bl4ck
#2912
Post
by bl4ck » Wed Sep 02, 2020 12:37 pm
LG TV also need this remux to play DV?
#2913
Post
by RESET_9999 » Wed Sep 02, 2020 2:07 pm
bl4ck wrote: ↑Wed Sep 02, 2020 12:37 pm
use the mp4muxer for LG TV playback.. tsmuxer dual layer files will only work on the x700 and the oppo.
MastaG
#2914
Post
by MastaG » Wed Sep 02, 2020 3:05 pm
RESET_9999 wrote: ↑Wed Sep 02, 2020 2:07 pm
I merge both layers into a single hevc using yusesope's tool.
Then I add the hevc file and Dolby truehd audio using tsmuxer into a single TS container.
It will play fine on LG using Emby because you can select core ac3 5.1 audio for playback (which is part of the truehd track).
I guess that's the best way for preservation because unlike mp4muxer you can also include the he audio (and Atmos).
Krinski
#2915
Post
by Krinski » Wed Sep 02, 2020 5:49 pm
Guys, how do I do / what are the commands to redo a mkv remux generated by MakeMKV, but keep Dolby Vision data, using ffmpeg? Is this too complicated, or is it still not possible?
I know that MKVToolNix currently maintains the BlockAdditional data track. But I would like to do it for ffmpeg.
Thank you.
Jordbrett
#2916
Post
by Jordbrett » Thu Sep 03, 2020 12:58 am
When trying to run yusesope's tool on Mac I get a syntax error. Is there something I need to do first to get it to run? Thanks
#2917
Post
by shawnc22 » Thu Sep 03, 2020 6:25 pm
For those still following, apparently the minix u22-xj just received a firmware update with much improved DV support (
https://theminixforum.com/index.php?thr ... post-26931 and subsequent posts). Looks like dual-layer (maybe dual track?) profile 7 mp4s are working. MKVs with the native player seems to be also supported as well. I'm not sure if this is the same support that already exists on the ugoos player since its the same chipset, but the next question of course is whether the colors are being displayed correctly.
kazuma
#2918
Post
by kazuma » Thu Sep 03, 2020 10:43 pm
i'm turned to the M9702. because there gonna not be a better solution that plays DV correct with HD-Audio. i doubt how far DV plays correct with all the muxes in this topic. i mean the colors, single layer etc. beside that M9702 (oppo203) is really a beast that does everything like DV, HDR10+, Atmos, DTS:X. I think there not will be a mediaplayer like this. if there is? you pay €600+. i'm also negatif about the future of DV with mkv, kodi and other stuff.
kazuma on Thu Sep 03, 2020 10:51 pm, edited 1 time in total.
#2919
Post
by RESET_9999 » Thu Sep 03, 2020 10:51 pm
kazuma wrote: ↑Thu Sep 03, 2020 10:43 pm
i'm turned to the M9702. because there gonna not be a better solution that plays DV correct with HD-Audio. i doubt how far DV plays correct with all the muxes in this topic. i mean the colors etc. beside that M9702 (oppo203) is really a beast that does everything like DV, HDR10+, Atmos, DTS:X. I think there not will be a mediaplayer like this. if there is? you pay €600+.
mmm, renewed x700 on amazon is only 157USD and can do DV + HD audio just fine. Plus no cinavia...
https://www.amazon.com/Sony-UBP-X700-Bl ... 371&sr=8-4
kazuma
#2920
Post
by kazuma » Thu Sep 03, 2020 10:52 pm
RESET_9999 wrote: ↑Thu Sep 03, 2020 10:51 pm
with iso, bdmv folders? uncompressed/muxed without tsmuxer/mp4 or ts?
#2921
Post
by RESET_9999 » Thu Sep 03, 2020 10:53 pm
kazuma wrote: ↑Thu Sep 03, 2020 10:52 pm
with iso, bdmv folders? uncompressed/muxed without tsmuxer?
Dual layer TS remux.. I dont care about bluray menu so it's all good for me
kazuma
#2922
Post
by kazuma » Thu Sep 03, 2020 10:58 pm
RESET_9999 wrote: ↑Thu Sep 03, 2020 10:53 pm
it's not about the menu's, but the thing about ''untouched'' = the safest way without doubts to play DV. but i keep following this thread. it's very interesting what people being capable of
#2923
Post
by RESET_9999 » Thu Sep 03, 2020 11:25 pm
kazuma wrote: ↑Thu Sep 03, 2020 10:58 pm
Safest? Are you suggesting that mp4 or ts remux are not the real deal?
I have compared the dual-layer profile 7 remux ( mp4 or TS) with bluray disc and it is identical in every aspect. Just like an MKV remux of any bluray.
Yes, there might be some question about the single layer (rpu + EL) files but definitely not with the dual-layer profile 7 files.
kazuma
#2924
Post
by kazuma » Thu Sep 03, 2020 11:49 pm
RESET_9999 wrote: ↑Thu Sep 03, 2020 11:25 pm
yeah, with the eye there is no difference. i also say that before in this thread. but i'm not sure if that is enough? what happens on the background in technical way? i think we shall only know with professional tools...
#2925
Post
by RESET_9999 » Thu Sep 03, 2020 11:58 pm
kazuma wrote: ↑Thu Sep 03, 2020 11:49 pm
I agree..
This may not be a professional tool but I think if there was a difference in colors and brightness, my camera would capture it.
see this comparison:
https://screenshotcomparison.com/comparison/6043
I did this comparison with many movies and never spotted any difference.
