Need help with libredrive
Cakeandpie
#1 Post by Cakeandpie » Sun Aug 30, 2020 12:19 am
I have a USB LG BP50NB40 blu-ray drive that I want to have libredrive enabled on it. How do you accomplish this? The SVC is NB50 and it was manufactured in 2019. The firmware revision is 1.01
Re: Need help with libredrive
#2 Post by Woodstock » Sun Aug 30, 2020 12:57 am
Does MakeMKV recognize it as a potential LD? There should be a section of the info window dedicated to LibreDrive if it can be done. Both the drive and controller (USB in this case) need to be correct.
Cakeandpie
#3 Post by Cakeandpie » Sun Aug 30, 2020 1:02 am
Harware support: Yes
Firmware support: No
Firmware version: 1.01
#4 Post by MartyMcNuts » Sun Aug 30, 2020 1:04 am
1. To enable LibreDrive, you can use the sdftool flasher to flash it to BP50NB40-NB50 1.01-MK firmware.
2. If you also want UHD capabilities, you can then flash it from BP50NB40-NB50 1.01-MK to BP60NB10 1.00-MK firmware.
zimberto
#5 Post by zimberto » Sun Aug 30, 2020 1:06 am
Did you try searching? viewtopic.php?f=19&t=20956
Cakeandpie
#6 Post by Cakeandpie » Sun Aug 30, 2020 1:29 am
Could you provide a link to the flasher please? Thanks.
zimberto
#7 Post by zimberto » Sun Aug 30, 2020 1:40 am
Did you try searching? viewtopic.php?f=16&t=18933
#8 Post by d00zah » Sun Aug 30, 2020 2:08 am
#9 Post by MartyMcNuts » Sun Aug 30, 2020 3:25 am
Search forum for "sdftool flasher" and you will find it. Or click the link provided by @d00zah.
You will also need the firmware pack. If you haven't already downloaded the firmware pack, you can grab it from viewtopic.php?f=19&t=19113
Cakeandpie
#10 Post by Cakeandpie » Fri Sep 04, 2020 12:22 am
Okay, thanks. Also I didn't mention that this is an external USB blu-ray drive, not an internal one. Is that important?
#11 Post by MartyMcNuts » Fri Sep 04, 2020 1:12 am
Nope, not at all. I have flashed plenty of BP50NB40's!! Follow the steps I provided and you should be fine.
