Scsi errorrs?
mangry
Scsi errorrs?
#1 Post by mangry » Sun Dec 12, 2010 2:22 am
Every time i just start the program I'm getting scsi errors, is that normal? (its also annoying)
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command 46020..00140 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at KV&ObvDR%bo"q`9V:29399450
Re: Scsi errorrs?
#2 Post by mike admin » Mon Dec 13, 2010 9:22 am
What kind of drive do you have?
mangry
Re: Scsi errorrs?
#3 Post by mangry » Mon Dec 13, 2010 6:04 pm
mike admin wrote:What kind of drive do you have?
It says ASUS DRW-2014L1T ATA Device
Re: Scsi errorrs?
#4 Post by mike admin » Tue Dec 14, 2010 9:43 am
Your drive doesn't confirm to SCSI MMC specification - I suggest updating drive firmware. It must be a really cheap drive. The error itself is harmless.
mangry
Re: Scsi errorrs?
#5 Post by mangry » Tue Dec 14, 2010 6:52 pm
mike admin wrote:Your drive doesn't confirm to SCSI MMC specification - I suggest updating drive firmware. It must be a really cheap drive. The error itself is harmless.
How about just not having the program print that?
mangry
Re: Scsi errorrs?
#6 Post by mangry » Sun Dec 19, 2010 12:22 am
It is running the latest firmware.
mangry
Re: Scsi errorrs?
#7 Post by mangry » Sat Mar 19, 2011 1:21 am
Actually, turns out its not the DVD drive - its a specially formatted partition on a harddrive, made (from manufacturers) to look like a DVD drive to the system.
So the only fix would be to disable the hang scan of makemkv
