Please help with BU40N "you cannot flash your drive to this firmware file directly" error
Theozefrench
#1 Post by Theozefrench » Tue Sep 08, 2020 10:49 am
Hi all,
Long time MakeMKV paid user, I want to rip 4K movies and after spending a few days in this forum I bought a BU40N slim external drive.
This is MakeMKV drive info :
Product: BD-RE BU40N
Revision: 1.01
Serial number: MO8K6283951
Firmware date: 2119-10-16 10:32
Bus encryption flags: 1F
Highest AACS version: 71
Harware support: Yes
Firmware support: No
Firmware version: 1.01
This post : viewtopic.php?f=19&t=22653 says the fimware to use is the BU40N-N-Main, but wen I try to flash it I get the "you cannot flash your drive to this firmware file directly" error.
I feel I'm almost there, probably some intermediate firmware to flash, but can't fint the missing bit of information. Can you point me to what I am missing ?
Thanks for your time !
Re: Please help with BU40N "you cannot flash your drive to this firmware file directly" error
#2 Post by Billycar11 » Tue Sep 08, 2020 10:54 am
just use the old flashers or read here about a remote flash from me: viewtopic.php?f=20&t=17831
#3 Post by MartyMcNuts » Tue Sep 08, 2020 11:43 am
Theozefrench wrote: Tue Sep 08, 2020 10:49 am Hi all,
Revision: 1.01
Also, the SDFtool Flasher has been updated. You should be able to flash the BU40N with firmware DE_LG_BU40N_1.00 firmware.
Theozefrench
#4 Post by Theozefrench » Wed Sep 09, 2020 4:56 pm
MartyMcNuts wrote: Tue Sep 08, 2020 11:43 am Also, the SDFtool Flasher has been updated. You should be able to flash the BU40N with firmware DE_LG_BU40N_1.00 firmware.
It just simply billiantly worked, thank you all for this great place and your kind help. You made my day !
