mulucy
#2881 Post by mulucy » Fri Aug 28, 2020 6:52 pm
McZuzlak wrote: Fri Aug 28, 2020 5:18 pm Only from USB or from network too ?
It has 100Mit only though but maybe you could use an USB3 to Gbit LAN adapter.
It works fine through network from Plex DLNA server. But it buffers with movies like Gemini Man since it's a 60FPS Native 4K movie
lexyz
#2882 Post by lexyz » Fri Aug 28, 2020 8:35 pm
Shield owners check bright clipping after 8.2
X700 vs Shield
https://slow.pics/c/I0k7fFq4
mulucy
#2883 Post by mulucy » Fri Aug 28, 2020 9:41 pm
lexyz wrote: Fri Aug 28, 2020 8:35 pm Shield owners check bright clipping after 8.2
X700 vs Shield
the difference in picture quality is significant if you ask me
ragico
#2884 Post by ragico » Fri Aug 28, 2020 10:35 pm
Problems with shield pro 2019. I was initially concentrated on the infamous red push problem. Today I saw other movies and;
The Matrix initial scenes look light blue instead of beautiflul green.
This happens both with the kodi/exoplayer/mkv and with plex ts profile 4 and 5.
Very bad,
lexyz
#2885 Post by lexyz » Sat Aug 29, 2020 5:49 am
ragico wrote: Fri Aug 28, 2020 10:35 pm Problems with shield pro 2019. I was initially concentrated on the infamous red push problem. Today I saw other movies and;
Very bad,
What TV do you have? Panasonic GZ2000 oled right?
So such issue not only Sony-related
I suggest you to fill report for nVidia - more data, more chances for quicker fix.
Settings->Device Preferences->About->Send feedback to Nvidia
daddy
#2886 Post by daddy » Sat Aug 29, 2020 6:48 am
The largest FEL i ever see is Universal Soldier.
Universal soldier DV layer have a higher bitrate (16 Mbps) for a total bitrate of the movie equal to 100 Mbps.
DISC INFO:
Disc Title:     Universal.Soldier.1992.MULTI.COMPLETE.UHD.BLURAY-COASTER
Disc Size:      88,151,888,864 bytes
Protection:     AACS2
Extras:         Ultra HD
BDInfo:         0.7.5.6 (compatible layout created by DVDFab 11.0.5.7)
PLAYLIST REPORT:
Length:                 1:43:20.416 (h:m:s.ms)
Total Bitrate:          100.24 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec                   Bitrate             Description
MPEG-H HEVC Video       64000 kbps          2160p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020
* MPEG-H HEVC Video     16036 kbps (20.04%) 1080p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / Dolby Vision FEL / BT.2020
AUDIO:
Codec                           Language        Bitrate         Description
DTS-HD Master Audio             German          3892 kbps       5.1 / 48 kHz / 3892 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             English         4287 kbps       5.1 / 48 kHz / 4287 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             French          3524 kbps       5.1 / 48 kHz / 3524 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             English         1508 kbps       2.0 / 48 kHz / 1508 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 24-bit)
DTS-HD Master Audio             English         1616 kbps       2.0 / 48 kHz / 1616 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           German          18.982 kbps
Presentation Graphics           English         26.278 kbps
Presentation Graphics           French          14.994 kbps
Presentation Graphics           German          25.921 kbps
Presentation Graphics           French          25.97 kbps
Presentation Graphics           German          19.233 kbps
Presentation Graphics           German          0.11 kbps
Presentation Graphics           French          0.102 kbps
Mr_Orange
#2887 Post by Mr_Orange » Sat Aug 29, 2020 8:55 am
daddy wrote: Sat Aug 29, 2020 6:48 am The largest FEL i ever see is Universal Soldier.
DISC INFO:
Protection:     AACS2
Extras:         Ultra HD
PLAYLIST REPORT:
VIDEO:
AUDIO:
SUBTITLES:
Where do you obtain this information from? MakeMKV or another tool?
mulucy
#2888 Post by mulucy » Sat Aug 29, 2020 1:58 pm
lexyz wrote: Sat Aug 29, 2020 5:49 am
Very bad,
If has nothing to do with a TV brand. It's a known issue with Shield with dual-layer DV files. Although, the recent update fixed the issue with profile 5 used for streaming services. Profile 4/6 support is undocumented and never been advertised by Nvidia. I doubt they are going to fix it.
#2889 Post by RESET_9999 » Sat Aug 29, 2020 2:33 pm
[/code]
good to know. I think I missed that one and I'll get it right now. thanks for sharing.
#2890 Post by RESET_9999 » Sat Aug 29, 2020 2:34 pm
mulucy wrote: Sat Aug 29, 2020 1:58 pm If has nothing to do with a TV brand. It's a known issue with Shield with dual-layer DV files. Although, the recent update fixed the issue with profile 5 used for streaming services. Profile 4/6 support is undocumented and never been advertised by Nvidia. I doubt they are going to fix it.
definitely looks like an issue with file that contains an EL and not TV brand related.
ragico
#2891 Post by ragico » Sat Aug 29, 2020 4:45 pm
Very bad,
I really am uncapable to explain what's happening:
Today, after 2 shield reboots, The Matrix DV initial scenes, played in perfect colours (berautiful green) in mkv via kodi, exoplayer and in plex via ts profile 5
Alleluja
lexyz
#2892 Post by lexyz » Sat Aug 29, 2020 4:57 pm
There are few issues with EL files playback on Shield so far:
  1. "Red push" - excessive red spots in some frames. Example - https://imgur.com/a/oXwAoOj
  2. Clipping on DVLL TV at very bright scenes. Example - https://slow.pics/c/I0k7fFq4 pay attention on snow detais.
  3. Dolby vision output in wrong colorspace. Example https://imgur.com/a/w1z1Kjg . Triggered randomy, without any oblivious pattern. Reboot to fix
  4. Overall instability on DV playback. You can notice some flashy picture changes after FF or RW mkv in exoplayer
  5. Some PGS subtitles doesn't render properly.
3, 4 and 5 are new after 8.2 update
2 probably was prior 8.2
phbart
#2893 Post by phbart » Sat Aug 29, 2020 8:44 pm
My first post here. I have an OLED B7P panel, and it worked just fine! I'm really glad I found this thread.
The question is, does anybody knows any other player that supports DV from a USB drive other than Oppo? LG UBKM9 or UBK90 models, for instance?
mulucy
#2894 Post by mulucy » Sun Aug 30, 2020 12:04 am
We are all thanking Yusecope for creating tools and investing time here to make our lives better. But the real " thank you " will be to helping to invest in a solid DV capable hardware since he does not own any, AFAIK.
I am calling out everyone here to put our efforts together to buy him a nice OLED TV with Shield Pro and Blu Ray player such as X700 ( or even better, Oppo)
MastaG
#2895 Post by MastaG » Sun Aug 30, 2020 1:06 am
Then put up a donation link.
I'm happy to donate :)
