jcdr428
#2971 Post by jcdr428 » Thu Sep 17, 2020 5:12 pm
yusesope wrote: Thu Sep 17, 2020 2:59 pm I purposely didn't use TsMuxeR because the final output wouldn't have profile 7.
If my gimmick works maybe @jcdr428 can modify TsMuxeR once again to make files with profile 7 thus eliminating all those versions (04.fix, 06.fix, 08.fix) that are circulating and that only confuse ideas.
Hi @yusesope, so you need tsMuxer to register profile 6 as profile 4 to be read by ExoPlayer, is this correct ?
I am still reluctant to push this hack to tsMuxer as profile 4 BL should be SDR, not HDR10. Then AppleTV users will still need to use 05.06 fix to register profile 8 as profile 5.
Why not push a commit to ExoPlayer to read profile 6 (DvheDth) ?
pitrako
#2972 Post by pitrako » Thu Sep 17, 2020 5:17 pm
I need some .dll or something? MUX.bat works but MUX_AND_CONVERT_TO_MEL.bat doesn't work, It shows the error I posted above.
PapitaHD
#2973 Post by PapitaHD » Thu Sep 17, 2020 5:31 pm
Exception in thread Thread-5:SIS: 0.0% BL_EL_RPU WRITING: 0.0% (BL AUs: 244 EL AUs: 571)
Traceback (most recent call last):
File "D:\Dolby Vision\v0.0.4_BETA\python-3.7.6.amd64\lib\threading.py", line 926, in _bootstrap_inner
self.run()
File "src\app.py", line 395, in run
self.cpp_lib = self.init_cpp_lib()
File "src\app.py", line 342, in init_cpp_lib
cpp_lib = cdll.LoadLibrary(cpp_lib_path)
File "D:\Dolby Vision\v0.0.4_BETA\python-3.7.6.amd64\lib\ctypes\__init__.py", line 442, in LoadLibrary
return self._dlltype(name)
File "D:\Dolby Vision\v0.0.4_BETA\python-3.7.6.amd64\lib\ctypes\__init__.py", line 364, in __init__
self._handle = _dlopen(self._name, mode)
OSError: [WinError 126] Cannot find the specified module
BL_ANALYSIS: 0.0% EL_ANALYSIS: 0.0% BL_EL_RPU WRITING: 0.0% (BL AUs: 509 EL AUs: 571)
Error for me and stuck.
Same error for me. I'm trying to convert/remux Gemini Man from a full UHD BluRay backup. Officially it's a FEL title, although it has about the lowest bitrare a FEL can have.
Later I'll try Saving Private Ryan.
#2974 Post by shawnc22 » Thu Sep 17, 2020 5:39 pm
kws53 wrote: Thu Sep 17, 2020 3:48 pm
shawnc22 wrote: Wed Sep 16, 2020 10:06 pm They're not really fixing anything. The 04.06 version is an old version (circa ~March/April) that assigned BL+EL+RPU streams as profile 4. The current version nightly assigns them as profile 6. The 05.06 version is I think a user modified version that forcibly assigns a BL+RPU stream as profile 5 instead of 8 for playback on AppleTVs. I don't know what the 08.06 version is, but if it's forcibly assigning streams as profile 8, then I wouldn't go near it. The current nightly correctly labels BL+RPU streams as profile 8 and that's about the only thing that should be labeled as profile 8.
What would you recommend using for BL+EL+RPU.hevc made from Yusesope's tool with a Shield Pro 2019? I'm currently using 0406fix but currently have no way of verifying its efficacy as my 77CX is enroute. Are you suggesting using the 06.06fix (or as an alternative, the current nightly) for my purposes?
You're good, but either should work without issue, though.
jcdr428 wrote: Thu Sep 17, 2020 5:12 pm
Please correct me if I'm wrong, but I think yusecope is suggesting that what tsmuxer is currently registering as profile 6 should go back to being registered as profile 7. It's currently what MakeMKV is doing with the same BL+EL+EPU tracks and it seems to have had no ill effects on playback capabilities (on the Shield w/Exoplayer at least). Mike has mentioned in that past the dual track vs single track transport methods of BL,EL+RPU should have no bearing on profile choice, so I think with the deprecation of profile 6, 7 should technically be the correct assignment for these files.
yusesope
#2975 Post by yusesope » Thu Sep 17, 2020 5:54 pm
quietvoid wrote: Thu Sep 17, 2020 4:19 pm Just tried this and it works on the FireTV Stick 4K...On archlinux...And it plays in Dolby Vision with ExoPlayer. :)
It always warms the heart to see "archlinux" written somewhere :D . Thanks for your feedback.
pitrako wrote: Thu Sep 17, 2020 5:17 pm I need some .dll or something? MUX.bat works but MUX_AND_CONVERT_TO_MEL.bat doesn't work, It shows the error I posted above.
PapitaHD wrote: Thu Sep 17, 2020 5:31 pm Same error for me. I'm trying to convert/remux Gemini Man from a full UHD BluRay backup. Officially it's a FEL title, although it has about the lowest bitrare a FEL can have.
Yes you are right. Your Windows needs THESE libraries (unpack the archive and place the two dll files where there are the files MUX.bat, DEMUX.bat, etc ...). It's not an elegant solution but it should at least work for these days of testing.
Let me know!
jcdr428 wrote: Thu Sep 17, 2020 5:12 pm Hi @yusesope, so you need tsMuxer to register profile 6 as profile 4 to be read by ExoPlayer, is this correct?
The files that are created by this latest version have as VUI:
0,9,16,9,2 for the Base layer
0,9,16,9,2 for the Enhancement layer.
The correct profile should therefore be 7.
Now I don't remember well but it seems to me that TsMuxeR currently generates files with profile 6 (but, I repeat myself, I could be wrong). If my tool proves to work, in my opinion, we should try to mark the ts files with profile 7 (and not 6).
shawnc22 wrote: Thu Sep 17, 2020 5:39 pm I think yusecope is suggesting that what tsmuxer is currently registering as profile 6 should go back to being registered as profile 7
Yep, Exactly!
hepe9
#2976 Post by hepe9 » Thu Sep 17, 2020 6:08 pm
yusesope wrote: Thu Sep 17, 2020 2:59 pmIt goes without saying that these tests must be done on FEL titles. Do not use titles that are already MEL !!!!!
On archlinux, my steps (starting from a mode1 muxed BL_EL_RPU.hevc file):
Mux to mkv, split to make smaller.
Demux to hevc.
python app.py -lbf 50 -demux -fel_to_mel -if video.hevc
python app.py -lbf 50 -mux -bl BL.hevc -el EL_RPU.hevc
mp4muxer_64bits -i BL_EL_RPU.hevc --dv-profile 7 -o test.mp4
PS: there should probably be an indication or something to stop instead of just "Wait...", the default -lbf value just hanged because the file sample is small.
A Firestick playing DV profile 7?
In this thread I read to many people saying the Firestick can't play DV profile 7
I'm confused right now
Edit:
yusesope wrote: Tue Mar 31, 2020 1:45 pmFinally, I join people who ask for the possibility to choose the most congenial DV profile: the dvhe.05 files obtained with my tool (or with DVDFab) are not standard at all (we are well aware of that) but there are devices (Apple TV, Fire Stick 4K) which can only play this type of file!
yusesope wrote: Wed Mar 18, 2020 10:58 am Do you guys want to check the correct functioning of my tool?
Well, create an mp4 file with Dolby's mp4muxer (bearing in mind the limitations of the individual device, like MEL vs FEL or hardware capability):
"-mode 1" (default mode) in my tool and "--dv-profile 4" in mp4muxer for owners of the new Shield (2019)
"-mode 1" (default mode) in my tool and "--dv-profile 7" (maybe also --dv-profile 4) in mp4muxer for owners of LG OLED TV (ninth, eighth
..series...maybe seventh series)
"-mode 2" in my tool and "--dv-profile 5" in mp4muxer for owners of Fire Stick 4K
This has changed?
#2977 Post by shawnc22 » Thu Sep 17, 2020 6:26 pm
hepe9 wrote: Thu Sep 17, 2020 6:08 pm
Demux to hevc.
A device's inability to previously play profile 7 files probably has more to do with the fact that the BL and EL+RPU layers were in separate tracks and not the actual profile label itself.
pitrako
#2978 Post by pitrako » Thu Sep 17, 2020 6:33 pm
yusesope wrote: Thu Sep 17, 2020 5:54 pm
Let me know!
Yep, Exactly!
I tried "A quiet place", It's a FEL title, in exoplayer through kodi and doesn't play, It stays at 00:00. And I think I followed all the steps (extract with FFmpeg, mux and convert to MEL and create a mp4 file with mp4muxer.
hepe9
#2979 Post by hepe9 » Thu Sep 17, 2020 6:35 pm
shawnc22 wrote: Thu Sep 17, 2020 6:26 pm
Demux to hevc.
Thanks for the answer :wink:
quietvoid
#2980 Post by quietvoid » Thu Sep 17, 2020 7:14 pm
hepe9 wrote: Thu Sep 17, 2020 6:08 pmA Firestick playing DV profile 7?
For what it's worth, I've mentioned already that I can play everything except FEL files on mine.
viewtopic.php?f=12&t=21937&p=93904#p93904
PlatypusW
#2981 Post by PlatypusW » Thu Sep 17, 2020 9:48 pm
As anticipated some posts ago, maybe I found the way to "convert" a FEL file to MEL.
This latest innovation together with the previous idea of ​​combining the two layers (BL and EL_RPU) in a single track, should guarantee the possibility of playing any FEL UHD-BD backup on Android devices equipped with a Dolby Vision decoder and capable of playing THIS file (+ my ExoPlayer) or THIS file.
Fingers crossed!
I’ll try and test over the weekend :D
I presume that this isn’t something that could be done ‘on the fly’ at some point? We would need to change the makemkv MKVs to these MP4s each time? I.e. wouldn’t be able to just play the FEL mkv using exoplayer.
ragico
#2982 Post by ragico » Thu Sep 17, 2020 10:12 pm
Following Yusesope instructions, I did the full movie of Despicable me 3 (which is fel) from the original UHD disc backup. I also add an ac3 5.1 audio track to the mp4.
In the Firestick 4k the movie plays perfectly in dolby vision whilst the original fel gives only audio and black screen as all the fel movies in the firestick 4k.
I have used kodi 18.8 and yusesope exoplayer as recommended.
Perfect also the fast fwd/rear navigation.
In next days I will compare it with the original disc played on sony x700 feeding a Panasonic GZ2000 oled.
Yusesope you continue to amaze.
Thankkssssssssssss.
DaMacFunkin
#2983 Post by DaMacFunkin » Fri Sep 18, 2020 5:45 am
kws53 wrote: Thu Sep 17, 2020 3:32 pm
DaMacFunkin wrote: Thu Sep 17, 2020 10:16 am <movie name>.eng.forced.srt
Thank you for the response. So using tsmuxer to mux my MI4.HEVC, MI4.AC3, and MI4.eng.forced.srt together into MI4.ts will result in PLEX playing the subtitles automatically?
it may work if you mux them to TS, I always leave .srt as external subs with Plex, that is what the .eng.forced switch is for. External is also the method for using .srt with Oppo.
jcdr428
#2984 Post by jcdr428 » Fri Sep 18, 2020 9:28 am
yusesope wrote: Thu Sep 17, 2020 5:54 pm The files that are created by this latest version have as VUI:
Yep, Exactly!
Got it! I always assumed that dual PID were profile 7, and single PID were profile 4/6.
I will get it corrected in tsMuxer.
hepe9
#2985 Post by hepe9 » Fri Sep 18, 2020 9:50 am
Demux to hevc.
Knowing this, I tried a Mel with Makemkv and Exoplayer with the Sony Xf90 and it all have red tones, the hardware of this TV is a crap if a simple Firestick can do it
