Dolby Vision and 1.15.1
Re: Dolby Vision and 1.15.1
I can't drag the .m2ts files over to tsMuxeR from the disc as it doesn't work. Does this mean we have to rip with MakeMKV twice? Once to copy the disc and a 2nd time to create the .mkv file?
Anyone have pitch black uhd and converted it to mkv? Tried to play it on the shield like usual and it triggered dv but completely black screen with audio playing. It's a mel title. First one of my rips I've seen do this.
How do you create the "unencrypted backup"?Cannikin wrote: ↑Fri Sep 04, 2020 11:34 pmWhere do you get the m2ts from? Is that inside BDMV somewhere? If so I assume you need an unencrypted backup?RESET_9999 wrote: ↑Fri Sep 04, 2020 11:31 pmyou don't need eac3to if you have the original m2ts file.
Open MakeMKV > Ensure the desired disc drive is selected as the source in the UI > File > Backup > Check the "Decrypt video files" box > Select your output directory > Click OKlujan wrote: ↑Sat Sep 05, 2020 2:55 pmHow do you create the "unencrypted backup"?Cannikin wrote: ↑Fri Sep 04, 2020 11:34 pmWhere do you get the m2ts from? Is that inside BDMV somewhere? If so I assume you need an unencrypted backup?RESET_9999 wrote: ↑Fri Sep 04, 2020 11:31 pmyou don't need eac3to if you have the original m2ts file.
Just tried mine on shield - seemed to work fine. At least there wasn’t any black screen - jumped 10 mins in too, DV picture + audio.
Thanks, it took a while but I finally got it working. I'm watching "Gemini Man" 4k in Dolby Vision and Atmos. I noticed that the .ts file is around 5 GB more than the .mkv file. Is this expected?
My copy just arrived. I will test it out this weekend and let you know.
Just checked mine: plays in HDR and DTS-HD MA on Plex on my Shield Pro just fine! I haven’t converted to TS or use the patched Exoplayer so no DV for me.
are you using overscan on the shield? with 8.2 is a bug, if overscan is disabled it should work again. otherwise try to reboot the shield and try it again.
strange , works fine on mine.
Well, thanks to my very fast NVME drive , it is faster this way than encoding the truehd track with eac3to.
I rip from disc to a folder bluray structure (which take most of the time) then create a DV mkv using the folder bluray structure as the source instead of ripping the disc again.
Then you use tsmuxer to mux the dv mkv with atmos from the original m2ts.
Sounds good, I'll rip in that order the next time.
Can I just ask please if there are any Dolby Vision Demo files available (preferably mkv's) to test with the modified Exo Player.
Nope, not using overscan. This is the ONLY title in my several dozen DV movies that doesn't work for me.
