Weird extra audio track on Criterion Brazil BD
sremick
Post by sremick »
So tonight I ripped my blu-ray Criterion edition of Brazil (1985). In MakeMKV (1.15.2) when I open the disk pre-rip it it shows a DTS-MA track, a mono track (director commentary), and the subtitles track.
But then after ripping, opening the resulting MKV file in VLC shows two DTS-MA audio tracks (along with the mono commentary track and subtitles stream). In listening to them, I haven't been able to hear any apparent difference but I'm confused how the ripped file ended up with an additional (dupe?) audio track. Any thoughts?
Re: Weird extra audio track on Criterion Brazil BD
By default, MakeMKV will extract the "core audio" from certain "lossless" tracks into a more-compatible "lossy" track. The metadata remains the same.
In other words, if you have a 7.1 DTS-MA HD track to start with, you'll also have a lossy 7.1 DTS track that more players can handle. TrueHD will have a standard AC3 track extracted.
sremick
Post by sremick »
Woodstock wrote: Thu Sep 03, 2020 2:24 am By default, MakeMKV will extract the "core audio" from certain "lossless" tracks into a more-compatible "lossy" track. The metadata remains the same.
Ok, I'm with you so far. But is there any way to determine which is which? Both say (in VLC):
Codec: DTS Audio (dts)
Language: English
Type: Audio
Channels: Stereo
Sample rate: 48000 Hz
Bits per sample: 32
VLC doesn't seem to differentiate between DTS and DTS-MA. A tool like Mediainfo (https://en.wikipedia.org/wiki/MediaInfo) can tell the difference however.
sremick
Post by sremick »
dcoke22 wrote: Thu Sep 03, 2020 2:37 pm VLC doesn't seem to differentiate between DTS and DTS-MA. A tool like Mediainfo (https://en.wikipedia.org/wiki/MediaInfo) can tell the difference however.
Perfect, that helped. Thank you! (it was the first audio track)
(GUI version of Mediainfo seems problematic... bummer. But commandline version worked fine)
Audio #1
Format                                   : DTS XLL
Commercial name                          : DTS-HD Master Audio
Duration                                 : 2 h 23 min
Bit rate                                 : 2 115 kb/s
Channel(s)                               : 2 channels
Stream size                              : 2.12 GiB (5%)
Title                                    : Stereo
Audio #2
Format                                   : DTS
Bit rate                                 : 1 509 kb/s
Channel layout                           : Lt Rt
Stream size                              : 1.51 GiB (4%)
Title                                    : Stereo
preserve
Post by preserve »
And if you expand the title and the tracks in MakeMKV, you can deselect the lossy core before you rip if you don’t have a need for it.
Using: ASUS BW-16D1HT 3.00
