Possible Flash error
Markdotjames
Post by Markdotjames » Mon Aug 31, 2020 5:14 pm
I just purchased a new wh16ns40 and think i may have flashed it with the WH14 firmware using the SDFtool, is that possible to do? can it be checked? if i did can it be rectified?
It did finish and say it was successful by the way.
many thanks
Mark
Just for info the two discs i have just tried both came up with the following error:
M2TS hash check error
Almost each Blu-ray disc contains so called content hash file. Designed as part of AACS protection, this file has a very useful property exploited by MakeMKV - having this file it is possible to verify that M2TS file loaded from the disc is not corrupt. If present on the disc, MakeMKV computes and compares hashes of M2TS files automatically. When hashes do not match, you get this error.
Hash check error essentially means that the drive was unable to read the file from the disc, and what more, instead of raising the read error it silently returned corrupted data. Getting this error usually means a failing Blu-ray drive.
One worked one failed.
Re: Possible Flash error
Post by Billycar11 » Mon Aug 31, 2020 7:00 pm
Your discs are defective or dirty or your drive is defective
Markdotjames
Post by Markdotjames » Mon Aug 31, 2020 8:09 pm
so it is definitely not due to my flashing then ?
Post by Billycar11 » Mon Aug 31, 2020 8:22 pm
Yes it is not due to your flashing
You should reflash to WH16NS60 though it better in everyway
Markdotjames
Post by Markdotjames » Mon Aug 31, 2020 8:28 pm
when i try to reflash using the correct file it states:
You cannot flash your drive to this firmware file directly, please select the appropriate MK firmware file for your drive and try again.
I am trying to flash this file:
HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440.bin
Post by Billycar11 » Mon Aug 31, 2020 8:38 pm
Don't go to WH16NS40 go to WH16NS60! As I said and as my guide says. If the Marty's sdf tool won't let you do it with the cmd and my video or contact me about a remote flash.
But again this is not going to fix your hash errors
Markdotjames
Post by Markdotjames » Mon Aug 31, 2020 8:44 pm
In that case i will return the drive and purchase a replacement, is it easy to return the stock firmware?
I thank you very very much for your support.
When the new one arrives can i utilise your remote flash option please?
Post by Billycar11 » Mon Aug 31, 2020 8:50 pm
I wouldn't worry about going back to stock fw they are not going to check.
It might be a good idea to check with another new disc to make sure it's the drive
Yes you can email me anytime for a remote flash.
Post by d00zah » Mon Aug 31, 2020 9:31 pm
Went through this exercise just yesterday... cross-flash WH16NS40 > WH16NS60 (x2).
'sdftool_flasher.exe' refused, as the OP reported, for some reason
ASUS_ODD_FW_Changer_(Modified).exe, on the other hand, worked 1st try. YMMV
Markdotjames
Post by Markdotjames » Mon Aug 31, 2020 10:09 pm
Well, I managed to flash the WH16NS60 firmware as you recommend and its now worked perfectly on both the disks with no errors, I am now confused...
Post by Billycar11 » Mon Aug 31, 2020 10:43 pm
trust me i have been there before the drive will get read errors again if the discs were new clean and scratch free.
or if you cleaned the discs in between the flashing that may have been your problem all along
Markdotjames
Post by Markdotjames » Mon Aug 31, 2020 11:55 pm
Thanks, I have ordered the ASus one anyway.
Thanks again for all your help.
