Jordbrett
Post by Jordbrett » Mon Aug 24, 2020 4:07 pm
Would the modified exoplayer work on a Vero or is that only for the shield/android devices currently?
Also, if using the internal LG player now that MKV is possible should I still convert to MP4 and do everything on the first post?
Post by shawnc22 » Mon Aug 24, 2020 6:10 pm
Exoplayer is an android project, so yes you'd need an android device. Also highly unlikely internal lg player will add support for new mkv standards, so you'd still need to remux into mp4s.
Boss21
Post by Boss21 » Tue Aug 25, 2020 1:09 am
Please can you send me link for downloading tsmuxer 05.06 fix for making Dolby vision profile 5
mecedo
Post by mecedo » Tue Aug 25, 2020 11:10 am
I've tried to make DV mp4 file but got 50% success. Only with --dv-profile 5 I've got mp4 file where MediaInfo reports it's Dolby Vision file. With other profiles I've got HDR10 file in Media Info. Video player embedded in TV Sony KD-55XF9005 triggers DolbyVision only for file made with --dv-profile 5. But unfortunately in the whole movie there's solid green picture with audio in the background :(
Any chances to make proper DV file with mp4muxer? Do you have correct workflow? I've tried instructions from first post but no success.
Jordbrett
Post by Jordbrett » Wed Aug 26, 2020 2:06 am
I must be doing something completely wrong on install but on Mac trying mp4 Dolby vision muxer and yusecope's tool I get a syntax error. Any idea why? Thanks in advance.
mulucy
Post by mulucy » Wed Aug 26, 2020 8:46 pm
RESET_9999 wrote: Thu Aug 13, 2020 1:56 am
mulucy wrote: Thu Aug 13, 2020 1:16 am We are not even 100% sure whether it's discarding the the second layer or not, correct?
no way to tell for sure until they fix the color issue.
Nvidia just pushed the update to fix the bt.2020 flag issue, can you confirm if it makes any difference in DV content in comparison to other devices?
mulucy
Post by mulucy » Wed Aug 26, 2020 9:52 pm
Boss21 wrote: Mon Aug 24, 2020 12:45 am please can anyone share ts muxer 05.06 fix , 06.06 fix and 07.06 to download. Iwant to create dv profile 5 to be play on Apple TV through infuse pro.
thanks
here is the version I have been using for the Profile 5 - https://drive.google.com/file/d/1yFrj5B ... sp=sharing
Post by RESET_9999 » Wed Aug 26, 2020 10:35 pm
mulucy wrote: Wed Aug 26, 2020 8:46 pm
YES finally.... just like my earlier comparisons showed. This update fixes the red push on profile 5 full-range content ( netflix, disney etc...)
https://screenshotcomparison.com/comparison/5762
still some issues with this color though:
Definitely better than before...
mulucy
Post by mulucy » Wed Aug 26, 2020 11:10 pm
RESET_9999 wrote: Wed Aug 26, 2020 10:35 pm
Does it still mean we don't know for sure whether it supports the dual-layer profile 4/6 videos made from UHD disks?
Post by RESET_9999 » Wed Aug 26, 2020 11:23 pm
mulucy wrote: Wed Aug 26, 2020 11:10 pm
I did not check the Dr. Sleep sample on this new update but I'm pretty sure it's a different issue so we still don't know for sure indeed.
There's still hope that it will work properly with SL-DL files one day though.
lexyz
Post by lexyz » Thu Aug 27, 2020 10:24 am
mulucy wrote: Wed Aug 26, 2020 8:46 pm Nvidia just pushed the update to fix the bt.2020 flag issue, can you confirm if it makes any difference in DV content in comparison to other devices?
Yeap, there is some noticeable difference :D
DV playback on Shield with Sony TV is corrupted by latest update.
Content is mostly in wrong colorspace.
In attempt to fix Shield for LG they crippled it for Sony :?
ragico
Post by ragico » Thu Aug 27, 2020 1:12 pm
After the firmware update on the shield 2019 pro, I compared on Panasonic GZ2000 oled Tv the infamous scene from Doctor Sleep, Shield vs Sony x700. I think that there is still a very slight difference in favour of Sony x700, but it is really very slight and you must look for it to find it.
So great job at nvidia shield concenring this problem.
Post by RESET_9999 » Thu Aug 27, 2020 3:24 pm
ragico wrote: Thu Aug 27, 2020 1:12 pm After the firmware update on the shield 2019 pro, I compared on Panasonic GZ2000 oled Tv the infamous scene from Doctor Sleep, Shield vs Sony x700. I think that there is still a very slight difference in favour of Sony x700, but it is really very slight and you must look for it to find it.
oh really, this is great news then. I'll check it out as well.
lexyz wrote: Thu Aug 27, 2020 10:24 am Yeap, there is some noticeable difference :D
OMG seriously!! I thought they wouldn't touch LLDV. Now that it seems fixed for RGB DV, I'm definitely turning off the auto-update on mine :)
Post by SamuriHL » Thu Aug 27, 2020 4:13 pm
Figures they fix one thing and break another. But, um, to be fair, we LG owners really needed this one. LMAO :D I'm on vacation starting tomorrow so I have some time to play, as well. I have a few things I want to take a look at. Would be nice if it's so close that it's hard to see. But I have one scene that'll make it very clear.
Post by RESET_9999 » Thu Aug 27, 2020 4:23 pm
@ragico did you check the flickering issue in the shawnc22 sample?
