BP60NB10 firmware question on disc playback
obscura
#1 Post by obscura » Tue Aug 18, 2020 3:40 pm
Hi, a quick question:
Does flashing my BP60NB10, a UHD official drive, to an MK firmware make it more UHD friendly, thereby allowing me to playback directly off a disc through DVDFab Player or VLC? I've tried to playback with original firmware and it seems to crash or hang.
Re: BP60NB10 firmware question on disc playback
#2 Post by MartyMcNuts » Wed Aug 19, 2020 12:49 am
obscura wrote: Tue Aug 18, 2020 3:40 pm Hi, a quick question:
BP60NB10 1.00 MK is the firmware of choice. I believe you should be able to play UHD using DVDFab player. Don't know about VLC.
obscura
#3 Post by obscura » Wed Aug 19, 2020 3:02 am
MartyMcNuts wrote: Wed Aug 19, 2020 12:49 am BP60NB10 1.00 MK is the firmware of choice. I believe you should be able to play UHD using DVDFab player. Don't know about VLC.
Thanks for the response! The drive I got recently was manufactured back in May 2020 and came with version 1.01 -- am I correct to assume that I'll have to flash it to the 1.01 MK or 1.02 MK firmware first before I can downgrade to 1.00 MK?
I just thought as a UHD official drive I would be able to playback using DVDFab player without any modification, but it seems like all the third party software other than PowerDVD will only work on UHD friendly drives.
#4 Post by MartyMcNuts » Wed Aug 19, 2020 11:39 pm
obscura wrote: Wed Aug 19, 2020 3:02 am
Correct. Flash 1.01-MK first, then 1.00-MK.
Yep, anything other than PowerDVD requires flashed firmware.
obscura
#5 Post by obscura » Fri Aug 21, 2020 1:22 pm
MartyMcNuts wrote: Wed Aug 19, 2020 11:39 pm Correct. Flash 1.01-MK first, then 1.00-MK.
Thank you good sir for the clarification. Sorry, just one more newb question, is there a thread somewhere that describes how to backup the original firmware (that is if it is even possible)?
When I get the chance (it might be a few weeks as I don't have time right now), I'll be sure to provide updates on my experiences with flashing the different firmwares and testing of playback so others can use this thread as a reference.
#6 Post by Billycar11 » Fri Aug 21, 2020 6:16 pm
Davidson wrote: Fri Aug 21, 2020 6:24 am I have been in contact with both LG support and MS support about this issue so far they have not been able to solve it.
I try with this forum as the issue seems to connected to the manufacture of the HW/PC.
Microsoft and LG are the last people that are going to help you unofficially playback a UHD disc. What are your PC specs?
#7 Post by MartyMcNuts » Sat Aug 22, 2020 12:53 am
obscura wrote: Fri Aug 21, 2020 1:22 pm
Not possible to back up the firmware. The best you can do is dump the user data. To do this, grab my SDFtool_flasher from viewtopic.php?f=16&t=22896, select your drive, select READ firmware and click START. The user data will be dumped to a folder called "Firmware_Dumps" which will be created in the same directory as the flasher.
obscura
#8 Post by obscura » Thu Jul 22, 2021 7:56 am
Apologies folks for my late update as it took me a lot longer than anticipated to finish my build due to trying to obtain a graphics card. :lol:
I can confirm playback works in VLC with the latest 1.02 firmware.
The only other player I tried was DVDFab Player Ultra, which didn't work as the application will display a prompt saying it is an incompatible drive for playback -- it looks like it's just reading the model of the drive and doesn't bother trying if it's not in its list of compatible drives. I downgraded the firmware to 1.01 and 1.00 to see if it would make a difference, but it didn't.
Has anyone been successful in playback with DVDFab Player or are there any other software players you would recommend to try?
