McZuzlak
Post by McZuzlak » Fri Aug 28, 2020 5:18 pm
Only from USB or from network too ?
It has 100Mit only though but maybe you could use an USB3 to Gbit LAN adapter.
Post by RESET_9999 » Fri Aug 28, 2020 6:49 pm
McZuzlak wrote: Fri Aug 28, 2020 5:18 pm Only from USB or from network too ?
network too. i dont know if an usb ethernet adaptor would work. please let us know if you try.
Post by RESET_9999 » Fri Aug 28, 2020 6:51 pm
wow .... Leon the professional German Bluray disc is Dolby vision and the layer bitrate is 14.2/mb/s ... I think this is the largest FEL ever.
Disc Size: 79,591,397,429 bytes
Protection: AACS2
Extras: Ultra HD
BDInfo: 0.7.5.9
PLAYLIST REPORT:
Length: 2:12:46.708
Total Bitrate: 79.63 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 50956 kbps 2160p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020
* MPEG-H HEVC Video 14208 kbps (21.80%) 1080p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / Dolby Vision FEL / BT.2020
AUDIO:
Codec Language Bitrate Description
DTS-HD Master Audio German 4090 kbps 5.1 / 48 kHz / 4090 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby TrueHD/Atmos Audio English 4653 kbps 7.1+13 objects / 48 kHz / 4013 kbps / 24-bit (AC3 Core: 5.1-EX / 48 kHz / 640 kbps)
DTS Audio Undetermined 768 kbps 2.0 / 48 kHz / 768 kbps / 24-bit
mulucy
Post by mulucy » Fri Aug 28, 2020 6:52 pm
It works fine through network from Plex DLNA server. But it buffers with movies like Gemini Man since it's a 60FPS Native 4K movie
lexyz
Post by lexyz » Fri Aug 28, 2020 8:35 pm
Shield owners check bright clipping after 8.2
X700 vs Shield
https://slow.pics/c/I0k7fFq4
mulucy
Post by mulucy » Fri Aug 28, 2020 9:41 pm
lexyz wrote: Fri Aug 28, 2020 8:35 pm Shield owners check bright clipping after 8.2
X700 vs Shield
the difference in picture quality is significant if you ask me
ragico
Post by ragico » Fri Aug 28, 2020 10:35 pm
Problems with shield pro 2019. I was initially concentrated on the infamous red push problem. Today I saw other movies and;
The Matrix initial scenes look light blue instead of beautiflul green.
This happens both with the kodi/exoplayer/mkv and with plex ts profile 4 and 5.
Very bad,
lexyz
Post by lexyz » Sat Aug 29, 2020 5:49 am
ragico wrote: Fri Aug 28, 2020 10:35 pm Problems with shield pro 2019. I was initially concentrated on the infamous red push problem. Today I saw other movies and;
Very bad,
What TV do you have? Panasonic GZ2000 oled right?
So such issue not only Sony-related
I suggest you to fill report for nVidia - more data, more chances for quicker fix.
Settings->Device Preferences->About->Send feedback to Nvidia
daddy
Post by daddy » Sat Aug 29, 2020 6:48 am
The largest FEL i ever see is Universal Soldier.
Universal soldier DV layer have a higher bitrate (16 Mbps) for a total bitrate of the movie equal to 100 Mbps.
DISC INFO:
Disc Title:     Universal.Soldier.1992.MULTI.COMPLETE.UHD.BLURAY-COASTER
Disc Size:      88,151,888,864 bytes
Protection:     AACS2
Extras:         Ultra HD
BDInfo:         0.7.5.6 (compatible layout created by DVDFab 11.0.5.7)
PLAYLIST REPORT:
Length:                 1:43:20.416 (h:m:s.ms)
Total Bitrate:          100.24 Mbps
VIDEO:
MPEG-H HEVC Video       64000 kbps          2160p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020
* MPEG-H HEVC Video     16036 kbps (20.04%) 1080p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / Dolby Vision FEL / BT.2020
AUDIO:
DTS-HD Master Audio             German          3892 kbps       5.1 / 48 kHz / 3892 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             English         4287 kbps       5.1 / 48 kHz / 4287 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             French          3524 kbps       5.1 / 48 kHz / 3524 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             English         1508 kbps       2.0 / 48 kHz / 1508 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 24-bit)
DTS-HD Master Audio             English         1616 kbps       2.0 / 48 kHz / 1616 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           German          18.982 kbps
Presentation Graphics           English         26.278 kbps
Presentation Graphics           French          14.994 kbps
Presentation Graphics           German          25.921 kbps
Presentation Graphics           French          25.97 kbps
Presentation Graphics           German          19.233 kbps
Presentation Graphics           German          0.11 kbps
Presentation Graphics           French          0.102 kbps
Mr_Orange
Post by Mr_Orange » Sat Aug 29, 2020 8:55 am
daddy wrote: Sat Aug 29, 2020 6:48 am The largest FEL i ever see is Universal Soldier.
DISC INFO:
Protection:     AACS2
Extras:         Ultra HD
PLAYLIST REPORT:
VIDEO:
AUDIO:
SUBTITLES:
Where do you obtain this information from? MakeMKV or another tool?
mulucy
Post by mulucy » Sat Aug 29, 2020 1:58 pm
lexyz wrote: Sat Aug 29, 2020 5:49 am
Very bad,
If has nothing to do with a TV brand. It's a known issue with Shield with dual-layer DV files. Although, the recent update fixed the issue with profile 5 used for streaming services. Profile 4/6 support is undocumented and never been advertised by Nvidia. I doubt they are going to fix it.
Post by RESET_9999 » Sat Aug 29, 2020 2:33 pm
[/code]
good to know. I think I missed that one and I'll get it right now. thanks for sharing.
Post by RESET_9999 » Sat Aug 29, 2020 2:34 pm
mulucy wrote: Sat Aug 29, 2020 1:58 pm If has nothing to do with a TV brand. It's a known issue with Shield with dual-layer DV files. Although, the recent update fixed the issue with profile 5 used for streaming services. Profile 4/6 support is undocumented and never been advertised by Nvidia. I doubt they are going to fix it.
definitely looks like an issue with file that contains an EL and not TV brand related.
ragico
Post by ragico » Sat Aug 29, 2020 4:45 pm
Very bad,
I really am uncapable to explain what's happening:
Today, after 2 shield reboots, The Matrix DV initial scenes, played in perfect colours (berautiful green) in mkv via kodi, exoplayer and in plex via ts profile 5
Alleluja
lexyz
Post by lexyz » Sat Aug 29, 2020 4:57 pm
There are few issues with EL files playback on Shield so far:
  1. "Red push" - excessive red spots in some frames. Example - https://imgur.com/a/oXwAoOj
  2. Clipping on DVLL TV at very bright scenes. Example - https://slow.pics/c/I0k7fFq4 pay attention on snow detais.
  3. Dolby vision output in wrong colorspace. Example https://imgur.com/a/w1z1Kjg . Triggered randomy, without any oblivious pattern. Reboot to fix
  4. Overall instability on DV playback. You can notice some flashy picture changes after FF or RW mkv in exoplayer
  5. Some PGS subtitles doesn't render properly.
3, 4 and 5 are new after 8.2 update
2 probably was prior 8.2
