Need help with libredrive
Cakeandpie
#1 Post by Cakeandpie » Sun Aug 30, 2020 12:19 am
I have a USB LG BP50NB40 blu-ray drive that I want to have libredrive enabled on it. How do you accomplish this? The SVC is NB50 and it was manufactured in 2019. The firmware revision is 1.01
Re: Need help with libredrive
#2 Post by Woodstock » Sun Aug 30, 2020 12:57 am
Does MakeMKV recognize it as a potential LD? There should be a section of the info window dedicated to LibreDrive if it can be done. Both the drive and controller (USB in this case) need to be correct.
Cakeandpie
#3 Post by Cakeandpie » Sun Aug 30, 2020 1:02 am
Harware support: Yes
Firmware support: No
Firmware version: 1.01
#4 Post by MartyMcNuts » Sun Aug 30, 2020 1:04 am
Cakeandpie wrote: Sun Aug 30, 2020 12:19 am I have a USB LG BP50NB40 blu-ray drive that I want to have libredrive enabled on it. How do you accomplish this? The SVC is NB50 and it was manufactured in 2019. The firmware revision is 1.01
1. To enable LibreDrive, you can use the sdftool flasher to flash it to BP50NB40-NB50 1.01-MK firmware.
2. If you also want UHD capabilities, you can then flash it from BP50NB40-NB50 1.01-MK to BP60NB10 1.00-MK firmware.
zimberto
#5 Post by zimberto » Sun Aug 30, 2020 1:06 am
Did you try searching? viewtopic.php?f=19&t=20956
Cakeandpie
#6 Post by Cakeandpie » Sun Aug 30, 2020 1:29 am
MartyMcNuts wrote: Sun Aug 30, 2020 1:04 am
Could you provide a link to the flasher please? Thanks.
zimberto
#7 Post by zimberto » Sun Aug 30, 2020 1:40 am
Cakeandpie wrote: Sun Aug 30, 2020 1:29 am Could you provide a link to the flasher please? Thanks.
Did you try searching? viewtopic.php?f=16&t=18933
#8 Post by d00zah » Sun Aug 30, 2020 2:08 am
#9 Post by MartyMcNuts » Sun Aug 30, 2020 3:25 am
Search forum for "sdftool flasher" and you will find it. Or click the link provided by @d00zah.
You will also need the firmware pack. If you haven't already downloaded the firmware pack, you can grab it from viewtopic.php?f=19&t=19113
Cakeandpie
#10 Post by Cakeandpie » Fri Sep 04, 2020 12:22 am
MartyMcNuts wrote: Sun Aug 30, 2020 3:25 am
Okay, thanks. Also I didn't mention that this is an external USB blu-ray drive, not an internal one. Is that important?
#11 Post by MartyMcNuts » Fri Sep 04, 2020 1:12 am
Cakeandpie wrote: Fri Sep 04, 2020 12:22 am
Nope, not at all. I have flashed plenty of BP50NB40's!! Follow the steps I provided and you should be fine.
