Wait, how is my television the limiting factor ? And then you say I need to use a different media player. Which is it ?chrisandy wrote: Fri Sep 18, 2020 5:35 amWon't work on LG. Have to use a Shield with the custom exoplayer found in this forum/annisman wrote: Fri Sep 18, 2020 2:15 am So is DV working with MKV rips now ?
This is my current playback method and haven't seen DV get triggered by my LG CX on any recent DV MKV rips:
HTPC . Emby . MadVR . MPC-BE.
Explain it to me like I'm five. What I gotta do?
Dolby Vision and 1.15.1
annisman
Re: Dolby Vision and 1.15.1
ragico
Once you have downloaded the app from the link I have posted, you should sideload it in the shield. If you have another emby version already installed, pls uninstall it first. Then make sure that the emby server is the latest beta version 4.5.0.29argo44 wrote: Fri Sep 18, 2020 1:23 pmIf anyone can expand on this I would appreciate it. I still can't get DV to trigger with the latest Emby beta. I have re-ripped my file with the latest MakeMKV and no go. Help appreciated.ragico wrote: Wed Sep 16, 2020 5:12 pm Latest Emby beta app for android is capable to play DV Mkv on both shield and ugoos am6 plus even with some problems.
Here; https://emby.media/community/index.php? ... 4-testing/
DV mkv play and dolby vision is triggered in this beta app. The main problem is that, after 2/3 minutes, suddenly the player stops without any apparent reason.
This happens with almost all the mkv files.
argo44
Thank you Ragico. I totally didn't know I had to be running a beta serverragico wrote: Fri Sep 18, 2020 3:29 pmOnce you have downloaded the app from the link I have posted, you should sideload it in the shield. If you have another emby version already installed, pls uninstall it first. Then make sure that the emby server is the latest beta version 4.5.0.29argo44 wrote: Fri Sep 18, 2020 1:23 pmIf anyone can expand on this I would appreciate it. I still can't get DV to trigger with the latest Emby beta. I have re-ripped my file with the latest MakeMKV and no go. Help appreciated.ragico wrote: Wed Sep 16, 2020 5:12 pm Latest Emby beta app for android is capable to play DV Mkv on both shield and ugoos am6 plus even with some problems.
Bob1321
argo44 wrote: Fri Sep 18, 2020 3:53 pmThank you Ragico. I totally didn't know I had to be running a beta serverragico wrote: Fri Sep 18, 2020 3:29 pmOnce you have downloaded the app from the link I have posted, you should sideload it in the shield. If you have another emby version already installed, pls uninstall it first. Then make sure that the emby server is the latest beta version 4.5.0.29argo44 wrote: Fri Sep 18, 2020 1:23 pm
This happens with almost all the mkv files.I will load that on another machine and give it a go and post back. Thanks!
Hello, I install this app to my Firestick 4K. When I start a Dolby Vision movie, the screen is black but I have the sound and I have the Dolby Vision notification on my TV.
I dont have problem with HDR movies
What I can do?
ragico
Nothing. The firestick plays correctly only the DV Mel.Bob1321 wrote: Fri Sep 18, 2020 6:12 pmargo44 wrote: Fri Sep 18, 2020 3:53 pmThank you Ragico. I totally didn't know I had to be running a beta serverragico wrote: Fri Sep 18, 2020 3:29 pm
What I can do?
If the DV is Fel you get sound and DV triggers on the screen but it remains black.
In this post viewtopic.php?f=12&t=18602&start=2970 Yusesope is giving us a program to "convert" Fel movies to Mel movies and in this way you can watch them correctly on the Firestick.
argo44
Just reporting back. Setup a beta server and used playback with Exoplayer and DV does not trigger. Only HDR10. If someone could post the correct Exoplayer link for confirmation that would be great. Thanks.argo44 wrote: Fri Sep 18, 2020 3:53 pmThank you Ragico. I totally didn't know I had to be running a beta serverragico wrote: Fri Sep 18, 2020 3:29 pmOnce you have downloaded the app from the link I have posted, you should sideload it in the shield. If you have another emby version already installed, pls uninstall it first. Then make sure that the emby server is the latest beta version 4.5.0.29argo44 wrote: Fri Sep 18, 2020 1:23 pm
gabi.gegea@gmail.com
Your files nedd to be single video channel(only video1), not Video1 hdr and video2 dolby vision!argo44 wrote: Fri Sep 18, 2020 8:35 pmJust reporting back. Setup a beta server and used playback with Exoplayer and DV does not trigger. Only HDR10. If someone could post the correct Exoplayer link for confirmation that would be great. Thanks.argo44 wrote: Fri Sep 18, 2020 3:53 pmThank you Ragico. I totally didn't know I had to be running a beta serverragico wrote: Fri Sep 18, 2020 3:29 pm
argo44
Alrighty that sounds wonderful! Now, what does that mean and how do I do that? Preeeeesh.gabi.gegea@gmail.com wrote: Fri Sep 18, 2020 9:42 pmYour files nedd to be single video channel(only video1), not Video1 hdr and video2 dolby vision!argo44 wrote: Fri Sep 18, 2020 8:35 pmJust reporting back. Setup a beta server and used playback with Exoplayer and DV does not trigger. Only HDR10. If someone could post the correct Exoplayer link for confirmation that would be great. Thanks.argo44 wrote: Fri Sep 18, 2020 3:53 pm
Thank you Ragico. I totally didn't know I had to be running a beta serverI will load that on another machine and give it a go and post back. Thanks!
argo44 wrote: Fri Sep 18, 2020 10:35 pmAlrighty that sounds wonderful! Now, what does that mean and how do I do that? Preeeeesh.gabi.gegea@gmail.com wrote: Fri Sep 18, 2020 9:42 pmYour files nedd to be single video channel(only video1), not Video1 hdr and video2 dolby vision!argo44 wrote: Fri Sep 18, 2020 8:35 pm
argo44
Haha. I love it. Totally get the response. I'll have to go fishing if no one wants to help haha. I don't torrent though.gabi.gegea@gmail.com wrote: Fri Sep 18, 2020 11:10 pmargo44 wrote: Fri Sep 18, 2020 10:35 pmAlrighty that sounds wonderful! Now, what does that mean and how do I do that? Preeeeesh.gabi.gegea@gmail.com wrote: Fri Sep 18, 2020 9:42 pm
Your files nedd to be single video channel(only video1), not Video1 hdr and video2 dolby vision!)) You start learning how to extract the video channel and convert your files or go torrenting.
It won't work from an HTPC or the internal LG TV player. You need a dedicated streaming box like the Shield.annisman wrote: Fri Sep 18, 2020 2:46 pmWait, how is my television the limiting factor ? And then you say I need to use a different media player. Which is it ?chrisandy wrote: Fri Sep 18, 2020 5:35 amWon't work on LG. Have to use a Shield with the custom exoplayer found in this forum/annisman wrote: Fri Sep 18, 2020 2:15 am So is DV working with MKV rips now ?
Sorry, my knowledge in the field is not enough to empower me to advise you. But there is a lot of info out there and a few tools that will actually do all the job for you.argo44 wrote: Fri Sep 18, 2020 11:19 pmHaha. I love it. Totally get the response. I'll have to go fishing if no one wants to help haha. I don't torrent though.gabi.gegea@gmail.com wrote: Fri Sep 18, 2020 11:10 pmargo44 wrote: Fri Sep 18, 2020 10:35 pm
Alrighty that sounds wonderful! Now, what does that mean and how do I do that? Preeeeesh.)) You start learning how to extract the video channel and convert your files or go torrenting.
What format are the files you are playing on shield and not getting DV?
Epedemic
Or you could read the thread. All the info you need is there. If that is too complicated, i suggest you wait until things are on a simple enough level.argo44 wrote: Fri Sep 18, 2020 11:19 pmHaha. I love it. Totally get the response. I'll have to go fishing if no one wants to help haha. I don't torrent though.
ragico
You must use the emby beta app sideloaded to play not exoplayer.argo44 wrote: Fri Sep 18, 2020 8:35 pmJust reporting back. Setup a beta server and used playback with Exoplayer and DV does not trigger. Only HDR10. If someone could post the correct Exoplayer link for confirmation that would be great. Thanks.argo44 wrote: Fri Sep 18, 2020 3:53 pmThank you Ragico. I totally didn't know I had to be running a beta serverragico wrote: Fri Sep 18, 2020 3:29 pm
Mr_Orange
This is my tactic. I'm reading the thread as it develops but I cannot be bothered with the faffing around so am just waiting until official support comes to Plex.Epedemic wrote: Sat Sep 19, 2020 3:42 pmOr you could read the thread. All the info you need is there. If that is too complicated, i suggest you wait until things are on a simple enough level.
