hepe9
#3016 Post by hepe9 » Sat Sep 19, 2020 11:00 am
ragico wrote:
Sat Sep 19, 2020 10:49 am
@Yusesope
Your new file plays correctly in firestick, ugoos am6plus and shield.
In sony x700, via usb, it does not start and the counter stays at 000.
Thanks for the tests
The .pgs subtitles works with exoplayer and firestick?
@yusesope maybe this method never work with x700 because is an "official player" I don't know
ragico
#3017 Post by ragico » Sat Sep 19, 2020 11:20 am
@Yusesope
In the mp4 files I did not add subtitles so don't know if they are displayed in firestick.
In the DV Mkv played in shield/ugoos am6plus via kodi/exoplayer, the pgs subs work and are displayed correctly.
yusesope
#3018 Post by yusesope » Sat Sep 19, 2020 11:37 am
@Yusesope
But normally, does the x700 play mp4 obtained with my tool (Single Track Double Layer)?
Could you please try to extract the hevc video stream from this latter mp4 file, demux it using my "DEMUX.bat", import the two bl.hevc (as first) and el_rpu.hevc (as second) into TsMuxeR and create a m2ts file to try on the Sony?
Thank you!
But why? :?: :?: :?: :?: :?: :?:
I need to know to understand if I'm doing something wrong!
hepe9
#3019 Post by hepe9 » Sat Sep 19, 2020 12:22 pm
Please can you try it with the firestick?
@yusesope I don't know, is only a idea, I say that becouse it work on Android devides but no in X700
You're are the master here :wink:
ragico
#3020 Post by ragico » Sat Sep 19, 2020 12:32 pm
@Yusesope
Thank you!
Thr m2ts file plays in sony x700 via usb.
Dolby vision is triggered a couple of seconds after the play starts.
There is some heavy flickering here and there.
ragico
#3021 Post by ragico » Sat Sep 19, 2020 12:33 pm
Try what?
hepe9
#3022 Post by hepe9 » Sat Sep 19, 2020 12:39 pm
Try what?
If .pgs subtitles works with the firestick and exoplayer
spezi
#3023 Post by spezi » Sat Sep 19, 2020 1:40 pm
If I use FEL -> MEL then the resulting file size is the same as without that conversion. Is that right?
Normally MEL EL-file sizes are much lower.
Parameter -mode 2 doesn't delete EL data. Getting not a file BL+RPU.hevc, only BL+EL+RPU.hevc with similar size.
I'm using profile 5 on Windows 10 using mp4muxer. Only this works.
Dell XPS 15 9500, cpu i7-10570H, Win10 Pro v2004,
Full HD 1920x1080 non-glare, HDR streaming enabled, Dolby Vision active
MastaG
#3024 Post by MastaG » Sat Sep 19, 2020 2:17 pm
yusesope wrote:
Sat Sep 19, 2020 8:39 am
MastaG wrote:
Fri Sep 18, 2020 2:21 pm
EDIT: Done!
But you didn't let us know if it works on LG or not :lol: .
A little tip: if you don't need to make cuts, you can extract video and audio with a single command
ffmpeg.exe -i \path\to\file -map 0:0 -c copy \path\to\BL.hevc -map 0:1 -c copy \path\to\EL.hevc -map 0:XXX -bsf:a truehd_core -c:a copy \path\to\AUDIO.ac3
Clearly replace "XXX" with the correct TrueHD (with ac3 core) audio stream id
Didn't knew, ffmpeg could also extract the core ac3 from truehd.
Thanks for that mate :)
Unfortunately the Gemini Man movie still lags very hard, like the TV has trouble decoding it somehow.
So it doesn't have anything to do with MEL or FEL.
I guess it simply cannot handle 60fps DV.
#3025 Post by RESET_9999 » Sat Sep 19, 2020 3:08 pm
yes, MEL Single Track Double Layer made with your tool plays on the x700... but not the FEL ones and not the converted MEL ones.
ragico
#3026 Post by ragico » Sat Sep 19, 2020 4:02 pm
Fully agree with @RESET_999
ragico
#3027 Post by ragico » Sat Sep 19, 2020 4:04 pm
latest Tsmuxer nightly produces DV profile 7 from hevc files made with Yusesope tool.
PlatypusW
#3028 Post by PlatypusW » Sat Sep 19, 2020 4:14 pm
yusesope wrote:
Fri Sep 18, 2020 12:57 pm
PlatypusW wrote:
Thu Sep 17, 2020 9:48 pm
I’ll try and test over the weekend :D
Let us know!
Tested, didn’t have any problems with the .bat files with the added libraries. I used the MI6 bathroom scene that’s been floating around here (recut from my own disc). Seems to have worked fine.
I only have an LG cx and shield to test with at the moment. LG TV didn’t seem to like the file, not sure if that’s expected, I’ve never really tried that hard to get it to play files due to the audio limitations.
The shield played the file. I can’t tell if the colour issue is still there though, I was struggling to see the red push on both the MEL mp4 and the FEL mkv. I don’t think the intention of this experiment was to ‘fix’ any of that? This was more for other devices, e.g. firestick?
ragico
#3029 Post by ragico » Sat Sep 19, 2020 4:49 pm
Try what?
As I said mp4 files do not support pgs subtitles so there is no way, at moment, to know if they are supported in exoplayer/firestick. I think we must wait for Tsmuxer m2ts format played via exoplayer to test this functionality.
MastaG
#3030 Post by MastaG » Sat Sep 19, 2020 6:49 pm
Well fukk me..
I've created four different versions of Gemini Man.
All with the same source files:
BL_EL_RPU.hevc (created with -mux -fel_to_mel as I described a few posts back)
Gemini.ac3 (the core ac3 5.1 audio taken from the Blu-ray disc)
Now I've muxed four versions with mp4muxer with only difference in --dv-profile being 4, 6, 7 (as recommended by yusesope) and 8.
Producing:
Profile 04:
General
Complete name                            : test_dv4.mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/dby1/isom)
File size                                : 68.9 GiB
Duration                                 : 1 h 57 min
Overall bit rate                         : 84.3 Mb/s
Encoded date                             : UTC 2020-09-19 14:32:24
Tagged date                              : UTC 2020-09-19 14:32:24
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.04.09, BL+EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Bit rate                                 : 83.7 Mb/s
Frame rate                               : 59.940 (60000/1001) FPS
Bits/(Pixel*Frame)                       : 0.168
Stream size                              : 68.4 GiB (99%)
Mastering display luminance              : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 5180 cd/m2
Maximum Frame-Average Light Level        : 1577 cd/m2
Codec configuration box                  : hvcC+dvcC+hvcE
Audio
Codec ID                                 : ac-3
Stream size                              : 536 MiB (1%)
Profile 06:
General
Complete name                            : test_dv6.mp4
Encoded date                             : UTC 2020-09-19 15:38:54
Tagged date                              : UTC 2020-09-19 15:38:54
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.06.09, BL+EL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Audio
Codec ID                                 : ac-3
Profile 07:
General
Complete name                            : test_dv7.mp4
Encoded date                             : UTC 2020-09-18 14:35:45
Tagged date                              : UTC 2020-09-18 14:35:45
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.09, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Audio
Codec ID                                 : ac-3
Language                                 : emg
Profile 08:
General
Complete name                            : test_dv8.mp4
Encoded date                             : UTC 2020-09-19 16:47:48
Tagged date                              : UTC 2020-09-19 16:47:48
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.09, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Audio
Codec ID                                 : ac-3
Now watch this:
https://streamable.com/4v5u4k
As you can see they all trigger DV.
But only the one being profile 08 (the last one) plays OK.
Why is that?
Perhaps profile 8 should be used for all Blu-ray DV rips then?
I'm going to try on Shield TV and also test all 4 of them with Emby client to see how well they play.
