I want to make MKVs from three (original) discs with music videos to have it available within my network. When I play the videos directly from disc, everything is fine. When I play the MKV, the sound is scratchy. It is not a joy to listen then. I tried several times with the different profiles (default, FLAC, AAC,WDTV) and from two different drives (dvd and br), but everytime the same result.
This is the information from the audio layer with different profiles:
Default:
Typ: Audio
Sprache: English
Codec: Linear PCM
Kanäle: 2
Channel layout: stereo
Abtastrate: 48000
Bits pro Sample: 24
Output format: Raw LPCM audio without channel configuration metadata ( Lossless conversion )
Output description: Save as raw LPCM
MKV Flags: Default
AAC-Stereo:
Typ: Audio
Flags: Profile-defined secondary stream
Sprache: English
Codec: Linear PCM → AAC
Kanäle: 2
Abtastrate: 48000
Bits pro Sample: 24
Output format: AAC audio ( Lossy conversion )
Output description: Save as Mpeg-4 AAC-LC
MKV Flags: Default
FLAC:
Typ: Audio
Sprache: English
Codec: Linear PCM → FLAC
Kanäle: 2
Abtastrate: 48000
Bits pro Sample: 24
Output format: FLAC audio ( Lossless conversion )
Output description: Save as FLAC (fast compression)
MKV Flags: Default
WDTV:
Typ: Audio
Sprache: English
Codec: Linear PCM
Kanäle: 2
Abtastrate: 48000
Bits pro Sample: 24
MKV Flags: Default
Anybody any ideas?
Thank you
