Yeah you're right, the mp4muxer_64bits binary also seems to work on Fedora 33 (beta).yusesope wrote: ↑Fri Sep 18, 2020 1:56 pmTry and let us know!MastaG wrote: ↑Fri Sep 18, 2020 1:31 pmSo for playback on LG (C8 in my case), some FEL movies like 1917 and Gemini Man would always give heavily stutter (both from USB HDD and Network)
Would converting them from FEL -> MEL fix this issue?
Also would you happen to have a diff file for mp4muxer so I can build on Linux ?
I don't have it but there is an x64 version in the archive that I used on Ubuntu.
For the record, I've demuxed the bluray iso file of Gemini Man:
ffmpeg -i bluray:///home/mastag/Video\'s/GeminiManISO -map 0:0 -c copy BL.hevc
ffmpeg -i bluray:///home/mastag/Video\'s/GeminiManISO -map 0:1 -c copy EL.hevc
Now I'm muxing it with your tool with conversion to MEL:
python src/app.py -mux -fel_to_mel -bl BL.hevc -el EL.hevc -of BL_EL_RPU.hevc
When it's done I'll use your mp4muxer_64bits binary to mux the BL_EL_RPU.hevc and the ac3 audio which I got from txMuxer into a single mp4 file.
I'll let you know!
Thanks for everything bro!
EDIT: Done!
mp4muxer -i BL_EL_RPU.hevc --dv-profile 7 -i 00222.track_4352.ac3 --media-lang eng -o Gemini_Man_2019.mp4
General
Complete name : Gemini_Man_2019.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/dby1/isom)
File size : 68.9 GiB
Duration : 1 h 57 min
Overall bit rate : 84.3 Mb/s
Encoded date : UTC 2020-09-18 14:35:45
Tagged date : UTC 2020-09-18 14:35:45
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.09, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 83.7 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 (60000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.168
Stream size : 68.4 GiB (99%)
Default : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 5180 cd/m2
Maximum Frame-Average Light Level : 1577 cd/m2
Codec configuration box : hvcC+dvcC+hvcE
Audio
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : ac-3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 536 MiB (1%)
Language : eng
Service kind : Complete Main
Default : No
