PapitaHD
Post by PapitaHD » Sat Sep 19, 2020 9:16 am
This is a second attempt based on a slightly different idea from the previous one.
Does THIS FILE play on both FireStick 4K and Sony/Zidoo Z9X?
Thank you!
Unfortunately it still doesn't play on M9702 (Oppo 203 clone). I've also tried several titles, using the new beta version of your tool and my LG C8 plays all of them but for some reason, the ChinOppo doesn't.
yusesope
Post by yusesope » Sat Sep 19, 2020 9:17 am
Meister_Proper wrote: Sat Sep 19, 2020 8:48 am This one triggers DV :)
Ok :)
hepe9 wrote: Sat Sep 19, 2020 8:57 am @RESET_9999 we need you, I hope now works in the x700
We hope it works for @RESET_9999 too, but the most important response is that of @ragico.
If the file doesn't play on the FireStick, we're at the same point as before!
PapitaHD wrote: Sat Sep 19, 2020 9:16 am Unfortunately it still doesn't play on M9702 (Oppo 203 clone). I've also tried several titles, using the new beta version of your tool and my LG C8 plays all of them but for some reason, the ChinOppo doesn't.
One device at a time :D !
Don't worry: your M9702 doesn't need a "conversion" FEL -> MEL.
hepe9
Post by hepe9 » Sat Sep 19, 2020 9:38 am
yusesope wrote: Sat Sep 19, 2020 9:17 am We hope it works for @RESET_9999 too, but the most important response is that of @ragico.
Fingers crossed
pitrako
Post by pitrako » Sat Sep 19, 2020 10:00 am
yusesope wrote: Sat Sep 19, 2020 8:39 am
RESET_9999 wrote: Fri Sep 18, 2020 4:49 pm Unfortunately, those converted MEL files dont play on my x700 ...
ragico wrote: Fri Sep 18, 2020 5:06 pm Yes, these converted Mel files dont play on my x700 too. So I plugged my firestick into the Pana to compare them with the discs played on the x700.
Meister_Proper wrote: Sat Sep 19, 2020 7:57 am The GIJoe P7 MEL triggers DV on the Zidoo Z9X, but your FEL to MEL plays in HDR10 only.
Thanks for your valuable tests!
The fact that devices like the FireStick 4K have no problems playing this type of file encourages me but the issue of the Sony x700/Zidoo Z9X leaves me a bit of a bad taste.
Thank you!
Clearly, the test is also extended to owners of different devices (obviously interested in the FEL -> MEL).
In your posts please also specify the device.
MastaG wrote: Fri Sep 18, 2020 2:21 pm EDIT: Done!
But you didn't let us know if it works on LG or not :lol: .
A little tip: if you don't need to make cuts, you can extract video and audio with a single command
ffmpeg.exe -i \path\to\file -map 0:0 -c copy \path\to\BL.hevc -map 0:1 -c copy \path\to\EL.hevc -map 0:XXX -bsf:a truehd_core -c:a copy \path\to\AUDIO.ac3
Clearly replace "XXX" with the correct TrueHD (with ac3 core) audio stream id
I tested again on my PUS7304 with your FEL to MEL (1917 movie), but this time all profiles 4, 5, 7, 8 with id 1 and 8 with id 2 in exoplayer and yout latest test file, these are the results:
Profile 4 = It starts but lags until the image freezes.
Profile 5 = It plays correctly.
Profile 7 = Black screen, time does not advance.
Profile 8 id 1 = It plays correctly.
Profile 8 id 2 = It plays correctly.
fel_to_mel_test_2.mp4 (your test file)= Black screen, time does not advance.
No luck for me with profile 7 :( .
iamTa
Post by iamTa » Sat Sep 19, 2020 10:17 am
Is there any way to combine a TrueHD track with a converted FEL to MEL or do we need to wait for the tsMuxeR update?
Looks like tsMuxeR 2.6.16 Nightly has a few DV updates.
Bobr.BY
Post by Bobr.BY » Sat Sep 19, 2020 10:41 am
to
yusesope
ExoPlayer v2.12.0 (2020-09-11)
https://github.com/google/ExoPlayer/blo ... 2020-09-11
Extractors:Matroska:Support Dolby Vision (#7267).
Pls make (compilation) new version ExoPlayer
ragico
Post by ragico » Sat Sep 19, 2020 10:49 am
@Yusesope
Your new file plays correctly in firestick, ugoos am6plus and shield.
In sony x700, via usb, it does not start and the counter stays at 000.
hepe9
Post by hepe9 » Sat Sep 19, 2020 11:00 am
ragico wrote: Sat Sep 19, 2020 10:49 am @Yusesope
Thanks for the tests
The .pgs subtitles works with exoplayer and firestick?
@yusesope maybe this method never work with x700 because is an "official player" I don't know
ragico
Post by ragico » Sat Sep 19, 2020 11:20 am
hepe9 wrote: Sat Sep 19, 2020 11:00 am
In the mp4 files I did not add subtitles so don't know if they are displayed in firestick.
In the DV Mkv played in shield/ugoos am6plus via kodi/exoplayer, the pgs subs work and are displayed correctly.
yusesope
Post by yusesope » Sat Sep 19, 2020 11:37 am
But normally, does the x700 play mp4 obtained with my tool (Single Track Double Layer)?
Could you please try to extract the hevc video stream from this latter mp4 file, demux it using my "DEMUX.bat", import the two bl.hevc (as first) and el_rpu.hevc (as second) into TsMuxeR and create a m2ts file to try on the Sony?
Thank you!
hepe9 wrote: Sat Sep 19, 2020 11:00 am @yusesope maybe this method never work with x700 because is an "official player" I don't know
But why? :?: :?: :?: :?: :?: :?:
I need to know to understand if I'm doing something wrong!
hepe9
Post by hepe9 » Sat Sep 19, 2020 12:22 pm
ragico wrote: Sat Sep 19, 2020 11:20 amIn the mp4 files I did not add subtitles so don't know if they are displayed in firestick.
Please can you try it with the firestick?
@yusesope I don't know, is only a idea, I say that becouse it work on Android devides but no in X700
You're are the master here :wink:
ragico
Post by ragico » Sat Sep 19, 2020 12:32 pm
yusesope wrote: Sat Sep 19, 2020 11:37 am
Thank you!
Thr m2ts file plays in sony x700 via usb.
Dolby vision is triggered a couple of seconds after the play starts.
There is some heavy flickering here and there.
ragico
Post by ragico » Sat Sep 19, 2020 12:33 pm
hepe9 wrote: Sat Sep 19, 2020 12:22 pm
Try what?
hepe9
Post by hepe9 » Sat Sep 19, 2020 12:39 pm
ragico wrote: Sat Sep 19, 2020 12:33 pm
Try what?
If .pgs subtitles works with the firestick and exoplayer
spezi
Post by spezi » Sat Sep 19, 2020 1:40 pm
If I use FEL -> MEL then the resulting file size is the same as without that conversion. Is that right?
Normally MEL EL-file sizes are much lower.
Parameter -mode 2 doesn't delete EL data. Getting not a file BL+RPU.hevc, only BL+EL+RPU.hevc with similar size.
I'm using profile 5 on Windows 10 using mp4muxer. Only this works.
Dell XPS 15 9500, cpu i7-10570H, Win10 Pro v2004,
Full HD 1920x1080 non-glare, HDR streaming enabled, Dolby Vision active
