Nvidia just pushed the update to fix the bt.2020 flag issue, can you confirm if it makes any difference in DV content in comparison to other devices?
here is the version I have been using for the Profile 5 - https://drive.google.com/file/d/1yFrj5B ... sp=sharing
YES finally.... just like my earlier comparisons showed. This update fixes the red push on profile 5 full-range content ( netflix, disney etc...)
https://screenshotcomparison.com/comparison/5762
still some issues with this color though:
Definitely better than before...
Does it still mean we don't know for sure whether it supports the dual-layer profile 4/6 videos made from UHD disks?RESET_9999 wrote: ↑Wed Aug 26, 2020 10:35 pmYES finally.... just like my earlier comparisons showed. This update fixes the red push on profile 5 full-range content ( netflix, disney etc...)
I did not check the Dr. Sleep sample on this new update but I'm pretty sure it's a different issue so we still don't know for sure indeed.
There's still hope that it will work properly with SL-DL files one day though.
Yeap, there is some noticeable difference
DV playback on Shield with Sony TV is corrupted by latest update.
Content is mostly in wrong colorspace.
In attempt to fix Shield for LG they crippled it for Sony
After the firmware update on the shield 2019 pro, I compared on Panasonic GZ2000 oled Tv the infamous scene from Doctor Sleep, Shield vs Sony x700. I think that there is still a very slight difference in favour of Sony x700, but it is really very slight and you must look for it to find it.
So great job at nvidia shield concenring this problem.
oh really, this is great news then. I'll check it out as well.ragico wrote: ↑Thu Aug 27, 2020 1:12 pmAfter the firmware update on the shield 2019 pro, I compared on Panasonic GZ2000 oled Tv the infamous scene from Doctor Sleep, Shield vs Sony x700. I think that there is still a very slight difference in favour of Sony x700, but it is really very slight and you must look for it to find it.
OMG seriously!! I thought they wouldn't touch LLDV. Now that it seems fixed for RGB DV, I'm definitely turning off the auto-update on mine
Figures they fix one thing and break another. But, um, to be fair, we LG owners really needed this one. LMAO I'm on vacation starting tomorrow so I have some time to play, as well. I have a few things I want to take a look at. Would be nice if it's so close that it's hard to see. But I have one scene that'll make it very clear.
@ragico did you check the flickering issue in the shawnc22 sample?
Well.. I've run few test right after update and got colorspace issues. After reboot the issue can't be reproducedRESET_9999 wrote: ↑Thu Aug 27, 2020 3:24 pmOMG seriously!! I thought they wouldn't touch LLDV. Now that it seems fixed for RGB DV, I'm definitely turning off the auto-update on mine
Probably it's gone for good, but I'm not sure
More testing needed!
And yes. SPR still flickers. I have tested about 35 or 37 movies.
Only two has issues - SPR and Atomic Blonde
I mean flickering
Red push still can be found on white like famous SM Benchmark horses scene or MI Fallout 00:32-00:33. Regarding MIF I would say it's more "red blocks" than just push
MIF test file is here https://gofile.io/d/8m2pOl
UPD: Doctor Sleep red push is still here.
Yeah some others on the nvidia forums have reported that the issue with Sony TVs went away after rebooting so hopefully that solves it. Previously, nvidia staff did say that attaching BT2020 to the RGB signal was a conscious decision to solve DV issues that some TVs were having. It'd make sense then that if they just simply removed the BT2020 tag without doing anything else, those same TVs would start seeing those issues again. Also as I remembered, there have been issues in the past with the way Sony implemented DV on their TVs, no?lexyz wrote: ↑Thu Aug 27, 2020 5:28 pmWell.. I've run few test right after update and got colorspace issues. After reboot the issue can't be reproducedRESET_9999 wrote: ↑Thu Aug 27, 2020 3:24 pmOMG seriously!! I thought they wouldn't touch LLDV. Now that it seems fixed for RGB DV, I'm definitely turning off the auto-update on mine
And yes. SPR still flickers. I have test about 35 or 37 movies.
Back in a day source devices had to be updated to support Sony TV
Not an issue for now as I know
SpR still flickers. but it also flickers in Ugoos am6 plus. Only in sony x700 trough ts profile7 there is no flickering.-RESET_9999 wrote: ↑Thu Aug 27, 2020 4:23 pm@ragico did you check the flickering issue in the shawnc22 sample?
I think this colour issue is higly depentend fron Tv maker and possibly model.. I have a Panasonic GZ2000 oled and I do not have the issues I read in this forum.
SPR still flickers and I still do notice the red tinting a bit on the little girl's face on my B9 when compared to the LG internal player. I'm not sure if it's gotten better or just stayed the same with the latest update.RESET_9999 wrote: ↑Thu Aug 27, 2020 4:23 pm@ragico did you check the flickering issue in the shawnc22 sample?
A bit unrelated, but does anyone else's Shield cut out for a second or two when starting an HDR/DV video? The sound on my system would start playing first with the "No Signal" image on the TV, and then the video switches on after a few seconds. This just started happening one day in both Plex and Kodi prior to the Shield update and is still happening at the moment after the update. Not a big deal, but just wondered if anyone else was experiencing the same. Setup: Shield -> Denon x3600h -> LG B9.
