Jordbrett
#2851 Post by Jordbrett » Mon Aug 24, 2020 1:07 am
So there's obviously a ton of info in this thread. I've skimmed probably 50+ pages but is there a good place to start? I know some of the older info is outdated. I have an LG Oled and would love to get dv working on it. Is there maybe a quick summary of the process? I can keep searching I don't mind that but figured maybe it would be good to have the info in a more recent post. Thanks!
McZuzlak
#2852 Post by McZuzlak » Mon Aug 24, 2020 5:04 am
If you plan to use the LG internal player app you may just use the methode in first page.
RayDawGGG
#2853 Post by RayDawGGG » Mon Aug 24, 2020 9:18 am
Profile 6:
Spider-Man Homecoming (2017) - .4K.2160P.HEVC.H265.DV.Atmos.ULTRAHD.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 51.8 GiB
Duration : 2 h 13 min
Overall bit rate mode : Variable
Overall bit rate : 55.6 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.06.06, BL+EL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : 6
Bit rate : 52.7 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.265
Stream size : 49.1 GiB (95%)
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 4332 cd/m2
Maximum Frame-Average Light Level : 992 cd/m2
Audio
Menu ID : 1 (0x1)
Format : AC-3 MLP FBA 16-ch
Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Muxing mode : Stream extension
Codec ID : 131
Bit rate mode : Variable
Bit rate : 640 kb/s
Maximum bit rate : 8 175 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 611 MiB (1%)
Language : English
Service kind : Complete Main
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Language : English
Profile 7:
Format : BDAV
Overall bit rate : 55.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : 6
Color space : YUV
Bit depth : 10 bits
Audio
Menu ID : 1 (0x1)
Codec ID : 131
Bit rate : 640 kb/s
Language : English
I was under the impression that the BL is HDR10(4K)[2160] and the EL is SDR(Bluray)[1920]. That's how the layers are stored on the UHD. Yet in profile 6 both layers are HDR10/HDR10, and in profile 7 the layers are Bluray/HDR10?
Jordbrett
#2854 Post by Jordbrett » Mon Aug 24, 2020 4:07 pm
Would the modified exoplayer work on a Vero or is that only for the shield/android devices currently?
Also, if using the internal LG player now that MKV is possible should I still convert to MP4 and do everything on the first post?
#2855 Post by shawnc22 » Mon Aug 24, 2020 6:10 pm
Exoplayer is an android project, so yes you'd need an android device. Also highly unlikely internal lg player will add support for new mkv standards, so you'd still need to remux into mp4s.
Boss21
#2856 Post by Boss21 » Tue Aug 25, 2020 1:09 am
Please can you send me link for downloading tsmuxer 05.06 fix for making Dolby vision profile 5
mecedo
#2857 Post by mecedo » Tue Aug 25, 2020 11:10 am
I've tried to make DV mp4 file but got 50% success. Only with --dv-profile 5 I've got mp4 file where MediaInfo reports it's Dolby Vision file. With other profiles I've got HDR10 file in Media Info. Video player embedded in TV Sony KD-55XF9005 triggers DolbyVision only for file made with --dv-profile 5. But unfortunately in the whole movie there's solid green picture with audio in the background :(
Any chances to make proper DV file with mp4muxer? Do you have correct workflow? I've tried instructions from first post but no success.
Jordbrett
#2858 Post by Jordbrett » Wed Aug 26, 2020 2:06 am
I must be doing something completely wrong on install but on Mac trying mp4 Dolby vision muxer and yusecope's tool I get a syntax error. Any idea why? Thanks in advance.
mulucy
#2859 Post by mulucy » Wed Aug 26, 2020 8:46 pm
RESET_9999 wrote: Thu Aug 13, 2020 1:56 am
mulucy wrote: Thu Aug 13, 2020 1:16 am We are not even 100% sure whether it's discarding the the second layer or not, correct?
no way to tell for sure until they fix the color issue.
Nvidia just pushed the update to fix the bt.2020 flag issue, can you confirm if it makes any difference in DV content in comparison to other devices?
mulucy
#2860 Post by mulucy » Wed Aug 26, 2020 9:52 pm
Boss21 wrote: Mon Aug 24, 2020 12:45 am please can anyone share ts muxer 05.06 fix , 06.06 fix and 07.06 to download. Iwant to create dv profile 5 to be play on Apple TV through infuse pro.
thanks
here is the version I have been using for the Profile 5 - https://drive.google.com/file/d/1yFrj5B ... sp=sharing
#2861 Post by RESET_9999 » Wed Aug 26, 2020 10:35 pm
mulucy wrote: Wed Aug 26, 2020 8:46 pm
YES finally.... just like my earlier comparisons showed. This update fixes the red push on profile 5 full-range content ( netflix, disney etc...)
https://screenshotcomparison.com/comparison/5762
still some issues with this color though:
Definitely better than before...
mulucy
#2862 Post by mulucy » Wed Aug 26, 2020 11:10 pm
RESET_9999 wrote: Wed Aug 26, 2020 10:35 pm
Does it still mean we don't know for sure whether it supports the dual-layer profile 4/6 videos made from UHD disks?
#2863 Post by RESET_9999 » Wed Aug 26, 2020 11:23 pm
mulucy wrote: Wed Aug 26, 2020 11:10 pm
I did not check the Dr. Sleep sample on this new update but I'm pretty sure it's a different issue so we still don't know for sure indeed.
There's still hope that it will work properly with SL-DL files one day though.
lexyz
#2864 Post by lexyz » Thu Aug 27, 2020 10:24 am
mulucy wrote: Wed Aug 26, 2020 8:46 pm Nvidia just pushed the update to fix the bt.2020 flag issue, can you confirm if it makes any difference in DV content in comparison to other devices?
Yeap, there is some noticeable difference :D
DV playback on Shield with Sony TV is corrupted by latest update.
Content is mostly in wrong colorspace.
In attempt to fix Shield for LG they crippled it for Sony :?
ragico
#2865 Post by ragico » Thu Aug 27, 2020 1:12 pm
After the firmware update on the shield 2019 pro, I compared on Panasonic GZ2000 oled Tv the infamous scene from Doctor Sleep, Shield vs Sony x700. I think that there is still a very slight difference in favour of Sony x700, but it is really very slight and you must look for it to find it.
So great job at nvidia shield concenring this problem.
