Quitch
Re: SDFtool Flasher
Post by Quitch » Tue Sep 08, 2020 12:51 pm
Used v1.0.0.1 just now to flash my drive, since I could find all the firmware but was struggling to find instructions on how to flash the drive. This was a real lifesaver, thank you! Worked like a charm.
One suggestion would be to have the outcome message appear as a modal pop-up. The first time it was unsuccessful, I think because I enabled enc and didn't need it, but because the window wasn't in the foreground I didn't see what happened.
melkore
Re: SDFtool Flasher
Post by melkore » Wed Sep 09, 2020 3:06 am
When trying to update my drive for the first time I am getting the error in the attached file. I can dump the firmware. I've tried with and without enc enabled.
Re: SDFtool Flasher
Post by MartyMcNuts » Wed Sep 09, 2020 1:23 pm
melkore wrote: Wed Sep 09, 2020 3:06 am When trying to update my drive for the first time I am getting the error in the attached file. I can dump the firmware. I've tried with and without enc enabled.
Ok. Please don't flash your drive to NS60 1.03. if it came with 1.02 flash NS60 1.02 MK. 1.03 is not better in any way. Also, "enc" is not required since your drive did not come with encrypted firmware.
melkore
Re: SDFtool Flasher
Post by melkore » Wed Sep 09, 2020 8:22 pm
MartyMcNuts wrote: Wed Sep 09, 2020 1:23 pm
That did it. I didn't know that the older firmware was in a different location than the latest. I only found 1.03 and figured that's what I needed. It is now flashed and currently ripping a 4k bluray. Thanks!
Re: SDFtool Flasher
Post by MartyMcNuts » Thu Sep 10, 2020 2:17 am
melkore wrote: Wed Sep 09, 2020 8:22 pm
You're welcome!!
Enjoy!!!
Re: SDFtool Flasher
Post by Billycar11 » Thu Sep 10, 2020 2:20 am
the recover drive thing you got that figured out?
like for cross flashed 2014 and older drives/ bu40ns to desktop?
Re: SDFtool Flasher
Post by SamuriHL » Thu Sep 10, 2020 2:52 am
I need to add that to my tool as well. But I don't think it's super straight forward and potentially dangerous. I don't have a drive to test it on either. But we really should have that in your tool.
Re: SDFtool Flasher
Post by MartyMcNuts » Thu Sep 10, 2020 8:16 am
SamuriHL wrote: Thu Sep 10, 2020 2:52 am I need to add that to my tool as well. But I don't think it's super straight forward and potentially dangerous. I don't have a drive to test it on either. But we really should have that in your tool.
I have the command ready to go but I do not have an old NS40 to test it with. @SamuriHL, @Billycar11, do either of you guys?
I tried it with a NS55 flashed with BU40N and it doesn't work. I get an error. See here: viewtopic.php?f=16&t=23023#p95844 I'm waiting on a response from Mike... He does say that the command should work for the old NS40's.
Re: SDFtool Flasher
Post by Billycar11 » Thu Sep 10, 2020 8:24 am
MartyMcNuts wrote: Thu Sep 10, 2020 8:16 am
i will try to convince the next guy who cant recover his to sell it to me lol
and ill check with Alex he might have some
jonghotti wrote:
Re: SDFtool Flasher
Post by MartyMcNuts » Thu Sep 10, 2020 8:37 am
Billycar11 wrote: Thu Sep 10, 2020 8:24 am
jonghotti wrote:
Ok, Let me know...
Re: SDFtool Flasher
Post by SamuriHL » Thu Sep 10, 2020 12:46 pm
I don't have a drive to test it on unfortunately.
Re: SDFtool Flasher
Post by MartyMcNuts » Fri Sep 11, 2020 3:30 am
@Billycar11 @jonghotti @SamuriHL
According to Mike, it should work for slim drives flashed to desktop firmware and the old NS40 / ASUS BW-16D1HT drives.
I tried it on a desktop drive flashed to slim firmware (BH16NS55 flashed to BU40N 1.00) and get an error when trying to recover to NS55 firmware (or any other firmware). I was hoping it would work this way too but no luck so far. Hoping Mike responds soon.
Anyway, if/when one of you guys end up with an old NS40, BW-16D1HT or a slim drive flashed to desktop firmware, let me know and I'll send the app to you to test.
CIR Engineering
Re: SDFtool Flasher
Post by CIR Engineering » Mon Sep 14, 2020 8:42 pm
I'm getting a .NET error when I launch the program on two different Windows 10 machines that I have tried. Any idea what I can do? I've tried the simple Googled fixes but with no joy.
Very frustrating!
Kind regards,
craigr
Re: SDFtool Flasher
Post by MartyMcNuts » Mon Sep 14, 2020 11:26 pm
CIR Engineering wrote: Mon Sep 14, 2020 8:42 pm I'm getting a .NET error when I launch the program on two different Windows 10 machines that I have tried. Any idea what I can do? I've tried the simple Googled fixes but with no joy.
Very frustrating!
Kind regards,
craigr
Ensure that MakeMKV is installed and that you have the latest version of the .net framework installed.
CIR Engineering
Re: SDFtool Flasher
Post by CIR Engineering » Tue Sep 15, 2020 1:25 am
Thanks. Trouble is you never know which version of .NET framework may be out of date, Microsoft just has too many variants and no easy way to tell if they are all up to date. They really need to unify that a bit better.
In any event I got it working. Of all the crazy things, I plugged the drives into my NexStar DX NST-53053 USB enclosure and connected it to my Windows 10 VM running as guest on unRAID Slackware and it f---ing worked that way. This was the most construed approach and I thought the chance of it working were close to zero, but there it is.
In any event, I made four WH14NS40 1.05's into four Asus BW-16D1HT 3.10's. They now rip UHD great.
Thanks for the new tool!
Kind regards,
craigr
