I'm trying to make an mkv of a file.
A get an error :
Debug log started at Sat Dec 11 21:39:10 2010 , written by MakeMKV v1.6.2 win(x64-release)
001005:0000 MakeMKV v1.6.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\John/MakeMKV_log.txt
003006:0000 Opening files on harddrive at D:/BBC_South_Pacific_Disc_1 1/BBC South Pacific Disc 1/
003305:0000 AACS directory not present, assuming unencrypted disc
003307:0000 File 00002.mpls was added as title #0
003307:0000 File 00009.mpls was added as title #1
003025:0000 Title #00001.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory E:/Video/South_Pacific_D1
001003:0020 DEBUG: Code 2 at Pwu8ABS9z?EQ\@cl8YC5:213130973
001003:0020 DEBUG: Code 1828 at se#Wjk$|<_4^GI!MuC-~~:213132077
001003:0020 DEBUG: Code 1644 at se#Wjk$|<_4^GI!MuC-~~:213132077
001003:0020 DEBUG: Code 3 at Pwu8ABS9z?EQ\@cl8YC5:213130973
001003:0020 DEBUG: Code 4 at yZ,,nxHB^GUA`evJM9i:121263958
005003:0000 Failed to save title 0 to file E:/Video/South_Pacific_D1/title00.mkv
005004:0080 0 titles saved, 1 failed
What could be the problem ?
Problems with South Pacific BBC
Re: Problems with South Pacific BBC
Hi!
1) Have you played the source file (from your hard drive) to see if it has any READ problems?
2) Try making a FULL DISC backup from your original, commercial Blu-ray disc.
