Media Player Classic & MadVR - Rookie Q's
hiver
#1 Post by hiver » Fri Dec 17, 2010 1:36 pm
Hi all,
Complete rookie here, so go easy please. :-)
Setup:
Windows7/32
MakeMKV 1.6.3
MPC-HC 1.4.2499
FFdshow 3631
MadVR 0.34
HW: Intel Core i3 Mobile Processor (Asrock Core 100 BD machine)
I have searched quite a bit and read through numerous posts on another forum, but I am still puzzled on exactly what is the ideal setup/configuration of MPC-HC, FFdshow and MadVR when playing mkv files (made with Makemkv)
i ask because after having finally gotten bitstreaming sound to work with MPC and FFDshow, I threw MadVR into the mix to improve picture, and now it is all choppy. I understand it could be my HW setup, but would like to check that I have done things right in the setup.
Anyone have a guide with screen dumps of all the relevant settings in the 3 programs, or should I post screendumps of my setups?
Thanks in advance! Mads
setarip_old
Re: Media Player Classic & MadVR - Rookie Q's
#2 Post by setarip_old » Sat Dec 18, 2010 1:52 am
Hi!
Did I overlook something in your post?
What does it have to do with MakeMKV?
hiver
#3 Post by hiver » Sat Dec 18, 2010 12:21 pm
Hi, and thanks for you response.
I took for granted that when posting in a section regarding 'MKV file playback', readers would be able to read between the lines, but you are right - I did not mention MakeMKV, my bad.
Sooo, to answer your question, I rip all my BR films using MakeMKV. Now, I want to make sure I view them with optimal quality of sound and picture. Hence my original question.
Thanks in advance for any insight!
Regards, Mads
