Need help with libredrive
Cakeandpie
I have a USB LG BP50NB40 blu-ray drive that I want to have libredrive enabled on it. How do you accomplish this? The SVC is NB50 and it was manufactured in 2019. The firmware revision is 1.01
Re: Need help with libredrive
Does MakeMKV recognize it as a potential LD? There should be a section of the info window dedicated to LibreDrive if it can be done. Both the drive and controller (USB in this case) need to be correct.
Cakeandpie
Harware support: Yes
Firmware support: No
Firmware version: 1.01
1. To enable LibreDrive, you can use the sdftool flasher to flash it to BP50NB40-NB50 1.01-MK firmware.Cakeandpie wrote: Sun Aug 30, 2020 12:19 am I have a USB LG BP50NB40 blu-ray drive that I want to have libredrive enabled on it. How do you accomplish this? The SVC is NB50 and it was manufactured in 2019. The firmware revision is 1.01
2. If you also want UHD capabilities, you can then flash it from BP50NB40-NB50 1.01-MK to BP60NB10 1.00-MK firmware.
zimberto
Did you try searching? viewtopic.php?f=19&t=20956
Cakeandpie
Could you provide a link to the flasher please? Thanks.MartyMcNuts wrote: Sun Aug 30, 2020 1:04 am1. To enable LibreDrive, you can use the sdftool flasher to flash it to BP50NB40-NB50 1.01-MK firmware.Cakeandpie wrote: Sun Aug 30, 2020 12:19 am I have a USB LG BP50NB40 blu-ray drive that I want to have libredrive enabled on it. How do you accomplish this? The SVC is NB50 and it was manufactured in 2019. The firmware revision is 1.01
zimberto
Did you try searching? viewtopic.php?f=16&t=18933
Or... SDFtool Flasher
Search forum for "sdftool flasher" and you will find it. Or click the link provided by @d00zah.Cakeandpie wrote: Sun Aug 30, 2020 1:29 amCould you provide a link to the flasher please? Thanks.MartyMcNuts wrote: Sun Aug 30, 2020 1:04 am1. To enable LibreDrive, you can use the sdftool flasher to flash it to BP50NB40-NB50 1.01-MK firmware.Cakeandpie wrote: Sun Aug 30, 2020 12:19 am I have a USB LG BP50NB40 blu-ray drive that I want to have libredrive enabled on it. How do you accomplish this? The SVC is NB50 and it was manufactured in 2019. The firmware revision is 1.01
You will also need the firmware pack. If you haven't already downloaded the firmware pack, you can grab it from viewtopic.php?f=19&t=19113
Cakeandpie
Okay, thanks. Also I didn't mention that this is an external USB blu-ray drive, not an internal one. Is that important?MartyMcNuts wrote: Sun Aug 30, 2020 3:25 amSearch forum for "sdftool flasher" and you will find it. Or click the link provided by @d00zah.Cakeandpie wrote: Sun Aug 30, 2020 1:29 amCould you provide a link to the flasher please? Thanks.MartyMcNuts wrote: Sun Aug 30, 2020 1:04 am
Nope, not at all. I have flashed plenty of BP50NB40's!! Follow the steps I provided and you should be fine.Cakeandpie wrote: Fri Sep 04, 2020 12:22 amOkay, thanks. Also I didn't mention that this is an external USB blu-ray drive, not an internal one. Is that important?MartyMcNuts wrote: Sun Aug 30, 2020 3:25 amSearch forum for "sdftool flasher" and you will find it. Or click the link provided by @d00zah.
