Good evening people.
I'm trying to figure out if it is possible to convert (without quality loss) a FEL movie to MEL. I have some ideas about it and this is a first try.
In THIS archive you will find two files: the original file is the FEL one (generated starting from the ISO uploaded HERE by @RESET_9999), the MEL file was obtained by modifying the first.
If you feel like it, try both files. Personally I am interested in the tests carried out on devices that have proved capable of playing MEL files with profile 7 but not FEL files (Fire Stick 4K, some Android TVs, etc ...). With these latest devices the desired result should be:
FEL file -> HDR (or unplayable)
MEL file -> DV.
Please, in your feedback obviously indicate the outcome, the device and the player used (if you can, also use my version of ExoPlayer).
Thank you
MEL file -> DV.
Thank you
thank you yusesope for the great work as always.
I'll check out the files tonight.
Thanks for your work on this.
I have an LG C8.
The LG internal player freezes a lot with both FEL and MEL files, for some reason.
On the Fire TV Stick 4K (your ExoPlayer):
FEL file -> DV, black screen.
MEL file -> DV, plays fine.
Fantastic work yusesope! Here are my observations-yusesope wrote: ↑Fri Sep 04, 2020 4:11 pmGood evening people.
MEL file -> DV.
Thank you
Both files say unsupported file format in the internal media player.
FEL plays with HDR through Kodi+your latest exoplayer.
MEL plays and triggers DV through Kodi+your lastest exoplayer.
I'm playing these directly on my Android TV. (A cheap Indian brand, VU Cinema TV 50" with Dolby Vision).
Looking forward to a detailed method as I'd love to convert all my FEL titles into this format so I can play them directly on the TV.
Thanks Master, another prime from you.yusesope wrote: ↑Fri Sep 04, 2020 4:11 pmGood evening people.
MEL file -> DV.
Thank you
My results:
FIRESTICK TV 4K:
Plex....FEL_ST_DL triggers DV but black screen
MEL_ST_DL triggers and plays DV
Kodi 19.1 Alpha and Exoplayer_DolbyVision_DTS-HD_FFmpeg_4.2_01_08_2020_no_debug....same as Plex
UGOOS AM6 PLUS:
Plex...both files trigger and play DV
Kodi 18.8 Leia and Exoplayer as above both files trigger and play DV
APPLE ATV 4K:
Infuse app: both files play HDR
SHIELD PRO 2019:
All devices directly connected to Panasonic Tv's
Thank you for your time!
The results are what I was hoping for
 but It's too early to claim victory
  but It's too early to claim victory   !
 !The "final test" must be conducted on a full movie and not on a 60sec segment.
I hope cheaper devices don't run out of RAM due to a too large buffer.
We'll see.
There is currently no detailed method, just lines of code that only make sense to me...
In the next days/weeks I will release the 0.0.4 BETA version of my tool (I will update my original post HERE as always) so those interested can do all the tests they want and help me fix any bugs.
In the meantime maybe I'll write some technical posts to start a discussion and see if anyone has any ideas to validate/improve my logic.
				DaMacFunkin
Hi, i probably know the answe to this, but is there a way to reverse the DoVi created mp4?
For example de-mux the mp4 file and make a working MKV out of it?
Thank you.
Thank you.
It plays dual layer dual track in the form of mkv (dual layer single track) via kodi + Yusesope Exoplayer and .ts profile 4 (using Yusesope tool)
I've had success creating Dolby Vision + Lossless Audio TS files with dozens of movies (using eac3to + Yusescope's tool + tsMuxer 04.06) but I have run into an issue with Braveheart that has me stumped. All of the audio tracks, including the TrueHD Atmos track, require a delay of 2,169ms in order to sync up with the video.
Has anyone encountered this issue with other movies?
Are there any solutions to tackle this, such as removing the first 2,169ms of the video to make them sync up, or any way to add 2,169ms to the beginning of the .thd+ac3 file?
when you're extracting the bl and el files with eac3to, did you notice any errors? when there's an a/v sync issue after remuxing, it's possible that there may be errors in the original video layers.Bresnik17 wrote: ↑Sun Sep 06, 2020 12:00 amI've had success creating Dolby Vision + Lossless Audio TS files with dozens of movies (using eac3to + Yusescope's tool + tsMuxer 04.06) but I have run into an issue with Braveheart that has me stumped. All of the audio tracks, including the TrueHD Atmos track, require a delay of 2,169ms in order to sync up with the video.When I create the .TS file in tsMuxer with the audio delay set to 2,169ms, my 2019 Shield Pro reverts to HDR and transcodes down to DD+.
When I create the .TS file in tsMuxer with the audio delay set to zero, it plays in Dolby Vision & TrueHD Atmos on my Shield Pro but with the audio clearly a couple seconds ahead of the video.
No errors during the extraction and the issue appears to exist before that point. When I pull the original M2TS / MPLS files into eac3to and tsMuxer they already acknowledge the required delay:shawnc22 wrote: ↑Sun Sep 06, 2020 1:49 amwhen you're extracting the bl and el files with eac3to, did you notice any errors? when there's an a/v sync issue after remuxing, it's possible that there may be errors in the original video layers.Bresnik17 wrote: ↑Sun Sep 06, 2020 12:00 amI've had success creating Dolby Vision + Lossless Audio TS files with dozens of movies (using eac3to + Yusescope's tool + tsMuxer 04.06) but I have run into an issue with Braveheart that has me stumped. All of the audio tracks, including the TrueHD Atmos track, require a delay of 2,169ms in order to sync up with the video.When I create the .TS file in tsMuxer with the audio delay set to 2,169ms, my 2019 Shield Pro reverts to HDR and transcodes down to DD+.
eact3to:
1: Chapters, 22 chapters
2: h265/HEVC, 2160p24 /1.001 (16:9), 10 bits
3: h265/HEVC, 1080p24 /1.001 (16:9), 10 bits - Dolby Vision Enhancement Layer
4: TrueHD/AC3 (Atmos), 7.1 channels, 48kHz, 2168ms
(embedded: AC3 EX, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB)
5: AC3, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB, 2168ms
6: AC3, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB, 2168ms
7: AC3, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB, 2168ms
8: AC3 Surround, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB, 2168ms
9: Subtitle (PGS)
10: Subtitle (PGS)
11: Subtitle (PGS)
12: Subtitle (PGS)
tsMuxer:
Automatically sets the delay on all audio files to 2,169ms when imported.
				DaMacFunkin
I had this problem with Braveheart, I seem to remember ripping it either movie only ISO with DVDfab then processing that outputBresnik17 wrote: ↑Sun Sep 06, 2020 2:33 pmNo errors during the extraction and the issue appears to exist before that point. When I pull the original M2TS / MPLS files into eac3to and tsMuxer they already acknowledge the required delay:shawnc22 wrote: ↑Sun Sep 06, 2020 1:49 amwhen you're extracting the bl and el files with eac3to, did you notice any errors? when there's an a/v sync issue after remuxing, it's possible that there may be errors in the original video layers.Bresnik17 wrote: ↑Sun Sep 06, 2020 12:00 amI've had success creating Dolby Vision + Lossless Audio TS files with dozens of movies (using eac3to + Yusescope's tool + tsMuxer 04.06) but I have run into an issue with Braveheart that has me stumped. All of the audio tracks, including the TrueHD Atmos track, require a delay of 2,169ms in order to sync up with the video.When I create the .TS file in tsMuxer with the audio delay set to 2,169ms, my 2019 Shield Pro reverts to HDR and transcodes down to DD+.
eact3to:
9: Subtitle (PGS)
10: Subtitle (PGS)
11: Subtitle (PGS)
12: Subtitle (PGS)
tsMuxer:
