Dolby Vision and 1.15.1
lujan
Re: Dolby Vision and 1.15.1
Post by lujan » Sat Sep 05, 2020 1:44 pm
I can't drag the .m2ts files over to tsMuxeR from the disc as it doesn't work. Does this mean we have to rip with MakeMKV twice? Once to copy the disc and a 2nd time to create the .mkv file?
Post by SamuriHL » Sat Sep 05, 2020 1:59 pm
Anyone have pitch black uhd and converted it to mkv? Tried to play it on the shield like usual and it triggered dv but completely black screen with audio playing. It's a mel title. First one of my rips I've seen do this.
lujan
Post by lujan » Sat Sep 05, 2020 2:55 pm
Cannikin wrote: Fri Sep 04, 2020 11:34 pm
RESET_9999 wrote: Fri Sep 04, 2020 11:31 pm you don't need eac3to if you have the original m2ts file.
Where do you get the m2ts from? Is that inside BDMV somewhere? If so I assume you need an unencrypted backup?
How do you create the "unencrypted backup"?
jayper
Post by jayper » Sat Sep 05, 2020 3:02 pm
lujan wrote: Sat Sep 05, 2020 2:55 pm
Open MakeMKV > Ensure the desired disc drive is selected as the source in the UI > File > Backup > Check the "Decrypt video files" box > Select your output directory > Click OK
PlatypusW
Post by PlatypusW » Sat Sep 05, 2020 6:54 pm
SamuriHL wrote: Sat Sep 05, 2020 1:59 pm Anyone have pitch black uhd and converted it to mkv? Tried to play it on the shield like usual and it triggered dv but completely black screen with audio playing. It's a mel title. First one of my rips I've seen do this.
Just tried mine on shield - seemed to work fine. At least there wasn’t any black screen - jumped 10 mins in too, DV picture + audio.
lujan
Post by lujan » Sat Sep 05, 2020 6:56 pm
Thanks, it took a while but I finally got it working. I'm watching "Gemini Man" 4k in Dolby Vision and Atmos. I noticed that the .ts file is around 5 GB more than the .mkv file. Is this expected?
jayper
Post by jayper » Sat Sep 05, 2020 9:56 pm
My copy just arrived. I will test it out this weekend and let you know.
Post by SamuriHL » Sat Sep 05, 2020 10:15 pm
jayper wrote: Sat Sep 05, 2020 9:56 pm
Yea just curious if it works for others. Was weird. Ended up watching it in madvr tone mapped HDR cause I was too lazy to go put the disc in the UB820. LMAO
Cannikin
Post by Cannikin » Sat Sep 05, 2020 11:33 pm
Just checked mine: plays in HDR and DTS-HD MA on Plex on my Shield Pro just fine! I haven’t converted to TS or use the patched Exoplayer so no DV for me.
M2k80
Post by M2k80 » Sun Sep 06, 2020 12:10 am
are you using overscan on the shield? with 8.2 is a bug, if overscan is disabled it should work again. otherwise try to reboot the shield and try it again.
Post by RESET_9999 » Sun Sep 06, 2020 12:30 am
lujan wrote: Sat Sep 05, 2020 1:44 pm I can't drag the .m2ts files over to tsMuxeR from the disc as it doesn't work. ?
strange , works fine on mine.
lujan wrote: Sat Sep 05, 2020 1:44 pm Does this mean we have to rip with MakeMKV twice? Once to copy the disc and a 2nd time to create the .mkv file?
Well, thanks to my very fast NVME drive , it is faster this way than encoding the truehd track with eac3to.
I rip from disc to a folder bluray structure (which take most of the time) then create a DV mkv using the folder bluray structure as the source instead of ripping the disc again.
Then you use tsmuxer to mux the dv mkv with atmos from the original m2ts.
lujan
Post by lujan » Sun Sep 06, 2020 1:25 am
Sounds good, I'll rip in that order the next time.
arrbee99
Post by arrbee99 » Sun Sep 06, 2020 1:50 am
Can I just ask please if there are any Dolby Vision Demo files available (preferably mkv's) to test with the modified Exo Player.
Post by SamuriHL » Sun Sep 06, 2020 3:57 am
M2k80 wrote: Sun Sep 06, 2020 12:10 am
Nope, not using overscan. This is the ONLY title in my several dozen DV movies that doesn't work for me.
jayper
Post by jayper » Sun Sep 06, 2020 4:57 am
Just got a chance to test it out. Dolby Vision triggers, and video & audio playback are fine.
