Every time i just start the program I'm getting scsi errors, is that normal? (its also annoying)
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command 46020..00140 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at KV&ObvDR%bo"q`9V:29399450
Scsi errorrs?
Re: Scsi errorrs?
What kind of drive do you have?
mangry
Re: Scsi errorrs?
It says ASUS DRW-2014L1T ATA Devicemike admin wrote:What kind of drive do you have?
Re: Scsi errorrs?
Your drive doesn't confirm to SCSI MMC specification - I suggest updating drive firmware. It must be a really cheap drive. The error itself is harmless.
mangry
Re: Scsi errorrs?
How about just not having the program print that?mike admin wrote:Your drive doesn't confirm to SCSI MMC specification - I suggest updating drive firmware. It must be a really cheap drive. The error itself is harmless.
mangry
Re: Scsi errorrs?
It is running the latest firmware.
mangry
Re: Scsi errorrs?
Actually, turns out its not the DVD drive - its a specially formatted partition on a harddrive, made (from manufacturers) to look like a DVD drive to the system.
So the only fix would be to disable the hang scan of makemkv
