WH14NS40: "No disc inserted" after re-flashing to stock firmware
Kepler
Post by Kepler » Sat Sep 05, 2020 2:31 pm
Hello! I recently bought a used WH14NS40 (Manufactured Nov. 2012, had firmware v1.00, info label pic attached)
I foolishly flashed the WH14NS40-NS50 firmware (linux):
# sdftool -d /dev/sr0 rawflash -i /tmp/HL-DT-ST-BD-RE_WH14NS40-NS50-1.05-NM00900-212005061444.bin
That, of course, soft bricked the drive. After doing more research, I found the patched flasher guide, and in Windows crossflashed WH16NS60 1.02 (as recommended here)
That flashed successfully, but after rebooting, the drive wasn't able to read discs, saying "No disc inserted" in MakeMKV
After more toying around I decided to install the latest official firmware (v1.03), using the patched flasher, extracting the .bin from the official installer with Firmware Extractor 2. That flashed succesfully, but I'm still left with the drive not recognizing discs (DVDs and Blu Rays).
MakeMKV_log.txt:
Debug log started at Sat Sep  5 14:27:19 2020 , written by MakeMKV v1.15.2 linux(x64-release)
001005:0000 MakeMKV v1.15.2 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/*/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at EhsdE9uJwGJ#F]k}>sW:D0:29393631
No  SDF v07a: ATAPI_iHAS424___B_GL1B_3743524253_2A8145501968
SDF id v07a: ATAPI_iHAS424___B_GL1B_3743524253_2A8145501968
SDF  v07a: HL-DT-ST_BD-RE__WH14NS40_1.03_211711211658_SIK85CBLG033
Here's the current drive info from MakeMKV:
OS device name: /dev/sr0
Product: BD-RE WH14NS40
Revision: 1.03
Serial number: SIK85CBLG033
Firmware date: 2117-11-21 16:58
Highest AACS version: 70
Harware support: Yes
Firmware support: No
Firmware version: 1.03
Here's more info that might be useful: (the drive is sr0, has DVD inserted)
$ cat /proc/sys/dev/cdrom/info
CD-ROM information, Id: cdrom.c 3.20 2003/12/17
drive name:		sr0
drive speed:		48
drive # of slots:	1
Can close tray:		1
Can open tray:		1
Can lock tray:		1
Can change speed:	1
Can select disk:	0
Can read multisession:	1
Can read MCN:		1
Reports media changed:	1
Can play audio:		1
Can write CD-R:		1
Can write CD-RW:	1
Can read DVD:		1
Can write DVD-R:	1
Can write DVD-RAM:	1
Can read MRW:		1
Can write MRW:		1
Can write RAM:		1
$ cat /proc/mounts | grep sr0	#outputs nothing
$ lsblk | grep sr0
sr0                            11:0    1  1024M  0 rom
Is there any hope for this drive? I'll probably be getting another drive that's actually UHD friendly (this version number was deceiving), but it'd be nice to be able to resell this one in working condition. Any help is much appreciated :)
Drive info label
Drive info label
drive info.jpg (219.56 KiB) Viewed 10729 times
Re: WH14NS40: "No disc inserted" after re-flashing to stock firmware
Post by Billycar11 » Sat Sep 05, 2020 8:32 pm
You need to follow my UHD guide you ignored so much of it look at the usefull for recovery section.
And
Try this first
viewtopic.php?f=16&t=23023#p95457
Kepler
Post by Kepler » Sat Sep 05, 2020 9:57 pm
Billycar11 wrote: Sat Sep 05, 2020 8:32 pm You need to follow my UHD guide you ignored so much of it look at the usefull for recovery section.
And
Try this first
Thank you for the quick reply! Here's what I'm at after starting the steps in that post
Step 0: I downloaded sdf.bin, moved it to ~/.MakeMKV/sdf.bin, and started MakeMKV so it could be merged into _private_data.tar
Step 1: I picked MK/old/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin for the firmware
Step 2:
$ sdftool -d /dev/sr0 rawflash -i HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_SIK85CBLG033
yes
 100% Operation finished
Done successfully
It doesn't seem like it silently failed, because now MakeMKV says the firmware version is 1.02 (changed from 1.03 in the OP)
Post by Billycar11 » Sat Sep 05, 2020 10:23 pm
well you can just do it the dos flash way then follow the video and download martys img and us the old ns40 fw
