Mr_Orange
Post by Mr_Orange »
daddy wrote:
Sat Aug 29, 2020 6:48 am
The largest FEL i ever see is Universal Soldier.
Universal soldier DV layer have a higher bitrate (16 Mbps) for a total bitrate of the movie equal to 100 Mbps.
DISC INFO:
Disc Title:     Universal.Soldier.1992.MULTI.COMPLETE.UHD.BLURAY-COASTER
Disc Size:      88,151,888,864 bytes
Protection:     AACS2
Extras:         Ultra HD
BDInfo:         0.7.5.6 (compatible layout created by DVDFab 11.0.5.7)
PLAYLIST REPORT:
Length:                 1:43:20.416 (h:m:s.ms)
Total Bitrate:          100.24 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec                   Bitrate             Description
MPEG-H HEVC Video       64000 kbps          2160p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020
* MPEG-H HEVC Video     16036 kbps (20.04%) 1080p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / Dolby Vision FEL / BT.2020
AUDIO:
Codec                           Language        Bitrate         Description
DTS-HD Master Audio             German          3892 kbps       5.1 / 48 kHz / 3892 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             English         4287 kbps       5.1 / 48 kHz / 4287 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             French          3524 kbps       5.1 / 48 kHz / 3524 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             English         1508 kbps       2.0 / 48 kHz / 1508 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 24-bit)
DTS-HD Master Audio             English         1616 kbps       2.0 / 48 kHz / 1616 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           German          18.982 kbps
Presentation Graphics           English         26.278 kbps
Presentation Graphics           French          14.994 kbps
Presentation Graphics           German          25.921 kbps
Presentation Graphics           French          25.97 kbps
Presentation Graphics           German          19.233 kbps
Presentation Graphics           German          0.11 kbps
Presentation Graphics           French          0.102 kbps
Where do you obtain this information from? MakeMKV or another tool?
mulucy
Post by mulucy »
lexyz wrote:
Sat Aug 29, 2020 5:49 am
ragico wrote:
Fri Aug 28, 2020 10:35 pm
Problems with shield pro 2019. I was initially concentrated on the infamous red push problem. Today I saw other movies and;
The Matrix initial scenes look light blue instead of beautiflul green.
This happens both with the kodi/exoplayer/mkv and with plex ts profile 4 and 5.
Very bad,
What TV do you have? Panasonic GZ2000 oled right?
So such issue not only Sony-related
I suggest you to fill report for nVidia - more data, more chances for quicker fix.
Settings->Device Preferences->About->Send feedback to Nvidia
If has nothing to do with a TV brand. It's a known issue with Shield with dual-layer DV files. Although, the recent update fixed the issue with profile 5 used for streaming services. Profile 4/6 support is undocumented and never been advertised by Nvidia. I doubt they are going to fix it.
[/code]
good to know. I think I missed that one and I'll get it right now. thanks for sharing.
mulucy wrote:
Sat Aug 29, 2020 1:58 pm
definitely looks like an issue with file that contains an EL and not TV brand related.
ragico
Post by ragico »
Very bad,
I really am uncapable to explain what's happening:
Today, after 2 shield reboots, The Matrix DV initial scenes, played in perfect colours (berautiful green) in mkv via kodi, exoplayer and in plex via ts profile 5
Alleluja
lexyz
Post by lexyz »
There are few issues with EL files playback on Shield so far:
  1. "Red push" - excessive red spots in some frames. Example - https://imgur.com/a/oXwAoOj
  2. Clipping on DVLL TV at very bright scenes. Example - https://slow.pics/c/I0k7fFq4 pay attention on snow detais.
  3. Dolby vision output in wrong colorspace. Example https://imgur.com/a/w1z1Kjg . Triggered randomy, without any oblivious pattern. Reboot to fix
  4. Overall instability on DV playback. You can notice some flashy picture changes after FF or RW mkv in exoplayer
  5. Some PGS subtitles doesn't render properly.
3, 4 and 5 are new after 8.2 update
2 probably was prior 8.2
phbart
Post by phbart »
My first post here. I have an OLED B7P panel, and it worked just fine! I'm really glad I found this thread.
The question is, does anybody knows any other player that supports DV from a USB drive other than Oppo? LG UBKM9 or UBK90 models, for instance?
mulucy
Post by mulucy »
We are all thanking Yusecope for creating tools and investing time here to make our lives better. But the real " thank you " will be to helping to invest in a solid DV capable hardware since he does not own any, AFAIK.
I am calling out everyone here to put our efforts together to buy him a nice OLED TV with Shield Pro and Blu Ray player such as X700 ( or even better, Oppo)
MastaG
Post by MastaG »
Then put up a donation link.
I'm happy to donate :)
mulucy
Post by mulucy »
MastaG wrote:
Sun Aug 30, 2020 1:06 am
I have no idea, never done donation links. If someone willing to come up with an idea, I will be very happy to contribute
mulucy
Post by mulucy »
phbart wrote:
Sat Aug 29, 2020 8:44 pm
Sony X700 or Oppo China Clone
yusesope
Post by yusesope »
mulucy wrote:
Sun Aug 30, 2020 12:04 am
You forgot "a nice Ferrari"! :lol:
Seriously, thank you for the idea @mulucy but ABSOLUTELY NOT!
The lines of code you are using are, for the most part, the result of a lockdown. Away 1000 Km from my family, with the fear of losing my job, with the anxiety for university exams, writing a few lines of code helped me to spend this period of forced closure peacefully. It is not a job but an "advanced Sudoku" and I would feel bad if I received money for a hobby. Money must be donated to people in need or in exchange for hard work! Thank you both but I just need a "thank you" and a little mention if someone wants to implement my code\logic.
Thanks for understanding.
phbart
Post by phbart »
mulucy wrote:
Sun Aug 30, 2020 1:27 am
Thanks.
Too bad those LG models don't support it. I just found one second-hand in excellent condition for a very good price.
blackjack4494
Post by blackjack4494 »
Brief information. I have no Dolby vision nor Atmos but my brother does. Am not really interested in reading all 194 pages.
So is there a way now to combine DV and Atmos into one single container mkv and or mp4?
Would be nice to have some dedicated locked thread with information only (no discussion) or at least an updated first post to current situation.
I heard that plex or emby is supporting both in one go. Personally I use jellyfin. Anyway it should be quite easy to add support for DV + Atmos in jellyfin if there isn't a one container solution already. You can feed individual streams (video, audio, subtitle) within the jellyfin server to the client. I believe that is how emby/plex is implementing it as well.
bl4ck
Post by bl4ck »
Sony X700
sony can read DV m2ts without any modification from BDMV folder?
