Failure to rip
Jman5150
Failure to rip
Post by Jman5150 » Mon Aug 17, 2020 8:40 am
Whats a good checklist of things to check outside of a software or hardware error for 4k rips/ backups that fail
Clean disk
Restart drive
Restart software
Having issues with a star trek 2009 disk that should work, every other disk does. There are a few scratches but not many.
Anything else i should get in habit of checking before posting logs or reinstalling software?
Re: Failure to rip
Post by Billycar11 » Mon Aug 17, 2020 10:19 am
UHD disc with scratches is dead for ripping.
you can try polishing them out that might make it work but you need a perfect disc
Jman5150
Re: Failure to rip
Post by Jman5150 » Mon Aug 17, 2020 11:18 am
Heres the logsince ive exhausted other options.
MakeMKV v1.15.2 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/JeffMorrissette/MakeMKV_log.txt
Optical drive "BD-RE ASUS BW-16D1HT 3.10d" opened in OS access mode.
Using LibreDrive mode (v06.2 id=0FA242DD4D0B)
Backing up disc into folder "/Volumes/mymovies2/STAR TREK 2009"
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '10190192640'
DEBUG: Code 0 at /Zsq;Mq5z%K?u;BaD5t:121266189
DEBUG: Code 0 at /Zsq;Mq5z%K?u;BaD5t:213133365
DEBUG: Code 0 at m`9]nBNXhI/C'0Jj^2$p:29396920
Backup failed
Re: Failure to rip
Post by Billycar11 » Mon Aug 17, 2020 12:17 pm
Yeah that's a read error try polishing the disc with some disc compound and then polish.
Or just get a replacement
Jman5150
Re: Failure to rip
Post by Jman5150 » Mon Aug 17, 2020 6:44 pm
