tabris
#1
Post
by tabris » Fri Aug 21, 2020 2:29 pm
when ripping LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN it just failed to save title.
I think the problem is that this blu-ray disk is just for music play. because I can rip other blu-ray without problem.
MakeMKV v1.15.2 win(x64-release) started
Using LibreDrive mode (v06.2 id=8B0DAADF6310)
File 00000.mpls was added as title #0
File 00005.m2ts was added as title #1
File 00004.m2ts was added as title #2
Saving 3 titles into directory E:/Video/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 2
Failed to save title 0 to file E:/Video/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 2/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 2_t00.mkv
2 titles saved, 1 failed
#2
Post
by Woodstock » Fri Aug 21, 2020 3:16 pm
Could you activate Debug logging (information on that is in the link in my signature), and post the results of ripping the third track?
Most likely, it is a read error, which may be fixed by cleaning, but is difficult to say without more information.
tabris
#3
Post
by tabris » Sat Aug 22, 2020 10:42 am
Disc 1
Debug log started at Sat Aug 22 10:03:30 2020 , written by MakeMKV v1.15.2 win(x64-release)
001005:0000 MakeMKV v1.15.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users/MakeMKV_log.txt
SDF v07a: HL-DT-ST_BD-RE__BH16NS40_1.03_211403261115_K99ECTG1651
001011:0000 Using LibreDrive mode (v06.2 id=8B0DAADF6310)
DEBUG: Code 2147483648 at @-Nuv]M)#h?#R!f1:29396621
001003:0020 DEBUG: Code 0 at @-Nuv]M)#h?#R!f1:121265108
DISCID=9A9F36B3AF2638293367C6D6FC5A287B587B80C9
003307:0000 File 00000.mpls was added as title #0
005014:0000 Saving 1 titles into directory file://E:/Video/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 1
THDSF: [truehd @ 0000015128036f90] End of stream indicated.
001003:0020 DEBUG: Code 0 at <F;e`-8A<-u?T[9fqVF+:121263360
001003:0020 DEBUG: Code 5 at {jh$~Hd ?TZ>P#@H:121264165
001003:0020 DEBUG: Code 0 at mirI$m!:l!nb1uc0(p.,]:29400094
---- Failed E:/Video/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 1/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 1_t00.mkv
ch_0 1507890384000 0
ch_1 1508971464000 0
ch_2 1510052544000 0
ch_3 1511133624000 0
ch_4 1512214704000 0
ch_5 1513295784000 0
ch_6 1514160648000 0
ch_7 1514953440000 2
4 2012 002001 1515517920000 11520000 B7FB26FA 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000004000000040000000400000007144D84C8C98B5A94A4A5294A528420E7398A520C620C1AC62D4B5A94A5294A4A94A4A52939CA52C1AD62D6A5294A5292A5294A4A929398A51BD8B529294210731C
s=5 n=2 o=12288
5 5760 004001 1514964600000 5400000 F7E2D8D0 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
5 5760 000001 1514953440000 5400000 F7E2D8D0 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
AV sync issues in E:/Video/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 1/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 1_t00.mkv
AV sync in 3,4 at 0:23:22.734 (6.666ms) : encountered overlapping frame, audio skew is +6.666ms
AV sync in 2 at 0:23:22.734 (14.666ms) : short audio gap was removed, audio skew is -14.666ms
005003:0000 Failed to save title 0 to file E:/Video/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 1/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 1_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sat Aug 22 10:09:46 2020
Disc 2
Debug log started at Sat Aug 22 06:04:37 2020 , written by MakeMKV v1.15.2 win(x64-release)
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\MakeMKV_log.txt
DISCID=7FF2FFFF34E32368F9739F21D7B0DC425A453F48
003307:0000 File 00005.m2ts was added as title #1
003307:0000 File 00004.m2ts was added as title #2
005014:0000 Saving 3 titles into directory file://E:/Video/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 2
005001:0308 File E:/Video/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 2/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 2_t01.mkv already exist. Do you want to overwrite it?
005001:0308 File E:/Video/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 2/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 2_t02.mkv already exist. Do you want to overwrite it?
THDSF: [truehd @ 000001abd7ccffb0] End of stream indicated.
AV sync issues in E:/Video/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 2/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 2_t00.mkv
AV sync in 5 at 0:38:35.960 (20.333ms) : audio gap was filled with silence
AV sync in 2 at 0:38:35.980 (12.333ms) : short audio gap was removed, audio skew is -12.333ms
004008:0010 AV sync issue in stream 3,4 at 0:38:35.957 with duration of 23ms : audio gap - 2.156 missing frame(s)
004008:0010 AV sync issue in stream 1 at 0:38:35.946 with duration of 33.375ms : audio gap - 40.05 missing frame(s)
THDSF: [truehd @ 000001abd7cd1c90] End of stream indicated.
---- Failed E:/Video/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 2/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 2_t00.mkv
ch_0 4666301640000 0
ch_1 4667382720000 0
ch_2 4668463800000 0
ch_3 4669544880000 0
ch_4 4670625960000 0
ch_5 4671707040000 0
ch_6 4672716048000 0
ch_7 4673689020000 4
mt=000001ABC699ED70 n=6
4 2012 006001 4673677320000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
s=5 n=2 o=12288
5 5760 004001 4673694960000 5400000 F7E2D8D0 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
5 5760 000001 4673689020000 5400000 F7E2D8D0 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
AV sync in 2 at 1:12:07.468 (33.833ms) : audio gap - 1.057 missing frame(s)
005003:0000 Failed to save title 0 to file E:/Video/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 2/LUDWIG VAN BEETHOVEN- 9 SYMPHONIES - BERLINER PHILHARMONIKER- HERBERT VON KARAJAN I DISC 2_t00.mkv
005004:0080 2 titles saved, 1 failed
005037:0204 Copy complete. 2 titles saved, 1 failed.
Application exited at Sat Aug 22 06:32:01 2020
Is this what you need?
I think the audio gap is intended because the gap is located between the symphonies.
