Ghost in the Shell (1995) (US)
jayper
Post by jayper » Sat Sep 05, 2020 9:55 pm
The US version of Ghost in the Shell (1995) is not currently decrypting.
Dump submitted.
djwudi
Re: Ghost in the Shell (1995) (US)
Post by djwudi » Tue Sep 08, 2020 8:38 pm
Same issue, dump just submitted.
jayper
Post by jayper » Tue Sep 08, 2020 10:20 pm
Working now. Thanks Mike!
-Maverick-
Post by -Maverick- » Wed Sep 09, 2020 2:57 am
I'm assuming this is for the regular Blu-ray and not 4K disc?
hedcase
Post by hedcase » Wed Sep 09, 2020 7:31 am
I'm just now ripping my discs. I see there's two options -- which did you choose?
jayper
Post by jayper » Wed Sep 09, 2020 3:23 pm
Duplicate post.
jayper
Post by jayper » Wed Sep 09, 2020 3:34 pm
UHD.
Haven't actually done my back-up yet, just checked in to see if it would decrypt. Compare the language and sub tracks, a lot of times certain languages are relegated to a different playlist. If it all looks like the same, compare the segment maps for each playlist. If it's the same map, there's no difference between the two.
andcbii
Post by andcbii » Wed Sep 09, 2020 6:31 pm
I'm also having issues opening the UHD disk.
***EDIT***
3 hours later still trying to open the disc... I can not even get a dump file.
-Maverick-
Post by -Maverick- » Thu Sep 10, 2020 7:13 am
UHD.
Thanks for not crucifying me. I realized my dumb question without checking what forum section I was on first. :oops:
I'm picking up my steelbook release from Best Buy tomorrow. I've never owned a HD/4K release of this movie, so I'm looking forward to the jump in quality from my SE DVD release.
jayper
Post by jayper » Thu Sep 10, 2020 1:58 pm
***EDIT***
Have you made sure the disc surface is clean? Even if it looks clean, you might want to use a microfiber cloth to wipe it down.
jayper
Post by jayper » Thu Sep 10, 2020 1:59 pm
UHD.
We've all made similar mistakes. No worries! The steelbook looks awesome, enjoy!
andcbii
Post by andcbii » Mon Sep 14, 2020 7:30 pm
I got this title to rip. I saw some people asking with mpls to rip. My disk had mpls 800 and 801. I didn't do a very thorough review, but i noticed in 800 the subtitles at the beginning of the movie are on the bottom. For 801 the subtitles are at the top. When i put my disk in my UHD player the subs were at the bottom. So i'm going with 800.
Dankkh
Post by Dankkh » Fri Sep 18, 2020 10:51 pm
Man, my ASUS BW-16D1HT really struggled with this disc for some reason. I have never heard my drive make such unhealthy-sounding noises before.
When decrypting the disc, the drive would constantly spin up, make some audible grinding noises, and then spin back down. It kept doing this repeatedly. And once the disc was fully decrypted, the drive spun up to such an excessively fast speed that I thought it was about to explode.
I initially tried ripping the 801 playlist. It failed immediately. I tried rebooting and ripping the 800 playlist instead, and this time it worked, but it was stuck ripping at a very slow speed (2X only). Ultimately I was able to rip the whole thing with no errors though.
preserve
Post by preserve » Sun Feb 21, 2021 5:33 am
Finally got this. Starting first with the Blu-ray disc from the US UHD set... I'm assuming the configuration will be the same with the (differently numbered) playlists on the UHD.
There are two main playlists, and the disc uses a different playlist (and gives you different subtitles) depending on if you select playback with English or Japanese audio... even though both playlists in MakeMKV allow you to get all of the different audio together.
When I rip just the English subtitles using MakeMKV 1.15.4, this is the result I get:
00916.mpls
1 - English Dub Subtitles
2 - English Dub Subtitles Forced
3 - English Dub SDH Subtitles
4 - English Dub SDH Subtitles Forced
00454.mpls
1 - Japanese Translation Subtitles
2 - Japanese Translation Subtitles Forced
3 - Japanese Translation SDH Subtitles
4 - Japanese Translation SDH Subtitles Forced
Using: ASUS BW-16D1HT 3.00
caycep
Post by caycep » Sat Nov 05, 2022 4:24 pm
Quick question - it currently rips for me but has 3 separate UHD output tracks...is there anyway to tell which is which? the first one (title00) has a few subtitles on top, not sure what the mix is for the other two...
