pitrako
#2986 Post by pitrako » Fri Sep 18, 2020 10:34 am
At the end I muxed with tsmuxer profile 8 fix into .ts instead of mp4muxer and dolby vision worked on the native tv player (does not triggers dolby vision in exoplayer) but I get strong red colors on people's skin, too much.
EDIT: I tried again all the steps from yusesope but instead I used -mode 2 instead of default mode on his tool and this time It triggered dolby vision on exoplayer. All this on 1917 (FEL title).
yusesope
#2987 Post by yusesope » Fri Sep 18, 2020 12:57 pm
hepe9 wrote: Thu Sep 17, 2020 6:08 pm This has changed?
I hope so
PlatypusW wrote: Thu Sep 17, 2020 9:48 pm I’ll try and test over the weekend :D
Let us know! If you are using Windows, please read the central part of THIS post!
PlatypusW wrote: Thu Sep 17, 2020 9:48 pm I presume that this isn’t something that could be done ‘on the fly’ at some point? We would need to change the makemkv MKVs to these MP4s each time? I.e. wouldn’t be able to just play the FEL mkv using exoplayer.
I wrote everything in C++, you could run my code on a toaster! The problem is the implementation: a good programmer would take a few hours ... I need my time. The idea of ​​integrating everything into ExoP has been in my head for a while but I still don't know if I have the skills to do it! I'll try it in my free time when I feel like it!
However don't worry: mp4muxer should only be used in these test days. As soon as @jcdr428 updates TsMuxeR (in order to get profile 7 files), you can start using it as it is much faster than the first one and allows you to create files with TrueHD/ATMOS audio included!
pitrako wrote: Thu Sep 17, 2020 6:33 pm I tried "A quiet place", It's a FEL title, in exoplayer through kodi and doesn't play, It stays at 00:00. And I think I followed all the steps...
Did you also follow the first important step?
yusesope wrote: Thu Sep 17, 2020 2:59 pm ......playing any FEL UHD-BD backup on Android devices equipped with a Dolby Vision decoder and capable of playing THIS file (+ my ExoPlayer) or THIS file....
Is your device capable of playing these files (the first only through ExoP)?
If the answer is no, unfortunately there is nothing I can do! However (and this also applies to @hepe9), take the positive aspect: if all goes well with a 40-60€ FireStick 4K you can play UHD-BD backups as MEL without giving up ultra-high resolution audio (PCM in most cases). I think this is good news! No?
pitrako wrote: Fri Sep 18, 2020 10:34 am EDIT: I tried again all the steps from yusesope but instead I used -mode 2 instead of default mode on his tool and this time It triggered dolby vision on exoplayer. All this on 1917 (FEL title).
This is interesting ... But unfortunately I don't think it is the correct way to proceed!
ragico wrote: Thu Sep 17, 2020 10:12 pm In next days I will compare it with the original disc played on sony x700 feeding a Panasonic GZ2000 oled.
I'm curious! You could also call @RESET_9999 and take some pictures together :lol: :lol: :lol: :lol: :lol: !
jcdr428 wrote: Fri Sep 18, 2020 9:28 am I will get it corrected in tsMuxer.
Thank you for your time!
MastaG
#2988 Post by MastaG » Fri Sep 18, 2020 1:31 pm
So for playback on LG (C8 in my case), some FEL movies like 1917 and Gemini Man would always give heavily stutter (both from USB HDD and Network)
Would converting them from FEL -> MEL fix this issue?
yusesope wrote: Thu Sep 17, 2020 2:59 pm ... and this version of mp4muxer. Before testing an entire film I advise you to work with 120 second cuts.
Also would you happen to have a diff file for mp4muxer so I can build on Linux ?
yusesope
#2989 Post by yusesope » Fri Sep 18, 2020 1:56 pm
MastaG wrote: Fri Sep 18, 2020 1:31 pm So for playback on LG (C8 in my case), some FEL movies like 1917 and Gemini Man would always give heavily stutter (both from USB HDD and Network)
Try and let us know!
I don't have it but there is an x64 version in the archive that I used on Ubuntu.
hepe9
#2990 Post by hepe9 » Fri Sep 18, 2020 2:02 pm
yusesope wrote: Fri Sep 18, 2020 12:57 pm if all goes well with a 40-60€ FireStick 4K you can play UHD-BD backups as MEL without giving up ultra-high resolution audio (PCM in most cases). I think this is good news! No?
Absolutely yes, very good news
I can't wait for comparatives :wink:
MastaG
#2991 Post by MastaG » Fri Sep 18, 2020 2:21 pm
yusesope wrote: Fri Sep 18, 2020 1:56 pm
Yeah you're right, the mp4muxer_64bits binary also seems to work on Fedora 33 (beta).
For the record, I've demuxed the bluray iso file of Gemini Man:
ffmpeg -i bluray:///home/mastag/Video\'s/GeminiManISO -map 0:0 -c copy BL.hevc
ffmpeg -i bluray:///home/mastag/Video\'s/GeminiManISO -map 0:1 -c copy EL.hevc
Then I used tsMuxerGui to demux the truehd track and downconvert it to (core) ac3.
Now I'm muxing it with your tool with conversion to MEL:
python src/app.py -mux -fel_to_mel -bl BL.hevc -el EL.hevc -of BL_EL_RPU.hevc
it takes a while.. 58% now..
When it's done I'll use your mp4muxer_64bits binary to mux the BL_EL_RPU.hevc and the ac3 audio which I got from txMuxer into a single mp4 file.
I'll let you know!
Thanks for everything bro!
EDIT: Done!
mp4muxer -i BL_EL_RPU.hevc --dv-profile 7 -i 00222.track_4352.ac3 --media-lang eng -o Gemini_Man_2019.mp4
Info:
General
Complete name                            : Gemini_Man_2019.mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/dby1/isom)
File size                                : 68.9 GiB
Duration                                 : 1 h 57 min
Overall bit rate                         : 84.3 Mb/s
Encoded date                             : UTC 2020-09-18 14:35:45
Tagged date                              : UTC 2020-09-18 14:35:45
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.09, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Bit rate                                 : 83.7 Mb/s
Frame rate                               : 59.940 (60000/1001) FPS
Bits/(Pixel*Frame)                       : 0.168
Stream size                              : 68.4 GiB (99%)
Mastering display luminance              : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 5180 cd/m2
Maximum Frame-Average Light Level        : 1577 cd/m2
Codec configuration box                  : hvcC+dvcC+hvcE
Audio
Codec ID                                 : ac-3
Stream size                              : 536 MiB (1%)
Language                                 : eng
ragico
#2992 Post by ragico » Fri Sep 18, 2020 2:59 pm
I did my second complete movie: Us
This is really a challenge for a dolby vision chain. Until today only the original disc, played in the sony x700, was really correct to my eyes. I did not like the mkv version played trough the shield because of something wrong here and there with the colours.
Then I have watched the most critical scenes of this mp4 via firestick comparing it to that of the sony ( both devices almost syncronized) and could not detect any difference between the 2. Then I compared Despicable me 3 in the same way with same results. I have not a camera to take screenshot foto just my phone. I wait for comments from others as @RESET_999.
Maestro Yusesope. BRAVO.
#2993 Post by RESET_9999 » Fri Sep 18, 2020 4:49 pm
yusesope wrote: Fri Sep 18, 2020 12:57 pm I'm curious! You could also call @RESET_9999 and take some pictures together :lol: :lol: :lol: :lol: :lol: !
ragico wrote: Fri Sep 18, 2020 2:59 pm I have not a camera to take screenshot foto just my phone. I wait for comments from others as @RESET_999.
Unfortunately, those converted MEL files dont play on my x700 so I can't properly compare them with the original. And the shield cannot output proper colors for ANY file that contains an EL and i dont have any other device to test.. :(
the native single layer MEL (el+RPU) movies play fines but not the converted one.
hepe9
#2994 Post by hepe9 » Fri Sep 18, 2020 5:00 pm
RESET_9999 wrote: Fri Sep 18, 2020 4:49 pm
I hope other can do the comparative, because if work, it's the great deal
ragico
#2995 Post by ragico » Fri Sep 18, 2020 5:06 pm
Yes, these converted Mel files dont play on my x700 too. So I plugged my firestick into the Pana to compare them with the discs played on the x700.
hepe9
#2996 Post by hepe9 » Fri Sep 18, 2020 9:03 pm
@ragico one question, the Firestick works good with .pgs subtitles in the Exoplayer?
Meister_Proper
#2997 Post by Meister_Proper » Sat Sep 19, 2020 7:57 am
yusesope wrote: Thu Sep 17, 2020 2:59 pm This latest innovation together with the previous idea of ​​combining the two layers (BL and EL_RPU) in a single track, should guarantee the possibility of playing any FEL UHD-BD backup on Android devices equipped with a Dolby Vision decoder and capable of playing THIS file (+ my ExoPlayer) or THIS file.
The GIJoe P7 MEL triggers DV on the Zidoo Z9X, but your FEL to MEL plays in HDR10 only.
yusesope
#2998 Post by yusesope » Sat Sep 19, 2020 8:39 am
RESET_9999 wrote: Fri Sep 18, 2020 4:49 pm Unfortunately, those converted MEL files dont play on my x700 ...
ragico wrote: Fri Sep 18, 2020 5:06 pm Yes, these converted Mel files dont play on my x700 too. So I plugged my firestick into the Pana to compare them with the discs played on the x700.
Meister_Proper wrote: Sat Sep 19, 2020 7:57 am The GIJoe P7 MEL triggers DV on the Zidoo Z9X, but your FEL to MEL plays in HDR10 only.
Thanks for your valuable tests!
The fact that devices like the FireStick 4K have no problems playing this type of file encourages me but the issue of the Sony x700/Zidoo Z9X leaves me a bit of a bad taste.
This is a second attempt based on a slightly different idea from the previous one.
Does THIS FILE play on both FireStick 4K and Sony/Zidoo Z9X?
Thank you!
Clearly, the test is also extended to owners of different devices (obviously interested in the FEL -> MEL).
In your posts please also specify the device.
MastaG wrote: Fri Sep 18, 2020 2:21 pm EDIT: Done!
But you didn't let us know if it works on LG or not :lol: .
A little tip: if you don't need to make cuts, you can extract video and audio with a single command
ffmpeg.exe -i \path\to\file -map 0:0 -c copy \path\to\BL.hevc -map 0:1 -c copy \path\to\EL.hevc -map 0:XXX -bsf:a truehd_core -c:a copy \path\to\AUDIO.ac3
Clearly replace "XXX" with the correct TrueHD (with ac3 core) audio stream id
Meister_Proper
#2999 Post by Meister_Proper » Sat Sep 19, 2020 8:48 am
yusesope wrote: Sat Sep 19, 2020 8:39 am Thanks for your valuable tests!
Thank you!
Thank you for all your work make!
This one triggers DV :)
hepe9
#3000 Post by hepe9 » Sat Sep 19, 2020 8:57 am
@RESET_9999 we need you, I hope now works in the x700
@yusesope you're amazing
