MakeMKV firmware compatibility
Rathal
#1 Post by Rathal » Sun Sep 13, 2020 8:47 pm
Does flashing a drive with MakeMKV firmware affect its compatibility with other software? Read on one of the eBay listings that it makes the drive only work with MakeMKV, but that didn't seem consistent with what I've read on here.
I'm mainly talking about 1080p Blurays/DVD and (outside of MakeMKV) audio CDs - not bothered about 4K playback, and having 4K ripping (assuming I buy a compatible drive) only in MakeMKV would be fine.
Re: MakeMKV firmware compatibility
#2 Post by Billycar11 » Sun Sep 13, 2020 9:50 pm
yes it will work with all other rippers for 1080 blurays and dvd. 4k can work with other rippers mostly with de firmware to be safe still follow my pined guide and then go to your de fw
Rathal
#3 Post by Rathal » Sun Sep 13, 2020 9:59 pm
Brilliant, thanks! Although to be honest I'm leaning towards buying a preflashed drive anyway
#4 Post by Billycar11 » Sun Sep 13, 2020 10:04 pm
be sure to check my page if you are in the usa they are peflashed and tested to have no read errors on all UHD discs types.
viewtopic.php?f=20&t=17831
