Sherlock Holmes
TheClaw
Sherlock Holmes
Post by TheClaw »
I tried ripping Sherlock Holmes, but I got an error. I have attached the bug report.
Re: Sherlock Holmes
Post by mike admin »
Please try to make a full disc backup in MakeMKV and see if any hashcheck errors show up.
TheClaw
Re: Sherlock Holmes
Post by TheClaw »
Here is an updated log with the entire disk. Two titles didn't save, and I'm pretty sure one of them is the main movie but my computer keeps quitting out of explorer once I get to the drive and into a folder.
Re: Sherlock Holmes
Please try to make a full disc backup per instructions at http://www.makemkv.com/faq/item/4 .
TheClaw
Re: Sherlock Holmes
Post by TheClaw »
I finally got a chance to do a full back up and it failed. Here is the log
Re: Sherlock Holmes
TheClaw wrote:I finally got a chance to do a full back up and it failed. Here is the log
You have a bad disc or drive.
Hash check failed for file /BDMV/STREAM/00162.m2ts at offset 252635136, file is corrupt.
Hash check failed for file /BDMV/STREAM/00162.m2ts at offset 334424064, file is corrupt.
Hash check failed for file /BDMV/STREAM/00162.m2ts at offset 335407104, file is corrupt.
Hash check failed for file /BDMV/STREAM/00162.m2ts at offset 335996928, file is corrupt.
Hash check failed for file /BDMV/STREAM/00162.m2ts at offset 336193536, file is corrupt.
