ragico
Post by ragico »
I did my second complete movie: Us
This is really a challenge for a dolby vision chain. Until today only the original disc, played in the sony x700, was really correct to my eyes. I did not like the mkv version played trough the shield because of something wrong here and there with the colours.
Then I have watched the most critical scenes of this mp4 via firestick comparing it to that of the sony ( both devices almost syncronized) and could not detect any difference between the 2. Then I compared Despicable me 3 in the same way with same results. I have not a camera to take screenshot foto just my phone. I wait for comments from others as @RESET_999.
Maestro Yusesope. BRAVO.
yusesope wrote:
Fri Sep 18, 2020 12:57 pm
I'm curious! You could also call @RESET_9999 and take some pictures together :lol: :lol: :lol: :lol: :lol: !
ragico wrote:
Fri Sep 18, 2020 2:59 pm
Unfortunately, those converted MEL files dont play on my x700 so I can't properly compare them with the original. And the shield cannot output proper colors for ANY file that contains an EL and i dont have any other device to test.. :(
the native single layer MEL (el+RPU) movies play fines but not the converted one.
hepe9
Post by hepe9 »
RESET_9999 wrote:
Fri Sep 18, 2020 4:49 pm
I hope other can do the comparative, because if work, it's the great deal
ragico
Post by ragico »
Yes, these converted Mel files dont play on my x700 too. So I plugged my firestick into the Pana to compare them with the discs played on the x700.
hepe9
Post by hepe9 »
@ragico one question, the Firestick works good with .pgs subtitles in the Exoplayer?
Meister_Proper
Post by Meister_Proper »
yusesope wrote:
Thu Sep 17, 2020 2:59 pm
This latest innovation together with the previous idea of ​​combining the two layers (BL and EL_RPU) in a single track, should guarantee the possibility of playing any FEL UHD-BD backup on Android devices equipped with a Dolby Vision decoder and capable of playing THIS file (+ my ExoPlayer) or THIS file.
The GIJoe P7 MEL triggers DV on the Zidoo Z9X, but your FEL to MEL plays in HDR10 only.
yusesope
Post by yusesope »
Unfortunately, those converted MEL files dont play on my x700 ...
ragico wrote:
Fri Sep 18, 2020 5:06 pm
Meister_Proper wrote:
Sat Sep 19, 2020 7:57 am
Thanks for your valuable tests!
The fact that devices like the FireStick 4K have no problems playing this type of file encourages me but the issue of the Sony x700/Zidoo Z9X leaves me a bit of a bad taste.
This is a second attempt based on a slightly different idea from the previous one.
Does THIS FILE play on both FireStick 4K and Sony/Zidoo Z9X?
Thank you!
Clearly, the test is also extended to owners of different devices (obviously interested in the FEL -> MEL).
In your posts please also specify the device.
MastaG wrote:
Fri Sep 18, 2020 2:21 pm
EDIT: Done!
But you didn't let us know if it works on LG or not :lol: .
A little tip: if you don't need to make cuts, you can extract video and audio with a single command
ffmpeg.exe -i \path\to\file -map 0:0 -c copy \path\to\BL.hevc -map 0:1 -c copy \path\to\EL.hevc -map 0:XXX -bsf:a truehd_core -c:a copy \path\to\AUDIO.ac3
Clearly replace "XXX" with the correct TrueHD (with ac3 core) audio stream id
Meister_Proper
yusesope wrote:
Sat Sep 19, 2020 8:39 am
Thank you!
Thank you for all your work make!
This one triggers DV :)
hepe9
Post by hepe9 »
@RESET_9999 we need you, I hope now works in the x700
@yusesope you're amazing
PapitaHD
Post by PapitaHD »
Thank you!
Unfortunately it still doesn't play on M9702 (Oppo 203 clone). I've also tried several titles, using the new beta version of your tool and my LG C8 plays all of them but for some reason, the ChinOppo doesn't.
yusesope
Post by yusesope »
Sat Sep 19, 2020 8:48 am
Ok :)
hepe9 wrote:
Sat Sep 19, 2020 8:57 am
We hope it works for @RESET_9999 too, but the most important response is that of @ragico.
If the file doesn't play on the FireStick, we're at the same point as before!
PapitaHD wrote:
Sat Sep 19, 2020 9:16 am
One device at a time :D !
Don't worry: your M9702 doesn't need a "conversion" FEL -> MEL.
hepe9
Post by hepe9 »
yusesope wrote:
Sat Sep 19, 2020 9:17 am
Fingers crossed
pitrako
Post by pitrako »
Thank you!
EDIT: Done!
I tested again on my PUS7304 with your FEL to MEL (1917 movie), but this time all profiles 4, 5, 7, 8 with id 1 and 8 with id 2 in exoplayer and yout latest test file, these are the results:
Profile 4 = It starts but lags until the image freezes.
Profile 5 = It plays correctly.
Profile 7 = Black screen, time does not advance.
Profile 8 id 1 = It plays correctly.
Profile 8 id 2 = It plays correctly.
fel_to_mel_test_2.mp4 (your test file)= Black screen, time does not advance.
No luck for me with profile 7 :( .
iamTa
Post by iamTa »
Is there any way to combine a TrueHD track with a converted FEL to MEL or do we need to wait for the tsMuxeR update?
Looks like tsMuxeR 2.6.16 Nightly has a few DV updates.
Bobr.BY
Post by Bobr.BY »
to
yusesope
ExoPlayer v2.12.0 (2020-09-11)
https://github.com/google/ExoPlayer/blo ... 2020-09-11
Extractors:Matroska:Support Dolby Vision (#7267).
Pls make (compilation) new version ExoPlayer
