It works fine through network from Plex DLNA server. But it buffers with movies like Gemini Man since it's a 60FPS Native 4K movieMcZuzlak wrote: Fri Aug 28, 2020 5:18 pm Only from USB or from network too ?
It has 100Mit only though but maybe you could use an USB3 to Gbit LAN adapter.
mulucy
lexyz
mulucy
the difference in picture quality is significant if you ask melexyz wrote: Fri Aug 28, 2020 8:35 pm Shield owners check bright clipping after 8.2
X700 vs Shield
https://slow.pics/c/I0k7fFq4
ragico
Problems with shield pro 2019. I was initially concentrated on the infamous red push problem. Today I saw other movies and;
The Matrix initial scenes look light blue instead of beautiflul green.
This happens both with the kodi/exoplayer/mkv and with plex ts profile 4 and 5.
Very bad,
Very bad,
lexyz
What TV do you have? Panasonic GZ2000 oled right?ragico wrote: Fri Aug 28, 2020 10:35 pm Problems with shield pro 2019. I was initially concentrated on the infamous red push problem. Today I saw other movies and;
Very bad,
So such issue not only Sony-related
I suggest you to fill report for nVidia - more data, more chances for quicker fix.
Settings->Device Preferences->About->Send feedback to Nvidia
daddy
The largest FEL i ever see is Universal Soldier.
Universal soldier DV layer have a higher bitrate (16 Mbps) for a total bitrate of the movie equal to 100 Mbps.
DISC INFO:
Disc Title: Universal.Soldier.1992.MULTI.COMPLETE.UHD.BLURAY-COASTER
Disc Size: 88,151,888,864 bytes
Protection: AACS2
Extras: Ultra HD
BDInfo: 0.7.5.6 (compatible layout created by DVDFab 11.0.5.7)
PLAYLIST REPORT:
Length: 1:43:20.416 (h:m:s.ms)
Total Bitrate: 100.24 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 64000 kbps 2160p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020
* MPEG-H HEVC Video 16036 kbps (20.04%) 1080p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / Dolby Vision FEL / BT.2020
AUDIO:
Codec Language Bitrate Description
DTS-HD Master Audio German 3892 kbps 5.1 / 48 kHz / 3892 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio English 4287 kbps 5.1 / 48 kHz / 4287 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio French 3524 kbps 5.1 / 48 kHz / 3524 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio English 1508 kbps 2.0 / 48 kHz / 1508 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 24-bit)
DTS-HD Master Audio English 1616 kbps 2.0 / 48 kHz / 1616 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 24-bit)
SUBTITLES:
Presentation Graphics German 18.982 kbps
Presentation Graphics English 26.278 kbps
Presentation Graphics French 14.994 kbps
Presentation Graphics German 25.921 kbps
Presentation Graphics French 25.97 kbps
Presentation Graphics German 19.233 kbps
Presentation Graphics German 0.11 kbps
Presentation Graphics French 0.102 kbps -
Mr_Orange
Where do you obtain this information from? MakeMKV or another tool?daddy wrote: Sat Aug 29, 2020 6:48 am The largest FEL i ever see is Universal Soldier.
DISC INFO: Disc Title: Universal.Soldier.1992.MULTI.COMPLETE.UHD.BLURAY-COASTER Disc Size: 88,151,888,864 bytes Protection: AACS2 Extras: Ultra HD BDInfo: 0.7.5.6 (compatible layout created by DVDFab 11.0.5.7) PLAYLIST REPORT: Name: 00011.MPLS Length: 1:43:20.416 (h:m:s.ms) Size: 77,688,723,456 bytes Total Bitrate: 100.24 Mbps (*) Indicates included stream hidden by this playlist. VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-H HEVC Video 64000 kbps 2160p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020 * MPEG-H HEVC Video 16036 kbps (20.04%) 1080p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / Dolby Vision FEL / BT.2020 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio German 3892 kbps 5.1 / 48 kHz / 3892 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) DTS-HD Master Audio English 4287 kbps 5.1 / 48 kHz / 4287 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) DTS-HD Master Audio French 3524 kbps 5.1 / 48 kHz / 3524 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) DTS-HD Master Audio English 1508 kbps 2.0 / 48 kHz / 1508 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 24-bit) DTS-HD Master Audio English 1616 kbps 2.0 / 48 kHz / 1616 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 24-bit) SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics German 18.982 kbps Presentation Graphics English 26.278 kbps Presentation Graphics French 14.994 kbps Presentation Graphics German 25.921 kbps Presentation Graphics French 25.97 kbps Presentation Graphics German 19.233 kbps Presentation Graphics German 0.11 kbps Presentation Graphics French 0.102 kbps
mulucy
If has nothing to do with a TV brand. It's a known issue with Shield with dual-layer DV files. Although, the recent update fixed the issue with profile 5 used for streaming services. Profile 4/6 support is undocumented and never been advertised by Nvidia. I doubt they are going to fix it.lexyz wrote: Sat Aug 29, 2020 5:49 amWhat TV do you have? Panasonic GZ2000 oled right?ragico wrote: Fri Aug 28, 2020 10:35 pm Problems with shield pro 2019. I was initially concentrated on the infamous red push problem. Today I saw other movies and;
Very bad,
good to know. I think I missed that one and I'll get it right now. thanks for sharing.daddy wrote: Sat Aug 29, 2020 6:48 am The largest FEL i ever see is Universal Soldier.
[/code]
definitely looks like an issue with file that contains an EL and not TV brand related.mulucy wrote: Sat Aug 29, 2020 1:58 pm If has nothing to do with a TV brand. It's a known issue with Shield with dual-layer DV files. Although, the recent update fixed the issue with profile 5 used for streaming services. Profile 4/6 support is undocumented and never been advertised by Nvidia. I doubt they are going to fix it.
ragico
I really am uncapable to explain what's happening:ragico wrote: Fri Aug 28, 2020 10:35 pm Problems with shield pro 2019. I was initially concentrated on the infamous red push problem. Today I saw other movies and;
Very bad,
Today, after 2 shield reboots, The Matrix DV initial scenes, played in perfect colours (berautiful green) in mkv via kodi, exoplayer and in plex via ts profile 5
Alleluja
lexyz
There are few issues with EL files playback on Shield so far:
2 probably was prior 8.2
- "Red push" - excessive red spots in some frames. Example - https://imgur.com/a/oXwAoOj
- Clipping on DVLL TV at very bright scenes. Example - https://slow.pics/c/I0k7fFq4 pay attention on snow detais.
- Dolby vision output in wrong colorspace. Example https://imgur.com/a/w1z1Kjg . Triggered randomy, without any oblivious pattern. Reboot to fix
- Overall instability on DV playback. You can notice some flashy picture changes after FF or RW mkv in exoplayer
- Some PGS subtitles doesn't render properly.
phbart
My first post here. I have an OLED B7P panel, and it worked just fine! I'm really glad I found this thread.
The question is, does anybody knows any other player that supports DV from a USB drive other than Oppo? LG UBKM9 or UBK90 models, for instance?
mulucy
We are all thanking Yusecope for creating tools and investing time here to make our lives better. But the real " thank you " will be to helping to invest in a solid DV capable hardware since he does not own any, AFAIK.
I am calling out everyone here to put our efforts together to buy him a nice OLED TV with Shield Pro and Blu Ray player such as X700 ( or even better, Oppo)
MastaG
Then put up a donation link.
I'm happy to donate
I'm happy to donate
