You can re-encode the lossless audio stream into eac3, then you can go up to 1500kps and possibly higher.tr000 wrote: Tue Sep 08, 2020 2:28 am Is there any way to get anything more than 640kbps AC3 in DV mp4s? For some reason my Roku TV can't skip around in the stream when playing .ts files, where I can put lossless audio.
mrhollywood
DaMacFunkin
Hi, the link to how to do it is in this thread somewhere lol, maybe Grencola or Yeosope have it readily available.tr000 wrote: Tue Sep 08, 2020 7:53 amOh I see, I actually hadn't tried using Plex, just the Roku Media Player with Serviio. On regular .mkvs with HDR10 it passes DTS-HD fine through HDMI ARC. But using the Mp4Muxer, I can only do AC3. How would I put higher quality audio in it?DaMacFunkin wrote: Tue Sep 08, 2020 5:54 amYou can mux in DTS-HD later, whether the roku recognised the stream is another matter,!plex does in the shield, Zidoo Z9S doesn’t recognise the DTS-HD track and usually chokes.tr000 wrote: Tue Sep 08, 2020 2:28 am Is there any way to get anything more than 640kbps AC3 in DV mp4s? For some reason my Roku TV can't skip around in the stream when playing .ts files, where I can put lossless audio.
sajtipajti
As I know, Eac3To applies audio delay automatically, during demux. It can correct it in 32 ms fragments.Bresnik17 wrote: Mon Sep 07, 2020 9:23 pm Definitely a unique issue to have to solve for, but I ended up making it work by doing the following in case anyone else runs into this:
1. Extracted BL & EL HEVC files from the .M2TS or .MPLS file
2. Created BL+EL+RPU HEVC file using Yusescope's tool
3. Added ONLY the BL+EL+RPU HEVC file to tsMuxer 04.06 and used the "Split & cut" tab. I selected the "Enable cutting" box and set the "Start" time to the delay (2,168ms = 0:00:02.168) and left the "End" time untouched (0:00:00.000)
4. Muxed to .TS file
5. Muxed the newly created .TS file from Step 4 & the TrueHD Atmos track from the original .M2TS or .MPLS file together with the delay set to 0ms
Dolby Vision is triggered in Plex on my 2019 Shield and the TrueHD Atmos track is successfully Direct Playing and synced to the video.
Just select the tracks using USEac3TO and hit the "RUN CL" button...
Yep, however, the delay that eac3to applied during demux was not being applied during the mux to TS without also setting a delay in tsMuxer.sajtipajti wrote:As I know, Eac3To applies audio delay automatically, during demux. It can correct it in 32 ms fragments.Bresnik17 wrote: Mon Sep 07, 2020 9:23 pm Definitely a unique issue to have to solve for, but I ended up making it work by doing the following in case anyone else runs into this:
Sent from my SM-G965U using Tapatalk
sajtipajti
If the delay is positive, Eac3TO adds silence to the beginning of the file in 32 ms increments.Bresnik17 wrote: Wed Sep 09, 2020 1:30 pmYep, however, the delay that eac3to applied during demux was not being applied during the mux to TS without also setting a delay in tsMuxer.sajtipajti wrote:
If the delay is negative, Eac3TO cuts audio from the beginnig of the file in 32 ms increments.
After ending the process it renames the file to show how much was the remainder.
If I remember well it is always below (+/-) 16 ms, which (IMO) you can ignore during muxing with tsmuxer in the next step.
Take a look at viewtopic.php?p=76820#p76820tr000 wrote: Tue Sep 08, 2020 7:53 am Oh I see, I actually hadn't tried using Plex, just the Roku Media Player with Serviio. On regular .mkvs with HDR10 it passes DTS-HD fine through HDMI ARC. But using the Mp4Muxer, I can only do AC3. How would I put higher quality audio in it?
Hi. Did you end up resolving this issue? I downloaded the same torrent and my C9 also doesn't even want to play the files at all.deadchip12 wrote: Mon Apr 20, 2020 5:15 am Disney+ is not available in my country so I download this remux to watch The Mandalorian: https://rarbgway.org/torrent/rw213am. This looks like dolby vision single layer mp4? I have had hard time trying to get this to play on my oled c9. I put the film files in an external hdd and connected it to the c9 via usb. At first, the files seemed to play ok, but once I skipped to another point in the film it refused to play and showed message: "the file can't be recognized". Now that message is shown everytime I try to open the files so I can't even play the film anymore. Any idea? The TV did recognize the files at first so it's really weird that it does not recognize the files now anymore. The files are not corrupted btw, I tested them on my computer and they play fine, only without dolby vision.
sajtipajti
It's interesting: I tried them on my B7 just now without any issue.Mierzen wrote: Thu Sep 10, 2020 6:21 pmHi. Did you end up resolving this issue? I downloaded the same torrent and my C9 also doesn't even want to play the files at all.deadchip12 wrote: Mon Apr 20, 2020 5:15 am Disney+ is not available in my country so I download this remux to watch The Mandalorian: https://rarbgway.org/torrent/rw213am. This looks like dolby vision single layer mp4? I have had hard time trying to get this to play on my oled c9. I put the film files in an external hdd and connected it to the c9 via usb. At first, the files seemed to play ok, but once I skipped to another point in the film it refused to play and showed message: "the file can't be recognized". Now that message is shown everytime I try to open the files so I can't even play the film anymore. Any idea? The TV did recognize the files at first so it's really weird that it does not recognize the files now anymore. The files are not corrupted btw, I tested them on my computer and they play fine, only without dolby vision.
Hi can somebody share any torrents where I can test Dolby Vision? Thank you
There's been an uptick in piracy talk in here lately, and this is not the place for that kind of discussion.
The tool is for making legal back-ups of content you already own.
Dolby has test files if you're just looking to verify your system works.
https://developer.dolby.com/tools-media ... n-streams/
Hi.
Looks like my LG55CX (after latest firmware update) supports only DV profile 5 and 8 (did not get a chance to check profile 4), not profile 7.
Is there any way to convert profile 7 into either 5 or even better 8? Any tools available?
Anyone knows why The Invisible Man (Dolby Vision and HDR10+) does not show correct colors using DVDFab BL+RPU or BL/EL+RPU in a TV from USB using the native player (Philips PUS7304)? I ripped Spider-man far from home and Joker into a MP4 BL+RPU and It shows the right colors.
I might be wrong but it could be because The Invisible Man is an FEL title and the other two are MEL titles? I've always found colours from DVDFab to be botched.pitrako wrote: Sun Sep 13, 2020 8:15 am Anyone knows why The Invisible Man (Dolby Vision and HDR10+) does not show correct colors using DVDFab BL+RPU or BL/EL+RPU in a TV from USB using the native player (Philips PUS7304)? I ripped Spider-man far from home and Joker into a MP4 BL+RPU and It shows the right colors.
Is modded exoplayer with kodi able to play FEL?
