Many Errors Lately - Soloist is latest
kdheslop@gmail.com
Post by kdheslop@gmail.com »
Been having frequent problems ripping and backing up HD and UHD BluRays.
I have a mid-2014 MackBookPro Retina with 2.6 Ghz I-5, 8GB Memory running the latest version of MakeMKV, always with a full charge and plugged into power with an 85 Watt adapter. Running macOS Mojave 10.14.6.
I normally RIP to my server over 1 GbE connection that tends to only go at between 10-40 MB/S, typiucally in the teens though (seems like the NIC changes to a 100 Mb/S randomly. When backing up, I do that to a NvME USB 3.0 external drive or the main (1TB Samsung NvME SSD with over 700 GBs free and installed .)
BluRay Drive is the LG WH16NS60 flashed for UHD LibreDrive, in a Vantec External Case with a dedicated power supply. I also tried a Pioneer BDR-XD05S USB 3 external.
I have been having lots of problems ripping Blu Rays, both UHD and HD lately, although the error codes at times are all the same, and other times they change each time, either location or type.
I just increased my error read count and noticed as a result that the Soloist Disk slowed to a crawl (a few kb/s) at about 6.3 GB versus the prior 7.3GB so it was in the main movie...
Sometimes rebooting and starting over helps to complete...or backing up versus ripping, but not for this disk, which I have tried to RIP or Backup about 7 times.
Errors have been POSIX, SCSI and the OS ipc error 2-3 times with this disk (but don't recall on any other disks before.) I notice this time it reporting both ipc and POSIX errors... :shock:
Here are the debug logs.
005081:0104 Backup done. (Prior Disk)
SDF v07a: HL-DT-ST_BD-RE__WH16NS60_1.00_211704251756_KL7K35A5447
MMBDINST: Launching /Applications/MakeMKV.app/Contents/MacOS/makemkvcon
Put ../lib/libmmbd_new.dylib -> /Applications/VLC.app/Contents/MacOS/lib/libmmbd.dylib
MMBDINST: MMBD installer exiting.
001011:0000 Using LibreDrive mode (v06.2 id=4FBA32AEC678)
005072:0000 Backing up disc into folder "file:///Users/MyName/Desktop/Movies/Working/THE_SOLOIST"
DEBUG: Code 2147483648 at w~b<ET]V*dh:A|q$:29396621
001003:0020 DEBUG: Code 1073741829 at r{Wb^DkMoTc6&OHw:213130559
001003:0020 DEBUG: Code 268435459 at Y&5?w9wtBL}rLcz[Tkd{;f!(1lL:213130789
001003:0020 DEBUG: Code 2281701379 at r{Wb^DkMoTc6&OHw:213130559
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00052.m2ts' at offset '6684672'
001003:0020 DEBUG: Code 0 at /Zsq;Mq5z%K?u;BaD5t:121266189
001003:0020 DEBUG: Code 0 at /Zsq;Mq5z%K?u;BaD5t:213133365
001003:0020 DEBUG: Code 0 at m`9]nBNXhI/C'0Jj^2$p:29396920
002023:0000 Encountered 16 errors of type 'OS X IPC Error' - see http://www.makemkv.com/errors/ipc/
error=0x88000003 count=16 name=OS error - (ipc/send) invalid destination port
Encountered 1 unclassified errors
error=0x40000005 count=1 name=Posix error - Input/output error
005069:0080 Backup failed
005080:0204 Backup failed.
001003:0020 DEBUG: Code 2281701379 at GJ1-R4_'%@QEA~4V:121267431
Tried again with the Pioneer running off a USB 3.0 powered hub (on the fast charge poirts to enable full power) and these are the log files:
001003:0020 DEBUG: Code 100864261 at r{Wb^DkMoTc6&OHw:213130559
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '6858209280'
002023:0000 Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=15 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
error=0x0604441E count=2 name=Scsi error - HARDWARE ERROR:441E
Re: Many Errors Lately - Soloist is latest
You may want to back off to version 1.15.1, or force MakeMKV to use a lower speed. Some combinations of disks and drives don't work with unrestricted speeds, which became the default (when possible) in 1.15.2.
viewtopic.php?p=93341 for how it works, and viewtopic.php?f=1&t=22683 for discussion about issues.
