M2k80
Post
by M2k80 » Wed Aug 26, 2020 8:11 pm
got the shield update, on exoplayer test version from yuseope, the first 2 demo videos now have strange colors, unplayable (P4_LG_Dolby_trailer_4k_Demo and P5_Dolby_Amaze)
steffenmanden
Post
by steffenmanden » Thu Aug 27, 2020 11:02 am
Cannikin wrote: Wed Aug 26, 2020 5:44 pm
steffenmanden wrote: Wed Aug 26, 2020 4:10 pm
Plex uses ffmpeg primarily, so Exoplayer is only for format support on Android. We rarely see plex doing features for one platform only
Ahhh most of the threads always talk about a custom version of ExoPlayer "unlocking" DV in Plex on the Shield (or at least the Plex plugin for Kodi). What would be needed to support DV in the official Plex app on the Shield?
Plex uses Exoplayer, but also have a lot of custom stuff added on the side. So that means that they cant just merge in whatever as it may break their other stuff. Them pulling in new updates requires them to have to crosscheck all their systems and maybe even make changes/additions to make sure everything works.
Simply put: They don't just use Exoplayer as-is, they use it as a base and then worked around it. This is the reason why they can't just update all the time
kcxserver
Post
by kcxserver » Fri Aug 28, 2020 10:00 am
M2k80 wrote: Wed Aug 26, 2020 8:11 pm
I also have 8.2 on it. I can't watch that. Everything is going as it was before. Demofiles and MakeMKV rips are played correctly.
lexyz
Post
by lexyz » Fri Aug 28, 2020 8:31 pm
kcxserver wrote: Fri Aug 28, 2020 10:00 am
Happens randomly
https://imgur.com/8j6EG9Y
Tomas
Post
by Tomas » Sat Aug 29, 2020 1:42 pm
Hi, I want to ask what is the best quality to do a Dolby Vision remux. In mkv or .TS? Thank you very much.
Dinst
Post
by Dinst » Mon Aug 31, 2020 5:16 pm
Tomas wrote: Sat Aug 29, 2020 1:42 pm
TS and MKV are both containers so they make no difference to quality, MKV is preferable as it supports chapters and subtitles.
flashback8
Post
by flashback8 » Mon Aug 31, 2020 9:19 pm
I seem to recall reading somewhere that it is possible for frames to get dropped when muxing to MKV. Has to do with timing, as I recall. (Somebody please correct me if I'm wrong.) So, strictly speaking, TS is ideal, if bloated. This is also not a problem that a vast majority of people will ever notice, assuming it's even real. I don't think I've ever come across an MKV with dropped frames that came from a proper rip, and I've ripped a bunch of discs.
Balthazar2k4
Post
by Balthazar2k4 » Wed Sep 02, 2020 8:40 pm
MakeMKV will drop frames to maintain audio/video sync. It isn't something that one would necessarily see during playback though. Generally, discs with extensive seamless branching exhibit the issue the most.
kavie87
Post
by kavie87 » Thu Sep 03, 2020 1:35 am
I have a quick question. I have mounted my NAS onto Kodi via NFS will that work? or will I need to mount the NAS onto the Shield?
Balthazar2k4
Post
by Balthazar2k4 » Thu Sep 03, 2020 2:13 am
kavie87 wrote: Thu Sep 03, 2020 1:35 am
I wouldn't think it would matter. As long as Kodi can see the files on the Shield it should work.
DaMacFunkin
Post
by DaMacFunkin » Thu Sep 03, 2020 6:32 am
Dinst wrote: Mon Aug 31, 2020 5:16 pm
Mmm, TS and M2TS support subtitles too...
If you are ripping for playback on the Oppo clone or jail broken Oppo you could rip to Movie only ISO, this will keep original profile Dolby Vision, Atmos, Chapters and Subtitles, on the Oppo you can even assign a Movie thumbnail .
kavie87
Post
by kavie87 » Thu Sep 03, 2020 8:45 am
Figured I’ll change settings on my NAS so I can mount direct onto shield. Has someone made a video how to add exoplayer onto shield so it plays Dolby vision?
codeXRes
Post
by codeXRes » Thu Sep 03, 2020 12:41 pm
Slightly off-topic but anyone here tried Watchmen Ultimate edition?
Makemkv managed to create the mkv file which triggers DV with Kodi on modded exoplyer. But tsmuxer latest nightly errors with the following:
tsMuxeR finished with error code -1.
B-pyramid level 2 detected. Shift DTS to 3 frames
Have anyone seen this before?
DaMacFunkin
Post
by DaMacFunkin » Thu Sep 03, 2020 2:36 pm
codeXRes wrote: Thu Sep 03, 2020 12:41 pm
It isn’t an error that will stop you playing the file, it is a correction, I’ve seen it on loads of files over the years with TSmuxer.
