lexyz
#2866 Post by lexyz » Thu Aug 27, 2020 5:28 pm
RESET_9999 wrote: Thu Aug 27, 2020 3:24 pm OMG seriously!! I thought they wouldn't touch LLDV. Now that it seems fixed for RGB DV, I'm definitely turning off the auto-update on mine :)
Well.. I've run few test right after update and got colorspace issues. After reboot the issue can't be reproduced
Probably it's gone for good, but I'm not sure
More testing needed! :D
And yes. SPR still flickers. I have tested about 35 or 37 movies.
Only two has issues - SPR and Atomic Blonde
I mean flickering
Red push still can be found on white like famous SM Benchmark horses scene or MI Fallout 00:32-00:33. Regarding MIF I would say it's more "red blocks" than just push
MIF test file is here https://gofile.io/d/8m2pOl
UPD: Doctor Sleep red push is still here.
#2867 Post by shawnc22 » Thu Aug 27, 2020 5:50 pm
lexyz wrote: Thu Aug 27, 2020 5:28 pm
And yes. SPR still flickers. I have test about 35 or 37 movies.
Yeah some others on the nvidia forums have reported that the issue with Sony TVs went away after rebooting so hopefully that solves it. Previously, nvidia staff did say that attaching BT2020 to the RGB signal was a conscious decision to solve DV issues that some TVs were having. It'd make sense then that if they just simply removed the BT2020 tag without doing anything else, those same TVs would start seeing those issues again. Also as I remembered, there have been issues in the past with the way Sony implemented DV on their TVs, no?
lexyz
#2868 Post by lexyz » Thu Aug 27, 2020 6:06 pm
shawnc22 wrote: Thu Aug 27, 2020 5:50 pm Also as I remembered, there have been issues in the past with the way Sony implemented DV on their TVs, no?
Back in a day source devices had to be updated to support Sony TV
Not an issue for now as I know
ragico
#2869 Post by ragico » Thu Aug 27, 2020 6:12 pm
RESET_9999 wrote: Thu Aug 27, 2020 4:23 pm @ragico did you check the flickering issue in the shawnc22 sample?
SpR still flickers. but it also flickers in Ugoos am6 plus. Only in sony x700 trough ts profile7 there is no flickering.-
I think this colour issue is higly depentend fron Tv maker and possibly model.. I have a Panasonic GZ2000 oled and I do not have the issues I read in this forum.
#2870 Post by shawnc22 » Thu Aug 27, 2020 6:26 pm
SPR still flickers and I still do notice the red tinting a bit on the little girl's face on my B9 when compared to the LG internal player. I'm not sure if it's gotten better or just stayed the same with the latest update.
A bit unrelated, but does anyone else's Shield cut out for a second or two when starting an HDR/DV video? The sound on my system would start playing first with the "No Signal" image on the TV, and then the video switches on after a few seconds. This just started happening one day in both Plex and Kodi prior to the Shield update and is still happening at the moment after the update. Not a big deal, but just wondered if anyone else was experiencing the same. Setup: Shield -> Denon x3600h -> LG B9.
lexyz
#2871 Post by lexyz » Thu Aug 27, 2020 8:44 pm
lexyz wrote: Thu Aug 27, 2020 5:28 pm MIF test file is here https://gofile.io/d/8m2pOl
Fellow Shield-owners I would like to ask you to check this file. :D
Can you see red spots and blocks?
#2872 Post by RESET_9999 » Thu Aug 27, 2020 10:34 pm
yes I'm seeing the red artifacts in the background too on that MI clip. Same on the Dr. Sleep sample. :(
#2873 Post by SamuriHL » Thu Aug 27, 2020 10:43 pm
Same in the cloud scene in the Spears and Munsil FEL clip. Red push is still there. However, Disney+ is fixed so that's a win.
mulucy
#2874 Post by mulucy » Fri Aug 28, 2020 1:55 am
Is there a way to see if Shield triggers the second HEVC stream with dual-layer DV files with the developer menu or command line? I know Shield has some color issues with red and some other weird colors, but want to make sure that it's the right device before investing in another streamer, otherwise, I am quite happy with my Sony X700 ( there were some talks that it's possible that Shield Pro is not even processing the second FEL layer )
lexyz
#2875 Post by lexyz » Fri Aug 28, 2020 3:36 am
mulucy wrote: Fri Aug 28, 2020 1:55 am Is there a way to see if Shield triggers the second HEVC stream with dual-layer DV files with the developer menu or command line?
Second stream in dual track file will not play.
As for second stream (layer) merged in single track...
There is no way to tell for sure is FEL active or not. No test patterns exist, no reports in logs.
Only visual observation.
Based on theory visual difference could be in :arrow: :
a) smoother gradients
b) less compression artefacts in shadows (mostly in red and blue tones)
c) overall cleaner image with less shimmering
Keep in mind - if video has high quality properly encoded HDR base layer than FEL layer improvements are less and less noticeable, neglectable, or almost none. Indeed 2bit more data is here but probably it should be seen on true 12bit panel to spot something.
So If FEL discarded than image in HDR should be identical to DV Base layer plus some difference in contrast because of tonemapping.
I spend hours and hours to find any difference between HDR and DV and Shield . Heck, I even bought X700 solely for FEL-noFEL comparison purpose :lol:
One particular scene with oblivious difference I've found is Valerian 00:52:40 mark - better blue gradients
Pictures - https://slow.pics/c/yhIjWUas
I don't not say FEL is fully utilized and don't say FEL discarded. But after hours of testing I don't really care about FEL anymore until proper test patterns appear. :D
Red push and blocking is real problem for now
userr
#2876 Post by userr » Fri Aug 28, 2020 1:25 pm
Is it possible to play .mp4/.ts profile 7 dual layer, dual track files on x700? I guess .mkv doesnt work cause its so new(?) and maybe never will but .mp4/.ts ? with atmos?
#2877 Post by RESET_9999 » Fri Aug 28, 2020 2:10 pm
userr wrote: Fri Aug 28, 2020 1:25 pm Is it possible to play .mp4/.ts profile 7 dual layer, dual track files on x700? I guess .mkv doesnt work cause its so new(?) and maybe never will but .mp4/.ts ? with atmos?
yes, the x700 can play profile 7 dual-layer with atmos. plus the colors are accurate and no flickers.
mp4 dual layer fel or mel + LPCM 7.1 audio works but no atmos no subtitle
ts dual layer
fel or mel + Atmos + subtitles works
McZuzlak
#2878 Post by McZuzlak » Fri Aug 28, 2020 5:18 pm
Only from USB or from network too ?
It has 100Mit only though but maybe you could use an USB3 to Gbit LAN adapter.
#2879 Post by RESET_9999 » Fri Aug 28, 2020 6:49 pm
McZuzlak wrote: Fri Aug 28, 2020 5:18 pm Only from USB or from network too ?
network too. i dont know if an usb ethernet adaptor would work. please let us know if you try.
#2880 Post by RESET_9999 » Fri Aug 28, 2020 6:51 pm
wow .... Leon the professional German Bluray disc is Dolby vision and the layer bitrate is 14.2/mb/s ... I think this is the largest FEL ever.
Disc Size: 79,591,397,429 bytes
Protection: AACS2
Extras: Ultra HD
BDInfo: 0.7.5.9
PLAYLIST REPORT:
Length: 2:12:46.708
Total Bitrate: 79.63 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 50956 kbps 2160p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020
* MPEG-H HEVC Video 14208 kbps (21.80%) 1080p / 24 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / Dolby Vision FEL / BT.2020
AUDIO:
Codec Language Bitrate Description
DTS-HD Master Audio German 4090 kbps 5.1 / 48 kHz / 4090 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby TrueHD/Atmos Audio English 4653 kbps 7.1+13 objects / 48 kHz / 4013 kbps / 24-bit (AC3 Core: 5.1-EX / 48 kHz / 640 kbps)
DTS Audio Undetermined 768 kbps 2.0 / 48 kHz / 768 kbps / 24-bit
