it whatever name you like!
Profile 5 has a proprietary color space and it is not currently possible to convert a UHD-BD to Profile 5.chros wrote: Sun Sep 20, 2020 8:45 am So as someone just asked above: why don't you try to create BL+RPU instead of BL+EL+RPU?What's the reason behind this? Thanks
Yep.PlatypusW wrote: Sat Sep 19, 2020 4:14 pm I don’t think the intention of this experiment was to ‘fix’ any of that? This was more for other devices, e.g. firestick?
It is for those devices which are unable to play FEL movies
