If has nothing to do with a TV brand. It's a known issue with Shield with dual-layer DV files. Although, the recent update fixed the issue with profile 5 used for streaming services. Profile 4/6 support is undocumented and never been advertised by Nvidia. I doubt they are going to fix it.lexyz wrote: ↑Sat Aug 29, 2020 5:49 amWhat TV do you have? Panasonic GZ2000 oled right?ragico wrote: ↑Fri Aug 28, 2020 10:35 pmProblems with shield pro 2019. I was initially concentrated on the infamous red push problem. Today I saw other movies and;
The Matrix initial scenes look light blue instead of beautiflul green.
This happens both with the kodi/exoplayer/mkv and with plex ts profile 4 and 5.
Very bad,
So such issue not only Sony-related
I suggest you to fill report for nVidia - more data, more chances for quicker fix.
Settings->Device Preferences->About->Send feedback to Nvidia
good to know. I think I missed that one and I'll get it right now. thanks for sharing.
definitely looks like an issue with file that contains an EL and not TV brand related.mulucy wrote: ↑Sat Aug 29, 2020 1:58 pmIf has nothing to do with a TV brand. It's a known issue with Shield with dual-layer DV files. Although, the recent update fixed the issue with profile 5 used for streaming services. Profile 4/6 support is undocumented and never been advertised by Nvidia. I doubt they are going to fix it.
I really am uncapable to explain what's happening:ragico wrote: ↑Fri Aug 28, 2020 10:35 pmProblems with shield pro 2019. I was initially concentrated on the infamous red push problem. Today I saw other movies and;
Very bad,
Today, after 2 shield reboots, The Matrix DV initial scenes, played in perfect colours (berautiful green) in mkv via kodi, exoplayer and in plex via ts profile 5
Alleluja
There are few issues with EL files playback on Shield so far:
2 probably was prior 8.2
- "Red push" - excessive red spots in some frames. Example - https://imgur.com/a/oXwAoOj
- Clipping on DVLL TV at very bright scenes. Example - https://slow.pics/c/I0k7fFq4 pay attention on snow detais.
- Dolby vision output in wrong colorspace. Example https://imgur.com/a/w1z1Kjg . Triggered randomy, without any oblivious pattern. Reboot to fix
- Overall instability on DV playback. You can notice some flashy picture changes after FF or RW mkv in exoplayer
- Some PGS subtitles doesn't render properly.
My first post here. I have an OLED B7P panel, and it worked just fine! I'm really glad I found this thread.
The question is, does anybody knows any other player that supports DV from a USB drive other than Oppo? LG UBKM9 or UBK90 models, for instance?
We are all thanking Yusecope for creating tools and investing time here to make our lives better. But the real " thank you " will be to helping to invest in a solid DV capable hardware since he does not own any, AFAIK.
I am calling out everyone here to put our efforts together to buy him a nice OLED TV with Shield Pro and Blu Ray player such as X700 ( or even better, Oppo)
Then put up a donation link.
I'm happy to donate
I'm happy to donate
Sony X700 or Oppo China Clone
mulucy wrote: ↑Sun Aug 30, 2020 12:04 amWe are all thanking Yusecope for creating tools and investing time here to make our lives better. But the real " thank you " will be to helping to invest in a solid DV capable hardware since he does not own any, AFAIK.
You forgot "a nice Ferrari"!
Seriously, thank you for the idea @mulucy but ABSOLUTELY NOT!
The lines of code you are using are, for the most part, the result of a lockdown. Away 1000 Km from my family, with the fear of losing my job, with the anxiety for university exams, writing a few lines of code helped me to spend this period of forced closure peacefully. It is not a job but an "advanced Sudoku" and I would feel bad if I received money for a hobby. Money must be donated to people in need or in exchange for hard work! Thank you both but I just need a "thank you" and a little mention if someone wants to implement my code\logic.
Thanks for understanding.
blackjack4494
Brief information. I have no Dolby vision nor Atmos but my brother does. Am not really interested in reading all 194 pages.
So is there a way now to combine DV and Atmos into one single container mkv and or mp4?
Would be nice to have some dedicated locked thread with information only (no discussion) or at least an updated first post to current situation.
I heard that plex or emby is supporting both in one go. Personally I use jellyfin. Anyway it should be quite easy to add support for DV + Atmos in jellyfin if there isn't a one container solution already. You can feed individual streams (video, audio, subtitle) within the jellyfin server to the client. I believe that is how emby/plex is implementing it as well.
yes but that would be ''fake'' dolby vision. You need to remux using the latest tsMuxer in order to get real DV
https://bintray.com/justdan96/tsMuxer/t ... htly#files
