Where do you obtain this information from? MakeMKV or another tool?daddy wrote: ↑Sat Aug 29, 2020 6:48 amThe largest FEL i ever see is Universal Soldier.
Universal soldier DV layer have a higher bitrate (16 Mbps) for a total bitrate of the movie equal to 100 Mbps.
DISC INFO: Disc Title: Universal.Soldier.1992.MULTI.COMPLETE.UHD.BLURAY-COASTER Disc Size: 88,151,888,864 bytes Protection: AACS2 Extras: Ultra HD BDInfo: 0.7.5.6 (compatible layout created by DVDFab 11.0.5.7) PLAYLIST REPORT: Name: 00011.MPLS Length: 1:43:20.416 (h:m:s.ms) Size: 77,688,723,456 bytes Total Bitrate: 100.24 Mbps (*) Indicates included stream hidden by this playlist. VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-H HEVC Video 64000 kbps 2160p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020 * MPEG-H HEVC Video 16036 kbps (20.04%) 1080p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / Dolby Vision FEL / BT.2020 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio German 3892 kbps 5.1 / 48 kHz / 3892 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) DTS-HD Master Audio English 4287 kbps 5.1 / 48 kHz / 4287 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) DTS-HD Master Audio French 3524 kbps 5.1 / 48 kHz / 3524 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) DTS-HD Master Audio English 1508 kbps 2.0 / 48 kHz / 1508 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 24-bit) DTS-HD Master Audio English 1616 kbps 2.0 / 48 kHz / 1616 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 24-bit) SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics German 18.982 kbps Presentation Graphics English 26.278 kbps Presentation Graphics French 14.994 kbps Presentation Graphics German 25.921 kbps Presentation Graphics French 25.97 kbps Presentation Graphics German 19.233 kbps Presentation Graphics German 0.11 kbps Presentation Graphics French 0.102 kbps
If has nothing to do with a TV brand. It's a known issue with Shield with dual-layer DV files. Although, the recent update fixed the issue with profile 5 used for streaming services. Profile 4/6 support is undocumented and never been advertised by Nvidia. I doubt they are going to fix it.lexyz wrote: ↑Sat Aug 29, 2020 5:49 amWhat TV do you have? Panasonic GZ2000 oled right?ragico wrote: ↑Fri Aug 28, 2020 10:35 pmProblems with shield pro 2019. I was initially concentrated on the infamous red push problem. Today I saw other movies and;
The Matrix initial scenes look light blue instead of beautiflul green.
This happens both with the kodi/exoplayer/mkv and with plex ts profile 4 and 5.
Very bad,
So such issue not only Sony-related
I suggest you to fill report for nVidia - more data, more chances for quicker fix.
Settings->Device Preferences->About->Send feedback to Nvidia
good to know. I think I missed that one and I'll get it right now. thanks for sharing.
definitely looks like an issue with file that contains an EL and not TV brand related.mulucy wrote: ↑Sat Aug 29, 2020 1:58 pmIf has nothing to do with a TV brand. It's a known issue with Shield with dual-layer DV files. Although, the recent update fixed the issue with profile 5 used for streaming services. Profile 4/6 support is undocumented and never been advertised by Nvidia. I doubt they are going to fix it.
I really am uncapable to explain what's happening:ragico wrote: ↑Fri Aug 28, 2020 10:35 pmProblems with shield pro 2019. I was initially concentrated on the infamous red push problem. Today I saw other movies and;
Very bad,
Today, after 2 shield reboots, The Matrix DV initial scenes, played in perfect colours (berautiful green) in mkv via kodi, exoplayer and in plex via ts profile 5
Alleluja
There are few issues with EL files playback on Shield so far:
2 probably was prior 8.2
- "Red push" - excessive red spots in some frames. Example - https://imgur.com/a/oXwAoOj
- Clipping on DVLL TV at very bright scenes. Example - https://slow.pics/c/I0k7fFq4 pay attention on snow detais.
- Dolby vision output in wrong colorspace. Example https://imgur.com/a/w1z1Kjg . Triggered randomy, without any oblivious pattern. Reboot to fix
- Overall instability on DV playback. You can notice some flashy picture changes after FF or RW mkv in exoplayer
- Some PGS subtitles doesn't render properly.
My first post here. I have an OLED B7P panel, and it worked just fine! I'm really glad I found this thread.
The question is, does anybody knows any other player that supports DV from a USB drive other than Oppo? LG UBKM9 or UBK90 models, for instance?
We are all thanking Yusecope for creating tools and investing time here to make our lives better. But the real " thank you " will be to helping to invest in a solid DV capable hardware since he does not own any, AFAIK.
I am calling out everyone here to put our efforts together to buy him a nice OLED TV with Shield Pro and Blu Ray player such as X700 ( or even better, Oppo)
Then put up a donation link.
I'm happy to donate
I'm happy to donate
Sony X700 or Oppo China Clone
mulucy wrote: ↑Sun Aug 30, 2020 12:04 amWe are all thanking Yusecope for creating tools and investing time here to make our lives better. But the real " thank you " will be to helping to invest in a solid DV capable hardware since he does not own any, AFAIK.
You forgot "a nice Ferrari"!
Seriously, thank you for the idea @mulucy but ABSOLUTELY NOT!
The lines of code you are using are, for the most part, the result of a lockdown. Away 1000 Km from my family, with the fear of losing my job, with the anxiety for university exams, writing a few lines of code helped me to spend this period of forced closure peacefully. It is not a job but an "advanced Sudoku" and I would feel bad if I received money for a hobby. Money must be donated to people in need or in exchange for hard work! Thank you both but I just need a "thank you" and a little mention if someone wants to implement my code\logic.
Thanks for understanding.
Brief information. I have no Dolby vision nor Atmos but my brother does. Am not really interested in reading all 194 pages.
So is there a way now to combine DV and Atmos into one single container mkv and or mp4?
Would be nice to have some dedicated locked thread with information only (no discussion) or at least an updated first post to current situation.
I heard that plex or emby is supporting both in one go. Personally I use jellyfin. Anyway it should be quite easy to add support for DV + Atmos in jellyfin if there isn't a one container solution already. You can feed individual streams (video, audio, subtitle) within the jellyfin server to the client. I believe that is how emby/plex is implementing it as well.
