ragico
Post by ragico » Mon Sep 07, 2020 10:03 am
userr wrote:
Mon Sep 07, 2020 6:45 am
ragico wrote:
Sat Sep 05, 2020 6:53 pm
It plays dual layer dual track in the form of mkv (dual layer single track) via kodi + Yusesope Exoplayer and .ts profile 4 (using Yusesope tool)
So it doesnt play things with dual track? Basically like the shield then
Yes
Bresnik17
Post by Bresnik17 » Mon Sep 07, 2020 9:23 pm
DaMacFunkin wrote:
Mon Sep 07, 2020 5:57 am
Bresnik17 wrote:
Sun Sep 06, 2020 2:33 pm
shawnc22 wrote:
Sun Sep 06, 2020 1:49 am
when you're extracting the bl and el files with eac3to, did you notice any errors? when there's an a/v sync issue after remuxing, it's possible that there may be errors in the original video layers.
No errors during the extraction and the issue appears to exist before that point. When I pull the original M2TS / MPLS files into eac3to and tsMuxer they already acknowledge the required delay:
eact3to:
1: Chapters, 22 chapters
2: h265/HEVC, 2160p24 /1.001 (16:9), 10 bits
3: h265/HEVC, 1080p24 /1.001 (16:9), 10 bits - Dolby Vision Enhancement Layer
4: TrueHD/AC3 (Atmos), 7.1 channels, 48kHz, 2168ms
(embedded: AC3 EX, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB)
5: AC3, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB, 2168ms
6: AC3, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB, 2168ms
7: AC3, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB, 2168ms
8: AC3 Surround, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB, 2168ms
9: Subtitle (PGS)
10: Subtitle (PGS)
11: Subtitle (PGS)
12: Subtitle (PGS)
tsMuxer:
Automatically sets the delay on all audio files to 2,169ms when imported.
I had this problem with Braveheart, I seem to remember ripping it either movie only ISO with DVDfab then processing that output
Definitely a unique issue to have to solve for, but I ended up making it work by doing the following in case anyone else runs into this:
1. Extracted BL & EL HEVC files from the .M2TS or .MPLS file
2. Created BL+EL+RPU HEVC file using Yusescope's tool
3. Added ONLY the BL+EL+RPU HEVC file to tsMuxer 04.06 and used the "Split & cut" tab. I selected the "Enable cutting" box and set the "Start" time to the delay (2,168ms = 0:00:02.168) and left the "End" time untouched (0:00:00.000)
4. Muxed to .TS file
5. Muxed the newly created .TS file from Step 4 & the TrueHD Atmos track from the original .M2TS or .MPLS file together with the delay set to 0ms
Dolby Vision is triggered in Plex on my 2019 Shield and the TrueHD Atmos track is successfully Direct Playing and synced to the video.
tr000
Post by tr000 » Tue Sep 08, 2020 2:28 am
Is there any way to get anything more than 640kbps AC3 in DV mp4s? For some reason my Roku TV can't skip around in the stream when playing .ts files, where I can put lossless audio.
DaMacFunkin
Post by DaMacFunkin » Tue Sep 08, 2020 5:54 am
You can mux in DTS-HD later, whether the roku recognised the stream is another matter,!plex does in the shield, Zidoo Z9S doesn’t recognise the DTS-HD track and usually chokes.
tr000
Post by tr000 » Tue Sep 08, 2020 7:53 am
Oh I see, I actually hadn't tried using Plex, just the Roku Media Player with Serviio. On regular .mkvs with HDR10 it passes DTS-HD fine through HDMI ARC. But using the Mp4Muxer, I can only do AC3. How would I put higher quality audio in it?
mrhollywood
Post by mrhollywood » Tue Sep 08, 2020 5:14 pm
You can re-encode the lossless audio stream into eac3, then you can go up to 1500kps and possibly higher.
DaMacFunkin
Post by DaMacFunkin » Tue Sep 08, 2020 5:49 pm
Hi, the link to how to do it is in this thread somewhere lol, maybe Grencola or Yeosope have it readily available.
sajtipajti
Post by sajtipajti » Wed Sep 09, 2020 4:55 am
As I know, Eac3To applies audio delay automatically, during demux. It can correct it in 32 ms fragments.
Just select the tracks using USEac3TO and hit the "RUN CL" button...
Bresnik17
Post by Bresnik17 » Wed Sep 09, 2020 1:30 pm
Yep, however, the delay that eac3to applied during demux was not being applied during the mux to TS without also setting a delay in tsMuxer.
Sent from my SM-G965U using Tapatalk
sajtipajti
Post by sajtipajti » Wed Sep 09, 2020 1:43 pm
If the delay is positive, Eac3TO adds silence to the beginning of the file in 32 ms increments.
If the delay is negative, Eac3TO cuts audio from the beginnig of the file in 32 ms increments.
After ending the process it renames the file to show how much was the remainder.
If I remember well it is always below (+/-) 16 ms, which (IMO) you can ignore during muxing with tsmuxer in the next step.
daddy
Post by daddy » Thu Sep 10, 2020 5:00 am
Take a look at viewtopic.php?p=76820#p76820
Mierzen
Post by Mierzen » Thu Sep 10, 2020 6:21 pm
deadchip12 wrote:
Mon Apr 20, 2020 5:15 am
Disney+ is not available in my country so I download this remux to watch The Mandalorian: https://rarbgway.org/torrent/rw213am. This looks like dolby vision single layer mp4? I have had hard time trying to get this to play on my oled c9. I put the film files in an external hdd and connected it to the c9 via usb. At first, the files seemed to play ok, but once I skipped to another point in the film it refused to play and showed message: "the file can't be recognized". Now that message is shown everytime I try to open the files so I can't even play the film anymore. Any idea? The TV did recognize the files at first so it's really weird that it does not recognize the files now anymore. The files are not corrupted btw, I tested them on my computer and they play fine, only without dolby vision.
Hi. Did you end up resolving this issue? I downloaded the same torrent and my C9 also doesn't even want to play the files at all.
sajtipajti
Post by sajtipajti » Fri Sep 11, 2020 3:51 am
It's interesting: I tried them on my B7 just now without any issue.
apple2
Post by apple2 » Sat Sep 12, 2020 7:43 am
Hi can somebody share any torrents where I can test Dolby Vision? Thank you
jayper
Post by jayper » Sat Sep 12, 2020 6:56 pm
There's been an uptick in piracy talk in here lately, and this is not the place for that kind of discussion.
The tool is for making legal back-ups of content you already own.
