jayper
#2956 Post by jayper » Sat Sep 12, 2020 6:56 pm
There's been an uptick in piracy talk in here lately, and this is not the place for that kind of discussion.
The tool is for making legal back-ups of content you already own.
#2957 Post by Woodstock » Sat Sep 12, 2020 8:12 pm
Dolby has test files if you're just looking to verify your system works.
https://developer.dolby.com/tools-media ... n-streams/
Saiyajin
#2958 Post by Saiyajin » Sun Sep 13, 2020 8:00 am
Hi.
Looks like my LG55CX (after latest firmware update) supports only DV profile 5 and 8 (did not get a chance to check profile 4), not profile 7.
Is there any way to convert profile 7 into either 5 or even better 8? Any tools available?
pitrako
#2959 Post by pitrako » Sun Sep 13, 2020 8:15 am
Anyone knows why The Invisible Man (Dolby Vision and HDR10+) does not show correct colors using DVDFab BL+RPU or BL/EL+RPU in a TV from USB using the native player (Philips PUS7304)? I ripped Spider-man far from home and Joker into a MP4 BL+RPU and It shows the right colors.
whiplash1
#2960 Post by whiplash1 » Sun Sep 13, 2020 3:16 pm
I might be wrong but it could be because The Invisible Man is an FEL title and the other two are MEL titles? I've always found colours from DVDFab to be botched.
pitrako
#2961 Post by pitrako » Sun Sep 13, 2020 3:45 pm
Is modded exoplayer with kodi able to play FEL?
DaMacFunkin
#2962 Post by DaMacFunkin » Sun Sep 13, 2020 4:24 pm
No.
pitrako
#2963 Post by pitrako » Sun Sep 13, 2020 5:23 pm
I might sound dumb for asking so much but..., is possible to convert FEL to MEL and watch with correct colors? I tested the DV MKV files in my TV with exoplayer+kodi If is of any use (https://www.makemkv.com/download/dvtest/):
https://www.makemkv.com/download/dvtest ... K_Demo.mkv = Wrong colors
https://www.makemkv.com/download/dvtest ... _Amaze.mkv = Correct colors
https://www.makemkv.com/download/dvtest ... _Cobra.mkv = Wrong Colors
https://www.makemkv.com/download/dvtest ... _Cobra.mkv = Correct colors
https://www.makemkv.com/download/dvtest ... 00kbps.mkv = Correct colors
RayDawGGG
#2964 Post by RayDawGGG » Sun Sep 13, 2020 5:50 pm
Boss21 wrote:
Mon Aug 24, 2020 12:45 am
please can anyone share ts muxer 05.06 fix , 06.06 fix and 07.06 to download. Iwant to create dv profile 5 to be play on Apple TV through infuse pro.
thanks
This is the 6.06 fix I use. https://drive.google.com/file/d/1voAqvN ... sp=sharing
whiplash1
#2965 Post by whiplash1 » Sun Sep 13, 2020 5:58 pm
Able to play FEL yes. But in HDR. Only MELs trigger DV for now with the modded exoplayer.
RayDawGGG
#2966 Post by RayDawGGG » Sun Sep 13, 2020 6:05 pm
Hi.
Converting a "profile" is unnecessary. You did not state what tools you're using to obtain profile 7. If it's MP4Muxer, just mux your content into profile 5 or 8. If tsMuxer is your tool, use
5.06 fix https://drive.google.com/file/d/1ezfsbV ... sp=sharing for profile 5
8.06 fix https://drive.google.com/file/d/1J2nqPx ... sp=sharing for profile 8
Saiyajin
#2967 Post by Saiyajin » Sun Sep 13, 2020 6:38 pm
Hi.
Much obliged.
pitrako
#2968 Post by pitrako » Mon Sep 14, 2020 6:53 am
I tried extracting the base layer and the enhancement layer with eac3to, merging with yusesope's tool for BL_EL_RPU file, using tsmuxer to get .ts and I get just sound without image, why?
EDIT: I reset my TV and I tested again with the movie 1917 (has FEL too) ripped with DVDFab in MP4, at first It didn't work (wrong colors: purple, green...), I was bored and frustrated but I tried again after some time and the colors are correct now, someone knows If this is a known problem of this model (TV PUS7304)? MEL movies are always color correct.
kws53
#2969 Post by kws53 » Wed Sep 16, 2020 6:19 pm
Does anyone know what Windows video application will play a .ts file made using Yusesope's tool for "BL_EL_RPU.hevc" and muxed using 04.06fix tsmuxer version? VLC will NOT play the file.
kws53
#2970 Post by kws53 » Wed Sep 16, 2020 6:37 pm
Second .ts question - is there a "forced" flag available for SRT subtitles? I am in the process of converting my DV ISO's to .ts format (Yusesope tool+0406fix) for play through my Nvidia Pro Shield 2019 (from PLEX Server on Desktop), Denon AVR and OLED77CX. A number of them (MI 4 for example) have some English forced subtitles.
