Makemkv crashes one first run when changing output folder
robojock
Post by robojock »
I have been "distrohopping" and whenever i install makemkv regardless if it is snap/flatpak, ppa or from source everytime on the first run when i change the default destination to semi-auto and home/user/videos folder. After either clicking apply or ok, makemkv will get freeze and crash. After closing it and running makemkv again then i can select semi-auto and the destination folder i want.
bmillham
Re: Makemkv crashes one first run when changing output folder
Post by bmillham »
robojock wrote: Thu Sep 10, 2020 4:05 pm Hi,
Are you use videos or Videos? Remember that linux is case sensitive on filenames. At least with Ubuntu based distros, Videos is the correct directory.
robojock
Post by robojock »
bmillham wrote: Thu Sep 10, 2020 8:39 pm Are you use videos or Videos? Remember that linux is case sensitive on filenames. At least with Ubuntu based distros, Videos is the correct directory.
Yes, I know that linux is case sensitive on filenames, I usually select the directory by clicking on the "folder" icon. But even typing out the path it will also cause it crash. Always on the first run, after that it works.
