GregoryV wrote: Fri Sep 11, 2020 7:13 am my apologies as i didnt realize you are in fact the OP.
If you downloaded the flasher + firmware pack zip file from the first post, the firmware/s you are looking for are located in the zip file at:
BP60NB10 1.02-MK:
mk-firmware-pack-20200720\MK\HL-DT-ST\BP60NB10\HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
BP60NB10 1.00-MK:
mk-firmware-pack-20200720\MK\old\HL-DT-ST-BD-RE_BP60NB10-1.00-NM00200-211711211720.bin
So, as your drive came with 1.02, you must flash 1.02 MK first. Since it is the same firmware (just the MK version), you will not see any drive firmware number change.
Now you can flash 1.00-MK.
Once this has been done, open MakeMKV and you should see on the right hand side, firmware is version 1.00 and that libredrive has been enabled.
trippycat
Re:
Post by trippycat »
trippycat wrote: Thu Sep 10, 2020 6:23 pm
PrimoAngelo wrote: Fri Sep 06, 2019 11:27 am I have an LG BE16NU50 and LG BH16NS55 drives. Thanks to this guide I have succesfully flash a DE firmware and I can rip 4K and burn blank media.
Is it possible to crossflash these drives to enable scanning of burned bluray? (Qpxtools or Opti Drive Control).
Could this change possibly break the possibility of burning new discs?
I ordered a BH16NS55 today, I'll flash it to BH16NS55-MK (as it'll probably come with the 1.04 firmware version with downgrade protection), then crossflash it to WH16NS58-1.V5-MK. I'll cross fingers and report whether it works here. :)
If it doesn't, well, we're probably out of luck (and I've been looking into this topic for a bunch of hours).
Alright, answering to myself: it works!
I received my BH16NS55 today, with fw 1.04 as expected. I flashed 1.04-MK over it, successfully, then crossflashed WH16NS58-1.V5-MK. I can now successfully scan BD-R discs!
Here is a scan at normal (max) speed:
A scan at low speed (2x):
And a scan of a (badly) damaged disc:
Note that as a cool bonus feature, it does also support DVD quality scanning (PIE/PIF/POF).
Of course, it also happens to be a LibreDrive, which may come out handy at some point :) Clearly, it's the perfect drive for me!
GregoryV
Post by GregoryV »
Hello
Then ive been using the right ones from the start then. glad to know im not a total idiot. Using the SDF tool i load the firmware 1.02mk choose the drive, hit start, it goes through the progress bar then shows success. i reboot just to be sure then load the 1.0mk go through the same process. It says success but when i check in MakeMKV it still shows 1.02 and all the options say possible (with patched firmware)
Could this be a usb problem? Should i try to remove the drive from the enclosure and go direct sata to my PC? im just worried as that will most certainly void my warranty.
And again thank you for all your help.
GregoryV
Post by GregoryV »
Well I thought this might be a usb bottleneck issue so I learned how to disassemble my new drive by taking apart my old drive. Once I got both apart I was faced with a drive that has an extended pcb to the charging port. Never seen that before.
Now I cannot even direct connect to my PC to try and flash the drive as the BP60NB10 does not have the SATA power or data plug present in the back.
I have tried flashing on my laptop and then my PC to no avail. I guess there is a chipset that is keeping me from flashing back.
I truly appreciate the help I have recieved. I'm going to buy a 5.25 desktop drive and an enclosure and return this junk to Newegg.
Thank you to all that helped.
GregoryV wrote: Fri Sep 11, 2020 6:55 pm Well I thought this might be a usb bottleneck issue so I learned how to disassemble my new drive by taking apart my old drive. Once I got both apart I was faced with a drive that has an extended pcb to the charging port. Never seen that before.
I'm lost as to why it is not flashing properly. Do you have both USB's plugged in. Make sure you do.
Also as a last ditch attempt, can you try the ASUS flasher using the same steps (1.02 MK then 1.00 MK).
GregoryV
Post by GregoryV »
Yup both plugs are always in. It's a failure number 5 when trying the modified ASUS. I'm going in order like you showed and even deleted all the files from the link and then re-downloaded them just to be sure they weren't corrupted.
The drive was manufactured in July of this year. Like I said in my previous post I think the pcb being custom and the unit not having a sata hookup is one of the issues.
GregoryV
Post by GregoryV »
Here is the MakeMKV pics.
And again thank you for the help.
Post by SamuriHL »
Because you have not read enough. You can't go directly to 1.00 from 1.02.
GregoryV
Post by GregoryV »
SamuriHL wrote: Fri Sep 11, 2020 11:56 pm Because you have not read enough. You can't go directly to 1.00 from 1.02.
I've followed the directions given by the OP. And it still doesn't change the fact that it will not flash at all. It fails even when attempting to go from the stock 1.02 to the 1.02 mk. Maybe you need to read a bit more.
Post by SamuriHL »
GregoryV wrote: Sat Sep 12, 2020 12:39 am
Your picture shows that your drive is on 1.02 and you selected 1.00. So, good luck.
GregoryV
Post by GregoryV »
SamuriHL wrote: Sat Sep 12, 2020 12:59 am
Read back further bud. This was the last attempt after doing dozens of others. You obviously have not read the previously posted pics or threads as the CREATOR of the tool we are discussing instructed me on the procedure. Will it make you feel better if I attempt for the 50th time and take a picture of the FAILURE to go from 1.02 STOCK to 1.02 MK?
I have used both the modded ASUS and the other sdk tool RECOMMENDED BY THE CREATOR to try and flash from 1.02 to 1.02mk then 1.01mk then 1.0.
Guess what happened. They ALL failed. He was very helpful. You've come to the party late ASSUMED I didn't do things right when I am unable to do even THE FIRST STEP.
Either you have some constructive tips or please leave it be.
Ok, I think I know why it hasn't worked. I just realized that your drive's stock 1.02 firmware is an encrypted firmware.
Here are the new steps for you:
1. Using the SDFtool Flasher, select firmware 1.02 MK and check the "enc" box.
2. Once this has flashed successfully, select firmware 1.00 MK and make sure "enc" is not checked.
This should do the trick and you should be on 1.00 MK.
GregoryV
Post by GregoryV »
MartyMcNuts wrote: Sat Sep 12, 2020 1:15 am
Thank you. I will try as soon as my current rips are done on the computer.
Again youve been awesome! TY
GregoryV
Post by GregoryV »
Thank you so much! Got the firmware down to 1.0 using the exact method you listed. Unfortunately its still showing not supported by DVDFAB even though they list the drive with 1.0 being supported, but thats an issue for there not here. I just want to rip my movies and have VOB files in AVI so I can watch them from my media player in the truck like I do with standard blurays.
Do you have any recommendations for software that will do that with this drive now at 1.0? Does MakeMKV have that option or is it full disc backup only?
GregoryV wrote: Sat Sep 12, 2020 1:48 am
Glad you got it sorted.
MakeMKV can back upto full folder or movie only MKV file.
You could use MakeMKV to rip your movies to a MKV file. If your media player can't play MKV files, you could use basically any other software, such as HandBrake or DVDFab, to then convert the MKV file to an AVI.
