Can't rip to another drive/mount point
bmillham
Re: Can't rip to another drive/mount point
Post by bmillham »
ThePeoplesBards wrote:
Sun Aug 30, 2020 7:47 pm
Came across this thread while searching for a solution to the same problem yesterday. I figured out a suitable workaround in case anyone is still dealing with this:
I can confirm this is not a permissions issue, it seems that MakeMKV is only "aware" of certain root directories no matter who owns it. I.e. you can search for a disc in '/bin/' even though this is owned by root however other root directories like '/media/' don't show up in MakeMKV's file explorer.
I use MakeMKV to save to /media/XXX and /mnt/XXX all the time and never have a problem on my Linux Mint systems.
I install by downloading and building from source. I don't use Flatpack to install, so maybe it has something to do with running in a container. You can't really blame MakeMKV for that.
donut
Post by donut »
+1 on running from compiled source with no such issue.
Enzo2000
Post by Enzo2000 »
I fixed this simply by going to ubuntu software > search for makemkv > in makemkv page klick "permissions" > allow "Read / write on removable storage devices.
should be something similar on mint. :D
manchild
Post by manchild »
Enzo2000 wrote:
Sat Sep 12, 2020 2:04 pm
That fixed it for me in Xubuntu too! Thanks!
tomty89
Post by tomty89 »
You can always go from "/" (a.k.a. "root filesystem") down to the mountpoint where the drive is mounted. (If you are unsure, `lsblk -f` and/or `findmnt` can help.) If you cannot, it's a permission problem (read and/or execute down the path). And whether you can rip to the drive at the end is another permission (write) problem (of the filesystem on that drive, or maybe mount options if it's not a unix one).
Whether you can see it on the "side bar" of the "picker" depends on various things IIRC, udisks(2) configuration or maybe even polkit policy, or even how it was mounted or whether it's considered "internal"/"non-removable". (These can get very distro-specific.)
